SIRIUS Satellite Radio Stratus 5 Dock & Play Radio with Car Kit
4.0
based on 3 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
1
2 star
0
1 star
0
Category Average
4.3
$69.99 at RadioShack
Find it at Amazon
Find it at Ebay
$69.99
from 1 store
Pros
  • Easy to install (3)
  • Easy to use (3)
  • Clear display (2)
  • Portable (2)
  • Attractive design (1)
  • Reliable reception (1)
See less See more
Cons
  • Poor reception (1)
Best Uses
  • Car (3)
  • Music (3)
  • Talk shows (1)
  • Travel (1)
Provided by RadioShack
The Stratus 5 features all the essential features needed to maximize the enjoyment of SIRIUS in your vehicle.
Specification Description
Model SV5K1
Adjustable Auto Date/Time Yes
Antenna Features 21-feet long cable
Antenna Type Low profile magnetic
Auto Dimmer for display Yes
Battery Type Remote
Benefits Bright 3-line LCD display shows artist, song, channel info and moreFM transmitter or stereo audio output to connect to your vehicle's
Built-in Clock Yes
Built-in Wireless FM transmitter Yes
Cables Included 21-foot antenna cable
Capacity UOM mAh
Channels 120 Channels
Chemistry Lithium
Connections 1/8" stereo audio out (1)SMB antenna (1)
Controls Menu, display, memo, rewind, play/pause, fast forward, select, power, channel up/down, category previous/next, presets (0-9), band, jump, FM preset
Controls / Adjustments Brightness, contrast
Country Of Origin China
Description Header All radio is not created equal.
Display Catalog Number 12-656
Display Illumination Color Blue
Enclosure Color Black
End Product Indicator Yes
Features Satellite frequencies: 2322.293/2330.207MHzTerrestrial frequencies: 2326.250MHzTotal harmonic distortion (THD):
Form Factor Micro cable
Included in the Box SIRIUS® Stratus 5™Vehicle dockAdhesive dash mountVent mount with extended vent hooksVehicle power
Line Qty 3 Lines
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model SV5K1
Operating Temperature UOM ° F
Parental controls Yes
Product Depth 0.6
Product Dimensions UOM inches
Product Disclaimer Subscription to SIRIUS Satellite Radio is required.
Product Height 1.9
Product Type Receivers & tuners
Product Weight 2.4
Product Weight UOM ounces
Product Width 4.5
Search Modes Preset, category, channel, artist, song title
Size Coin Cell
Supported Languages English
Technology IR
Type LCD
Voltage 3
Voltage Required 5.2 volts DC, negative ground
Voltage UOM Volts
SIRIUS Satellite Radio Stratus 5 Dock & Play Radio with Car Kit Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 17, 2009
SIRIUS Satellite Radio Stratus 5 Dock & Play Radio with Car Kit Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Good Radio, Bad FM Transmitter
3.0
    Pros
  • Easy To Install
  • Easy To Use
    Cons
  • Poor Reception
    Best Uses
  • Car
  • Music
  • Traveling
"This radio is ALMOST exactly the same as the previous, but there are a few variations. The FM transmitter in this model is terrible in comparison with the previous stratus. The older model had a great built-in transmitter that did not require the use of the extra antenna cable. Even with the externa …"  Read Full Review »
Was this Satellite Radio review on the SIRIUS Satellite Radio Stratus 5 Dock & Play Radio with Car Kit helpful to you?
 Report Abuse  (1)  (0)  0 comments
Aug 14 2009
markga
Habersham, Georgia
I am:
  • Audiophile
  • Tech Savvy
[2 of 2 customers found this review helpful]
love this product
5.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
  • More »
    Cons
  • None
    Best Uses
  • Car
  • Music
  • Talk Shows
"i absolutely love this product we use it everyday we actually ordered two and use them in each of our vechiles we have 3 vechicles that they are used in and one 2 have the fm transmit set up and the other vechile we have the direct connect set up for our radio and i love the quality on all of them o …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Oct 17 2009
mine206
poplarville, ms
I am:
  • Practical
works great
4.0
    Pros
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
    Cons
  • None
    Best Uses
  • Car
  • Music
"It is easy to install, if you sit and play with the radio station you can find a good one, im in San Diego so it took me a while to find a station, 98.5 works everywhere in San Diego so far I have been as far as Mira Mesa to San Ysidro and to Alpine. Love this thing "
Aug 15 2009
Dezyer
Santee
I am:
  • Professional
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
