Smith-Victor RTK4 4 Channel Radio Trigger Kit
#1963
3.5
based on 33 reviews
from $79.95
Ratings Distribution
5 star
11
4 star
10
3 star
4
2 star
2
1 star
6
Category Average
4.2
Low Price:
$79.95 at B&H Photo Video
 Trusted:
$79.95 at Adorama
Find it at Amazon
Pros
  • Lightweight (26)
  • Reliable (18)
  • Convenient interface (11)
  • Easy to use (11)
  • Easy to pack (2)
  • Cheap (1)
  • Good price / value (1)
  • Great look (1)
  • Small (1)
  • Softens light (1)
See less See more
Cons
  • Unreliable (5)
  • Weak construction (5)
  • Poor interface (3)
  • Poor design (2)
  • Batterys barely fit (1)
  • Don't step on it (1)
  • Dosnt work (1)
  • Flimsy (1)
  • Hard to open (1)
  • Inconsistent (1)
Best Uses
  • Photography (12)
  • Lighting (11)
  • Fill flash (5)
  • Portraits (5)
  • Studio (4)
  • Night photography (3)
  • Travel (3)
  • Close -ups (2)
  • Macro (2)
  • Photojournalism (2)
Provided by B&H Photo Video
The Photogenic RTK-4 Radio Trigger Set enables firing of a StudioMax III or any other strobe monolight or power pack, without running a sync cord between the camera and your flash unit.This four-channel system is designed for use with both portable off-camera flashes and studio strobes. It provides reliable radio technology to trigger strobes up to a distance of 150' (50 m) without sync cords or unreliable optical slaves. Add a receiver for each additional flash unit in your set up.
Specification Description
Model 401552
UPC 037733008546
Select Sets
Smith-Victor RTK4 4 Channel Radio Trigger Kit Questions
Questions and Answers
Where to Buy
$79.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$79.95
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Nov 18, 2009
Smith-Victor RTK4 4 Channel Radio Trigger Kit Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
5.0
All you need and more
"After using sync cords in my studio to the point that the connection on my 20D became loose and intermittent I decided to go with a hot shoe mount radio flash system. Comparably priced to the Impact brand I decided to go with Photogenic due to the 4 channels vs. 16 channels (I have found that the less complicated electronics are the more reliable they seem to be). From the box to shooting in ten minutes without..." Read Full Review »
Apr 13, 2008 by URIAH
See more positive Smith-Victor RTK4 4 Channel Radio Trigger Kit reviews
3.0
UGH!!! UNPEEL THE STICKER!!!!
"UNPEEL THE STICKER TO CHANGE THE BATTERIES! THERE IS A SMALL SCREW HOLDING THE TRIGGER TOGETHER!!!! ITS UNDER THE STICKER!!!! After 1 hour to trying to force the thing off. I broke bits and pieces off the side. IT DOESN'T SNAP ON OR OFF!!!! IT HAS A SCREW HIDDEN UNDER THE STICKER! THEY PROBABLY PLACED THE STICKER THERE ON PURPOSE FOR YOU TO BREAK YOUR TRANSMITTER TO VOID WARRENTY!!!!! MAKE SURE TO UNSCREW ..." Read Full Review »
Jul 03, 2009 by Confused/Stressed
See more negative Smith-Victor RTK4 4 Channel Radio Trigger Kit reviews
Displaying 1 - 5 of 33 Reviews
Show
Sort by
5.0
    Pros
  • Convenient Interface
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Lighting
"After using sync cords in my studio to the point that the connection on my 20D became loose and intermittent I decided to go with a hot shoe mount radio flash system. Comparably priced to the Impact brand I decided to go with Photogenic due to the 4 channels vs. 16 channels (I have found that the l …"  Read Full Review »
Was this Camera Accessory review on the Smith-Victor RTK4 4 Channel Radio Trigger Kit helpful to you?
 Report Abuse  (4)  (0)  0 comments
Apr 13 2008
URIAH
Grafton,WV
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $79.95
Works as described
4.0
    Pros
  • Easy To Use
  • Lightweight
    Cons
  • Poor Design
    Best Uses
  • Macro Photography
  • Portraits
  • Studio
  • Traveling
"I use these to trigger a flash on a light stand for fill light. I just received them and tested it with one of my small flash units and it works. I don't know how they will hold up under pressure but will let you know in the future. The receivers need a small switch to turn them off, I think that's …"  Read Full Review »
Nov 18 2009
Sid
Atlanta, GA.
I am:
Reviewed at:
Price: $79.95
3.0
    Pros
  • Easy To Use
  • Lightweight
    Cons
  • Not Durable
    Best Uses
  • Everyday use
  • Home
  • Landscape Photography
  • Macro Photography
  • Portraits
  • More »
IT HAS A SCREW HIDDEN UNDER THE STICKER! THEY PR …"  Read Full Review »
Jul 3 2009
Confused/Stressed
Seattle, WA
I am:
  • Semi-Professional
Be afraid be...VERY afraid!
1.0
    Pros
  • Good Looks
    Cons
  • Inconsistent
  • Poor construction
  • poor design
  • Unreliable
    Best Uses
  • None
"Firstly, when I ordered the Photogenic RTK-4 Radio Trigger Set, I received a Smith Victor Set. The main difference is that the Photogenic has a range of 150 feet Vs 80 feet! I enquired about this mixup from the BH Staff and was informed that Photogenic is now owned by Smith Victor and given an apolo …"  Read Full Review »
Mar 20 2008
El Reto
Trinidad and Tobago, West Indies
I am:
  • Professional
it works!
4.0
    Pros
  • Easy To Use
  • Lightweight
    Cons
  • None
    Best Uses
  • Portraits
  • Studio
"I bought the set with one extra receiver about a year ago, and I was so satisfied that I purchased two extra receivers early this summer. They all work perfectly, and the only problem I have had is that the battery seems to run out faster than stated in the manual. After about two months of extensiv …"  Read Full Review »
Aug 30 2009
Svend
Oslo, Norway
I am:
  • Semi-Professional
Reviewed at:
Price: $79.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
