SIRIUS Satellite Radio Stiletto SL100-PK1 Portable Satellite Radio Receiver
#36
3.8
based on 37 reviews
Ratings Distribution
5 star
10
4 star
17
3 star
4
2 star
4
1 star
2
Category Average
4.0
$349.99 at Kmart
Find it at Amazon
Find it at Ebay
$349.99
from 1 store
More Images
Pros
  • Easy to use (18)
  • Clear display (17)
  • Portable (14)
  • Attractive design (13)
  • Easy to install (9)
  • Easy setup (6)
  • Reliable reception (6)
  • Good appearance (5)
  • Good features (4)
  • Great sound quality (4)
See less See more
Cons
  • Poor reception / weak antenna (6)
  • Poor battery life (2)
  • Bulky headphones (1)
  • Difficult to transport (1)
  • Difficult to use (1)
  • Finding accessories (1)
  • Heavier than expected (1)
  • Heavy / bulky (1)
  • Huedphones uncomfortable (1)
  • Intermittant signal (1)
Best Uses
  • Music (13)
  • Travel (12)
  • Car (11)
  • Talk shows (10)
  • Sports (8)
  • News (5)
  • Good for commuting (3)
  • Home (2)
  • Work (2)
  • Any where any place (1)
Provided by B&H Photo Video
Sirius' palm-sized Stiletto SL100 Portable Sirius Satellite Radio Receiver is actually a multitude of digital devices all wrapped up in 1 sleek body. The Stiletto, in addition to being perfect for listening to satellite radio whether you're walking around town at home, or in your vehicle, also stores and plays MP3 and WMA music files. Search for your favorite music by artist or song title with the music search function, and knowing the Stiletto is capable of storing up to 100 hours of Sirius programming, you'll always be able to save your favorite songs and shows. You can schedule and record up to 6-hour blocks of Sirius content at the touch of a button. No Signal? No Problem! The Stiletto has WiFi built in, so even if there is no Satellite signal you can always listen online. Not only does the Stiletto include all you need to fully experience the Sirius Satellite Radio experience, it also has MP3 capabilities with a 2GB Flash drive built in and displays sports scores on the large 2.2" Color screen.
Specification Description
Model SL100PK1, SL100PK1R
UPC 884720009709
Satellite Radio Tuner Sirius
Satellite Radio Type Portable
SIRIUS Satellite Radio Stiletto SL100-PK1 Portable Satellite Radio Receiver Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 14, 2008
SIRIUS Satellite Radio Stiletto SL100-PK1 Portable Satellite Radio Receiver Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
4.0
bit pricy but worth it if u got it!
"Purchased this [...] as an impulse buy and overall satisfied with the purchase. Sound is pretty good when using the home kit but the radio needs to be pretty near to your sound system. I don't use the car kit, but as portable, never had problems using it while commuting or walking and i work in the loop. The headphones are a bit bulky, and dorky but make a definite improvement on the reception while on the go..." Read Full Review »
Nov 19, 2006 by JR
See more positive SIRIUS Satellite Radio Stiletto SL100-PK1 Portable Satellite Radio Receiver reviews
2.0
USE TO BE A GREAT RADIO UNTIL
"I give this thing 2 stars cause it use to be great for the first 6 months. I always had 4 bars for signal. then all of the sudden it wont even keep 2 bars and is always acquiring signal. i tired using different antenna and tried the home dock and the car dock and still nothing more then 2 bars but mostly 1.the only way i can use the thing is at home on my wifi. witch works awesome. i called sirius today and the..." Read Full Review »
Feb 15, 2008 by pimpdaddypat
See more negative SIRIUS Satellite Radio Stiletto SL100-PK1 Portable Satellite Radio Receiver reviews
Displaying 1 - 5 of 37 Reviews
Show
Sort by
4.0
    Pros
  • Easy To Set Up
  • Great Sound
  • Simple Controls
    Cons
  • wireless "B" compatible
    Best Uses
  • At Work
  • Commuting
  • Travel
"Purchased this [...] as an impulse buy and overall satisfied with the purchase. Sound is pretty good when using the home kit but the radio needs to be pretty near to your sound system. I don't use the car kit, but as portable, never had problems using it while commuting or walking and i work in th …"  Read Full Review »
Was this Satellite Radio System review on the SIRIUS Satellite Radio Stiletto SL100-PK1 Portable Satellite Radio Receiver helpful to you?
 Report Abuse  (1)  (0)  0 comments
Nov 19 2006
JR
elmwood park, IL
Reviewed at:
2.0
    Pros
  • Attractive Design
  • Easy To Use
  • Portable
    Cons
  • Poor Reception
    Best Uses
  • Car
  • Music
"I give this thing 2 stars cause it use to be great for the first 6 months. I always had 4 bars for signal. then all of the sudden it wont even keep 2 bars and is always acquiring signal. i tired using different antenna and tried the home dock and the car dock and still nothing more then 2 bars but m …"  Read Full Review »
Feb 15 2008
pimpdaddypat
tampa florida
I am:
  • Gearhead
  • Tech Savvy
Reviewed at:
Cool radio,but buyer beware
5.0
    Pros
  • Records Satellite Radio
    Cons
  • None
    Best Uses
  • wi-fi
"I had to drive about 90 minutes to Beaufort,SC to find the home dock brand new (at the Radio Shack down there). [...] I bought the radio for home use anyways...the car kit is very available online (easily found using google). As for the product itself,yes Sirius promotes ALL of the Stiletto models a …"  Read Full Review »
Apr 30 2008
pussinboots
Ladson,South Carolina
I am:
  • General Home Electronics
Reviewed at:
[2 of 2 customers found this review helpful]
POOR SIGNALS
3.0
    Pros
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
    Cons
  • Poor Reception
    Best Uses
  • Traveling
"I can understand losing signal in tunnels or under bridges, but when you are traveling down a highway why would you lose signal? And why would you lose signal after you went under the bridge? Had signal under bridge, but lose it after you left the bridge?
Never had these problems when I had XM ra …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Sep 18 2007
supermonkey
Tampa, FL
I am:
  • Tech Savvy
Reviewed at:
An ok satellite radio at best
3.0
    Pros
  • Clear Display
  • Easy To Use
  • Portable
    Cons
  • Difficult To Transport
  • Poor Reception
    Best Uses
  • Car
  • Music
"I use this in both my work truck and personal vehicle, yes its easy to load music on and listen to in both vehicles but the FM transmitter is the worst. You will HAVE to buy either the plug that connects to the front of your car stereo, or the go-between plug that fits between your car stereo ant. o …"  Read Full Review »
Jun 19 2008
Atomik the Squirrel
Northford, CT
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
