Sling Media Slingbox Pro-HD (Model #SB300-100)
#2
3.8
based on 38 reviews
Ratings Distribution
5 star
19
4 star
7
3 star
3
2 star
3
1 star
6
Category Average
3.8
$263.00 - $299.99
from 10 stores
More Images
Pros
  • Crisp picture (9)
  • Easy to install (9)
  • Fast connection (9)
  • Easy setup (4)
  • Fast (3)
  • Fast connection speed (2)
  • Reliable connection (2)
  • Secure connection (2)
  • Best quality pictures (1)
  • Excellent product (1)
See less See more
Cons
  • Awful customer support (1)
  • Channel scan is too slow (1)
  • Mac installer a bit rough (1)
  • No hdmi input (1)
  • No mac hd yet (1)
Best Uses
  • Home (11)
  • Sports (8)
  • Office (5)
  • Home network (4)
  • Movies (4)
  • Large networks (2)
  • Golf course (1)
  • Small networks (1)
  • Tv (1)
Provided by Beach Audio
Wherever you are, provided there's Broadband Internet service, you can enter your secret code and view your TV on your PC notebook, even in High-Definition! With a set of Standard Definition (SD) and High Definition (HD) inputs and a built-in Digital HDTV tuner, you can truly watch all of your TV anywhere. The built-in TV tuner also allows you to watch your local analog/digital Broadcast or basic cable without changing Channels on your home TV. Slingbox PRO-HD unleashes the latest Hardware advancements to deliver the best Video Streaming quality of any Slingbox to date, for both local and remote viewing. And you can use the Slingbox PRO-HD with virtually any audio/video device such as an HD-DVR, satellite receiver, cable box, or security camera.
Specification Description
Model SB300-100, SB300100, SLINGBOXPROHD
UPC 852619001585
#per pack 1
Auto Sensing Yes
Benefits Streams high-definition video around the house or over the internetWatch your HDTV anywhere on your laptop or mobile phone with no mo
Cables Included Ethernet cable, Coaxial cable, Composite video cable, Component video cable, Remote control IR cable, S-video cable, Stereo audio cable
Capacity UOM mAh
Connections Component video in (2)Component video out (2)Composite video in (1)Composite video out (1)Analog audio RCA
Country Of Origin China
Description Header Watch your home HDTV anywhere.
Display Catalog Number 55031933
Enclosure Color Black
End Product Indicator Yes
Included in the Box Slingbox PRO-HDAC adapterEthernet cableCoaxial cableComposite video cableComponent video cable
Manufacturer Labor Warranty 12
Manufacturer Part Number SB300-100
Manufacturer Parts Warranty 12
MAP Price 0.0
Model SB300-100
Operating Temperature UOM ° F
PC Interface Supported RJ-45 Ethernet
Product Depth 5.63
Product Dimensions UOM inches
Product Disclaimer *Additional fees from your internet or mobile provider may apply.
Product Height 2.38
Product Type Multimedia
Product Weight 4
Product Weight UOM pounds
Product Width 13.25
Software Included SlingPlayer
Supported Languages English
Voltage Required 100-240V 50-60Hz
Sling Media Slingbox Pro-HD (Model #SB300-100) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 9, 2009
Sling Media Slingbox Pro-HD (Model #SB300-100) Reviews
Most helpful positive review
Most helpful negative review
4.0
Brilliant!
"This is a brilliant device that works as advertised.I have not used the remote control of devices feature (seriously, if I am away, playing a movie that I had to already pre-load in a DVD player is not realistic), but just getting my shows and sports while traveling is fantastic.Everything is great so far. The only drawback was the kludgy Mac installer, which, after it updated the firmware, went goofy. I had t..." Read Full Review »
Oct 12, 2009 by TravelinMan
See more positive Sling Media Slingbox Pro-HD (Model #SB300-100) reviews
3.0
Pretty Good
"The unit works as advertised but a couple things prevent it from being perfect. First, when you control your DVD using the built-in remote, you might lose a couple seconds of your stream. That's annoying if you just press something like the info button. There are several firmware and software updates that are required before you can use it on other machines. For example, if you run it on one machine and it s..." Read Full Review »
May 24, 2009 by cengland0
See more negative Sling Media Slingbox Pro-HD (Model #SB300-100) reviews
Displaying 1 - 5 of 38 Reviews
Show
Sort by
Brilliant!
4.0
    Pros
  • Crisp Picture
  • Fast Connection
  • Works as advertised
    Cons
  • No Mac HD yet
    Best Uses
  • Sports
  • TV
"This is a brilliant device that works as advertised.I have not used the remote control of devices feature (seriously, if I am away, playing a movie that I had to already pre-load in a DVD player is not realistic), but just getting my shows and sports while traveling is fantastic.Everything is great …"  Read Full Review »
Was this HDTV Tuner review on the Sling Media Slingbox Pro-HD (Model #SB300-100) helpful to you?
Oct 12 2009
TravelinMan
Somerset, KY
I am:
  • Casual User
Reviewed at:
Price: $263.84
THANK YOU!!!
5.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Office
  • Sports
"This gadget is absolutely incredible. Best gadget I've ever bought. Have it hooked up to my iphone (yes you can use 3g if you google long enough), and it works great. I use it every single day. "
Nov 9 2009
Paul
Baltimore, MD
I am:
  • Power User
Reviewed at:
Price: $263.84
Pretty Good
3.0
    Pros
  • Crisp Picture
  • Easy Installation
  • Fast Connection
    Cons
  • No HDMI input
    Best Uses
  • Home
  • Movies
There are several firmware and software u …"  Read Full Review »
May 24 2009
cengland0
Orange Park, Florida
I am:
  • Power User
Reviewed at:
Price: $298.00
Worthless Piece of Junk
2.0
"I purchased the Slingbox so that I could avoid the cost and set-up problems of cable TV or a satellite dish at an alternative residence that I use on an infrequent basis. The idea of portable TV viewing from my home base via the internet was a future-perfect solution!
When I purchased the Slingbox …"  Read Full Review »
Aug 25 2009
ChipperCat105
Virginia
Reviewed at:
Price: $299.99
Great on the back 9
4.0
    Pros
  • Crisp Picture
  • Easy Installation
  • Fast Connection
    Cons
  • None
    Best Uses
  • Golf Course
  • Home
  • Office
  • Sports
"I have an iPhone and wanted this product so I could stream Cubs games to it when I'm on the golf course. It works perfectly. I can fast forward, and rewind at my own leisure. It was a little difficult getting the streaming to work over the 3G network (Jailbreak iPhone and modify a little) but it w …"  Read Full Review »
Aug 18 2009
Chet the golfing cubs fan
Chicago, IL
I am:
  • Power User
Reviewed at:
Price: $263.84
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
