SIRIUS Satellite Radio Stratus Dock and Play with Car Kit
3.6
based on 54 reviews
Ratings Distribution
5 star
21
4 star
15
3 star
2
2 star
6
1 star
10
Category Average
4.0
Pros
  • Easy to install (42)
  • Easy to use (42)
  • Clear display (40)
  • Portable (35)
  • Attractive design (32)
  • Reliable reception (27)
  • Compact size (1)
  • Docks to port boom box (1)
  • Good value (1)
  • Install simple as 1 2 3 (1)
See less See more
Cons
  • Poor reception (18)
  • Hard to install (7)
  • Difficult to use (2)
  • Bad support from store (1)
  • Difficult to transport (1)
  • Does not come with remote (1)
  • Gets hot (1)
  • Hard to see display (1)
  • I only have one (1)
  • No remote control (1)
Best Uses
  • Car (44)
  • Music (35)
  • Travel (21)
  • Talk shows (18)
  • Sports (17)
  • News (16)
  • Boom box at beach (1)
  • Everything (1)
  • Garbage (1)
  • Howard 100 and 101 (1)
Provided by RadioShack
Stratus receiver with Universal Dock makes it easy to listen to your SIRIUS radio at home or on the go.
Specification Description
Model SV3TK1R
Age Adult
Antenna Type Low profile magnetic
Benefits Plug-and-play receiver offers simple controls & ease of use with large buttons and a bright displayPush-button navigation so you can
Built-in Clock Digital clock
Built-in Wireless FM transmitter Yes
Cable Length 21 ft
Cable Type Antenna
Capacity UOM mAh
Controls Power, menu, jump, preset/direct tune, category previous/next, channel up/down, select
Controls / Adjustments Brightness, contrast, mode
Country Of Origin Taiwan
Description Header Get the best radio on radio.
Display Catalog Number 12-167
Display Form Factor Built-in
Display Illumination Color Amber
Display Information Signal strength, artist, title, category, time
Display Languages English
End Product Indicator Yes
Features One-Touch Jump™ to local traffic, weather or your favorite channelReal-time clock is satellite updated with 7 time zones
Form Factor Vehicle rooftop
Gender Either
Included in the Box Stratus SV3 RadioVehicle docking stationAdhesive dash mountVent mount and extended vent hooksVehicle power
Inputs 1 x Barrel(5VDC), 1 x (Antenna)
Interest Musical
Line Qty 3 Lines
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 185 Fahrenheit
Min Operating Temperature -4 Fahrenheit
Model SV3TK1R
New Date Sun Jan 28 00:00:00 CST 2007
Operating Temperature UOM ° F
Outputs 1 x Phone 1/8"(Audio), 1 x Phone 3/32"(FM Out)
Parental controls Yes
Power Device Power adapter-external
Product Dimensions UOM inches
Product Disclaimer Activation fee of $15 and taxes apply. Cannot be sold or transferred. SIRIUS reserves the right to modify or terminate this offer at any time. See ass
Product Height 9.625
Product Length 9.625
Product Type Receivers & tuners
Product Weight 1.6
Product Weight UOM pounds
Product Width 3.25
Radio Channel Qty 100 Channels
Recipient Mom,Dad,Sister,Brother,Daughter,Son,Significant Other,Myself,Friend
Required to function Subscription to SIRIUS Satellite Radio required
Supported Languages English
Type LCD
SIRIUS Satellite Radio Stratus Dock and Play with Car Kit Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Stratus Dock and Play with Car Kit
See all eBay results
  at eBay.com
Product Reviews
Last update: Feb 28, 2009
SIRIUS Satellite Radio Stratus Dock and Play with Car Kit Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
4.0
Good unit - need to understand limits
"Using a direct cable connection via the AUX input in the car the unit's reception is flawless except when traveling thru heavily wooded area or tunnels. If relying on the FM interface it is challenging to keep a clean reception if traveling out of broadcast zones. Also purchased a home dock and works better than the FM reception that is poor in my home. One thing you need to be aware is that Sirius will charge y..." Read Full Review »
Nov 27, 2008 by mx5man
See more positive SIRIUS Satellite Radio Stratus Dock and Play with Car Kit reviews
1.0
stay away
"i bought one from radio shack in grayson ky and subscribed to it it worked great for 1 hour then when i turned the power off it woudnt come back on so i packed it back up and took it back to the store to get a trade in or refund and they wouldnt give either they said it was the wrong power cord and said i was just stuck with it ive never had trouble with radioshack in the pastbut if thats the way there gonna be ..." Read Full Review »
Sep 10, 2008 by peed
See more negative SIRIUS Satellite Radio Stratus Dock and Play with Car Kit reviews
Displaying 1 - 5 of 54 Reviews
Show
Sort by
stay away
1.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Portable
    Cons
  • Difficult To Use
  • Poor Reception
    Best Uses
  • Car
  • Sports
  • Talk Shows
"i bought one from radio shack in grayson ky and subscribed to it it worked great for 1 hour then when i turned the power off it woudnt come back on so i packed it back up and took it back to the store to get a trade in or refund and they wouldnt give either they said it was the wrong power cord and …"  Read Full Review »
Was this Satellite Radio System review on the SIRIUS Satellite Radio Stratus Dock and Play with Car Kit helpful to you?
 Report Abuse  (3)  (0)  0 comments
Sep 10 2008
peed
grayson ky
I am:
  • Practical
Reviewed at:
4.0
    Pros
  • Easy To Install
  • Easy To Use
  • Portable
    Cons
  • None
    Best Uses
  • Car
  • Music
  • Sports
  • Traveling
"Using a direct cable connection via the AUX input in the car the unit's reception is flawless except when traveling thru heavily wooded area or tunnels. If relying on the FM interface it is challenging to keep a clean reception if traveling out of broadcast zones. Also purchased a home dock and work …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Nov 27 2008
mx5man
Jersey Shore
I am:
  • Gearhead
  • Practical
Reviewed at:
Funny Joke at the cost of your Money
1.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Use
    Cons
  • Difficult To Install
  • Poor Reception
    Best Uses
  • Car
  • Music
"Well I purchased my unit and took it home to install,(this is the 3rd plug and play radio Ive installed) The unit this model was replacing was a XACT Jockey 2 (excellent unit! To bad its no longer made)
After a 2 hrs install, (running all the cables through the dash; power, ant, and fm transmit …"  Read Full Review »
Sep 21 2008
MotorHead
Orlando Fl
I am:
  • Gearhead
Reviewed at:
[1 of 1 customers found this review helpful]
Electronics salesman
5.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
  • More »
    Cons
  • Poor Reception
    Best Uses
  • Car
  • Traveling
"As a asst store manager for RadioShack I wanted to see exactly how good/bad this radio was for the small price and how easy/hard the installation was going to be for my customers. I read and reread the directions as taught before attempting the installation. Following the instructions I had my uni …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Mar 4 2008
Shack manager
Washington DC suburbs
I am:
  • Tech Savvy
Reviewed at:
My Wife's Gift SV#-TK1
5.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
  • More »
    Cons
  • None
    Best Uses
  • Car
  • Music
  • News
  • Talk Shows
"My wife purchased the SV3-TK1 Sirius radio for me for my 55th birthday and I love it. I have not yet installed it in my car because I see no specific reason to damage either my car or the new radio. I have a Mercedes-Benz SLK and when the hard top goes down, I feared that I would rip the antenna wir …"  Read Full Review »
Oct 7 2007
Bobby
Andover, MA
I am:
  • Professional
  • Technically Challenged
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
