SIRIUS Satellite Radio Stratus 5 Dock and Play Radio
3.9
based on 9 reviews
Ratings Distribution
5 star
3
4 star
4
3 star
1
2 star
0
1 star
1
Category Average
4.3
Pros
  • Attractive design (8)
  • Easy to install (8)
  • Easy to use (8)
  • Clear display (7)
  • Portable (6)
  • Reliable reception (3)
See less See more
Cons
  • Poor reception / weak antenna (4)
  • Hard to see display (1)
  • Wimpy fm output (1)
Best Uses
  • Car (6)
  • Music (6)
  • News (5)
  • Travel (5)
  • Sports (4)
  • Talk shows (4)
Provided by RadioShack
The Stratus 5 features all the essential features needed to maximize the enjoyment of SIRIUS in your vehicle.
Specification Description
Model SV5TK1R
Battery Type Remote
Benefits Universal docking capability: Add accessories to enjoy in your home, office or additional vehiclesFM transmitter or stereo audio outp
Built-in Clock Digital clock
Built-in Wireless FM transmitter Yes
Capacity UOM mAh
Channels 120 Channels
Chemistry Lithium
Connections Satellite antenna in (1)FM antenna in (1)Aucio in 1/8" (1)
Controls Menu, display, memo, rewind, play/pause, fast forward, select, power, channel up/down, category previous/next, presets (0-9), band, jump, FM preset
Controls / Adjustments Brightness, contrast
Country Of Origin China
Description Header All radio is not created equal.
Display Catalog Number 12-501
Display Information Artist, song title, channel information
Enclosure Color Black
End Product Indicator Yes
Included in the Box SIRIUS Stratus™ recieverVehicle dockMagnetic antennaVent mountDash mountFM extender antenna<
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model SV5TK1R
New Date Wed Dec 17 00:00:00 CST 2008
Operating Temperature UOM ° F
Parental controls Yes
Product Type Receivers & tuners
Size Coin Cell
Supported Languages English
Technology RF
Type LCD
Voltage 3
Voltage Required 12V DC
Voltage UOM Volts
SIRIUS Satellite Radio Stratus 5 Dock and Play Radio Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Stratus 5 Dock and Play Radio
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 7, 2009
SIRIUS Satellite Radio Stratus 5 Dock and Play Radio Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
Great Little Satellite Radio
5.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
  • More »
    Cons
  • None
    Best Uses
  • Car
  • Music
  • News
  • Sports
  • Talk Shows
  • More »
"Very easy to install. Should take most people less than an hour to install. No screws necessary, mine is clipped to a vent with the included clip mount. Wires are very sturdy yet thin and easy to hide following package instructions. There are only a few places in my area where I get lousy recept …"  Read Full Review »
Was this Satellite Radio review on the SIRIUS Satellite Radio Stratus 5 Dock and Play Radio helpful to you?
May 16 2009
TaxiTom
Inland Empire, CA
I am:
  • Tech Savvy
Reviewed at:
So far works great without problems
4.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
    Cons
  • None
    Best Uses
  • Car
  • Music
  • Traveling
"I installed the radio myself in my wife's vehicle in about two hours. It worked the first time power was turned on! I did however, decide to move the fm "Transmit wire" through the passenger door and attach it just under the vehicle's factory antenna. This seemed to help get a better signal to the f …"  Read Full Review »
Dec 23 2008
dja1922
Asheboro, NC.
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Great for the price & easy to install!!!
4.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
  • More »
    Cons
  • None
    Best Uses
  • Car
  • Music
  • News
  • Sports
  • Talk Shows
  • More »
"I don't know what everyone was talking about with bad reception. I had a factory installed Sirius unit in my Nissan and I had issues picking up signals under a car port. When I popped this baby in my Chevy, which took me maybe an hour, I didn't have to move my car to get a crystal clear signal. Easy …"  Read Full Review »
Feb 16 2009
Seattlegoobley
Seattle, WA
I am:
  • Tech Savvy
Reviewed at:
Another happy customer
5.0
    Pros
  • Attractive Design
  • Easy To Install
  • Easy To Use
  • Portable
  • Reliable Reception
    Cons
  • Hard To See Display
  • Wimpy FM output
    Best Uses
  • Car
  • Music
  • News
  • Sports
  • Talk Shows
  • More »
"If you are using this through the FM radio in your car, you are going to have problems because the FM transmitter in newer Sirius radios is wimpy per FCC edict. You will have stellar results with a direct audio connection. If your car radio does not have an audio input jack, get the RF cable that f …"  Read Full Review »
Aug 7 2009
Charlie
Chicago, IL
I am:
  • Audiophile
Reviewed at:
sirius for life
4.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
    Cons
  • Poor Reception
    Best Uses
  • None
"Have been a sirius subscriber for six years now and just bought my third reciever. I have always had great reception with out having my antenna mounted outside, unfortunately not with this model. i had to mount it outside on the roof, and now find myself changing the broadcast station at every stop …"  Read Full Review »
Jul 5 2009
Erock
cleveland, ohio
I am:
  • Tech Savvy
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
