Sony 19 in. (Diagonal) Class LCD Integrated HDTV (720p) - Pink
#85
4.4
based on 90 reviews
from $335.00 - $449.99
Ratings Distribution
5 star
59
4 star
20
3 star
7
2 star
0
1 star
4
Category Average
4.4
Pros
  • Great picture quality (68)
  • Attractive design (67)
  • High resolution (64)
  • Fast setup (63)
  • Simple controls (61)
  • Good connection options (58)
  • Wide viewing angle (42)
  • Lightweight (5)
  • Adjustable (2)
  • Easy setup (2)
See less See more
Cons
  • Poor image quality (3)
  • Difficult to set up (2)
  • Lacks timer (1)
  • Narrow viewing angle (1)
  • Poor sound quality (1)
  • Pricey (1)
  • Slow changing channels (1)
  • Tilting for good image (1)
  • Vividy not to trinitron (1)
Best Uses
  • Bedroom (27)
  • Home (27)
  • Kitchen (24)
  • Office (9)
  • Wall mounting (8)
  • Movies (5)
  • Video (2)
  • Craft room (1)
  • Dental lab (1)
  • Dorm (1)
Provided by Meijer.com
Want a small LCD HDTV that brings a lot to the (kitchen) table? The KDL-19M4000 is Sony's answer. With 3 HD connections (HDMI, component, and PC input), a sleek design, and the picture quality you've come to expect from Sony, the KDL-M4000 is designed to give you the performance you want in a more compact package. Perfect for the kitchen or bedroom, the 15:9 720p resolution panel (1440x900) provides crisp, detailed, and vibrant images.
The built-in ATSC/NTSC tuner with QAM delivers over-the-air digital TV and unencrypted HDTV broadcast signals, as well as traditional analog TV broadcasts. It also features a video noise reduction circuit that helps improve image quality by reducing image artifacts typical when viewing DVDs or digital TV channels and a fast panel response helps provide a crisp, clear image. VESA compatible hole spacing uses an industry-standard mounting hole pattern to allow a wide range of VESA compatible wall mount bracket choices.
Specification Description
Model 027242738591, KDL-19M4000, KDL-19M4000/G, KDL-19M4000/L
UPC 027242738584
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (3) Rear Input
Aspect Ratio 16:9
Color Black
color null
Component Video Rear Input
Composite Video Rear Input
Composite Video Side Input
Contrast Ratio 3000:1
DB15 (PC Video) Rear Input
Depth (Inches) 6.5
Energy Star Compliant Yes
HDMI Rear Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 720p
Headphone Jack Side Output
Height (Inches) 15.8
Optical Rear Output
Ports 1 x 15-pin HD-15 VGA In Rear
Ports 1 x S-Video In Rear
Refresh Frequency 60 Hz
Remote Control Included
Resolution 1440 x 900
RF Rear Input
S-Video Rear Input
Screen Format 16:9 Widescreen TV Imaging
Screen Size 11" to 20"
Screen Size 19"
Screen Size (inches) 19
Screen Size (Inches/Diagonal) 19
Select LCD Units
size null
sku 153858
skuprice 499.9900
Speakers 5 Watts x 2
Speakers Built-in
Standard Warranty 1 Year Limited
style 027242738591
taxable Y
Technology HDTV
Tuner ATSC
Tuner NTSC
Tuner QAM
Wall Mountable VESA Compliant
Wall Mountable Yes
Weight (Pounds) 16.1
Width (Inches) 19.1
Sony 19 in. (Diagonal) Class LCD Integrated HDTV (720p) - Pink Questions
Questions and Answers
Where to Buy
$335.00
5% off orders at Abt.com ends 11/30/09
BizRate Rating Outstanding 9.4
$349.99
$449.99
Code KMART5OFF50 : Save $5 off $50 with coupon
Product Reviews
Last update: Oct 9, 2009
Sony 19 in. (Diagonal) Class LCD Integrated HDTV (720p) - Pink Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
5.0
Amazing LCD TV from a great seller
"This is the nicest flat-panel LCD TV that I have ever seen in this size. The picture is amazing no matter what the source is. HD is breathtaking, even analog cable looks good on this TV. The picture is bright, colorful, and sharp. The sounds is also pretty good...as good as it really can be for a 19" LCD. The design of the TV is actually pretty nice. Features a good array of inputs. Remote is also very nice. The..." Read Full Review »
Aug 14, 2008 by Erik
See more positive Sony 19 in. (Diagonal) Class LCD Integrated HDTV (720p) - Pink reviews
3.0
Vertical viewing angle is limited
"If set is placed on a shelf that is above eye-level, screen is too dark. If set is placed below eye-level, screen is too light. Set must be placed at eye-level, or slightly below. Vertical viewing angle is limited...." Read Full Review »
Jan 27, 2009 by Chuck
See more negative Sony 19 in. (Diagonal) Class LCD Integrated HDTV (720p) - Pink reviews
Displaying 1 - 5 of 90 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Dorm
  • Home
  • Kitchen
"This is the nicest flat-panel LCD TV that I have ever seen in this size. The picture is amazing no matter what the source is. HD is breathtaking, even analog cable looks good on this TV. The picture is bright, colorful, and sharp. The sounds is also pretty good...as good as it really can be for a 19 …"  Read Full Review »
Was this LCD TV review on the Sony 19 in. (Diagonal) Class LCD Integrated HDTV (720p) - Pink helpful to you?
 Report Abuse  (3)  (0)  0 comments
Aug 14 2008
Erik
Pennsylvania
I am:
  • Tech Savvy
Reviewed at:
Perfect!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • Portability
  • More »
    Cons
  • None
    Best Uses
  • Craft room
  • Home
  • Kitchen
  • Office
"We don't have space to set up TVs in our kitchen and craft room permanently, so this lightweight TV solved the problem. It is lightweight enough to go move back and forth between the two rooms and streamline, taking very very little space. (Remember the days of 'portable' TVs?) Unlike portable TV …"  Read Full Review »
Sep 29 2008
New Villagers
The Villages, FL
I am:
  • Casual User
Reviewed at:
Price: $335.00
[2 of 2 customers found this review helpful]
Best in Class
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • At angles the picture was
    Best Uses
  • Bedroom
"First HDTV did a lot of homework mostly by reading revues on sites like this. Then on mfg website for product info dolby digital contrast ratio etc, Sony always came out on top. I would definetly recomend this TV. Just one word of advice, and its on Sony site also for the 26" M series----From angles …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jan 29 2009
Rob
Queens,NY
I am:
  • Enthusiast
Reviewed at:
Non-standard screen dimensions; good sound
4.0
"Pros:
- Most powerful sound system of any 19 inch flat panel
- Sturdy cabinet
- Nice remote
Cons:
- Non-standard screen dimension/poor zooming
- Some ringing in picture, even in HD
I purchased this TV strictly on its sound quality/power -- at 5 watts per channel, it's much more powerful sounding …"  Read Full Review »
Jan 2 2009
Llamaguy
Connecticut
Reviewed at:
[1 of 1 customers found this review helpful]
Great kitchen TV
4.0
    Pros
  • Bright Image
  • Good Resolution
  • Good Sound
  • Simple Controls
  • More »
    Cons
  • None
    Best Uses
  • Kitchen
"I needed a small TV to watch while I cook. I purchased one of these yesterday, and my husband and I are very pleased with its picture and sound quality--even though we don't have cable and the McMansion next store blocks signals. It is much better than the recently purchased Samsung HD LCD that co …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Feb 4 2009
LOL
Chicago suburb
I am:
  • Casual User
Reviewed at:
Price: $335.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
