SIRIUS Satellite Radio Starmate 5
4.3
based on 15 reviews
from
Ratings Distribution
5 star
9
4 star
4
3 star
0
2 star
2
1 star
0
Category Average
4.3
More Images
Pros
  • Clear display (13)
  • Easy to use (12)
  • Attractive design (11)
  • Easy to install (10)
  • Portable (10)
  • Reliable reception (8)
See less See more
Cons
  • Poor reception / weak antenna (3)
  • Fm transmitter weak (1)
  • Hard to install (1)
  • Hard to see display (1)
Best Uses
  • Car (13)
  • Music (12)
  • Travel (10)
  • Sports (7)
  • Talk shows (7)
  • News (6)
  • Boat (1)
  • Home stereo (1)
Provided by RadioShack
Make your drive more enjoyable with an ultra-compact receiver specifically designed for today's vehicles.
Specification Description
Model ST5TK1R
Battery Type Remote
Benefits Easy-to-read, six-line display simultaneously shows channel, category, Song title and moreGame Alert prompts you when favorite sports
Built-in Clock Digital clock
Capacity UOM mAh
Channels 120 Channels
Chemistry Lithium
Connections Satellite antenna in (1)FM antenna in (1)Aucio in 1/8" (1)
Controls Menu, display, memo, rewind, play/pause, fast forward, select, power, channel up/down, category previous/next, presets (0-9), band, jump, FM preset
Controls / Adjustments Brightness, contrast
Country Of Origin China
Description Header All radio is not created equal.
Display Catalog Number 12-491
Display Information Artist, song title, channel information
Enclosure Color Black
End Product Indicator Yes
Included in the Box SIRIUS Starmate™RF remote controlVehicle dockSuction cup mountVent mountVehicle power adapte
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model ST5TK1R
New Date Sun Dec 21 00:00:00 CST 2008
Operating Temperature UOM ° F
Product Depth 0.6
Product Dimensions UOM inches
Product Height 2.5
Product Type Receivers & tuners
Product Weight 3.7
Product Weight UOM pounds
Product Width 4.5
Radio Frequency Range 88.1-107.9
Size Coin Cell
Supported Languages English
Technology RF
Type LCD
Voltage 3
Voltage Required 12V DC
Voltage UOM Volts
SIRIUS Satellite Radio Starmate 5 Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Starmate 5
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 27, 2009
SIRIUS Satellite Radio Starmate 5 Reviews
Most helpful positive review
[6 of 6 customers found this review helpful]
Most helpful negative review
[0 of 6 customers found this review helpful]
5.0
Buy this one - it's cheaper overall
"BUY THIS ONE!!! This is currently the only Sirius radio that can use the a la carte plan. Don't waste your money on channels you will never listen to. The a la carte plan is only $6.95 a month, and gives you 50 channels OF YOUR CHOOSING (more channels are only a few cents more each)! Why spend twice as much to get a whole bunch of channels that don't appeal to you? Why give Sirius more of your hard-earned m..." Read Full Review »
Mar 06, 2009 by JEK3
See more positive SIRIUS Satellite Radio Starmate 5 reviews
2.0
BAD RECEPTION
"THE RECEPTION IS HORRIBLE. WAY TOO MUCH STATIC & I'M USING BOTH ANTENNAS..." Read Full Review »
Mar 19, 2009 by GATOR
See more negative SIRIUS Satellite Radio Starmate 5 reviews
Displaying 1 - 5 of 15 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
    Cons
  • None
    Best Uses
  • Car
  • Music
"BUY THIS ONE!!! This is currently the only Sirius radio that can use the a la carte plan. Don't waste your money on channels you will never listen to. The a la carte plan is only $6.95 a month, and gives you 50 channels OF YOUR CHOOSING (more channels are only a few cents more each)! Why spend t …"  Read Full Review »
Was this Satellite Radio review on the SIRIUS Satellite Radio Starmate 5 helpful to you?
 Report Abuse  (6)  (0)  0 comments
Mar 6 2009
JEK3
Fredericksburg, VA
I am:
  • Professional
Reviewed at:
[1 of 1 customers found this review helpful]
Worth every penny
4.0
    Pros
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
  • Reliable Reception
    Cons
  • FM transmitter weak
    Best Uses
  • Car
  • Music
  • News
  • Sports
  • Talk Shows
  • More »
"Well worth the money. Has the ability to play a select amount of XM stations for a few buck more a month. Tracks your favorite sport, teams, car drivers with visual and audio alerts. 30 favorite channel memory locations. Different display modes, view either list of stations, artists on each channe …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 18 2009
hansjer
Palmerton, PA
I am:
  • Tech Savvy
Reviewed at:
BAD RECEPTION
2.0
    Pros
  • Portable
    Cons
  • Poor Reception
    Best Uses
  • Car
  • Music
  • Talk Shows
"THE RECEPTION IS HORRIBLE. WAY TOO MUCH STATIC & I'M USING BOTH ANTENNAS "
2ND FROM THE RIGHT-"MEMPHIS".COUNTRY & OLDIES.
2ND FROM THE RIGHT-
 Report Abuse  (0)  (6)  0 comments
Mar 19 2009
GATOR
SPRINGFIELD, NJ
I am:
  • MUSICIAN
Reviewed at:
Poor reception
2.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Easy To Use
    Cons
  • Poor Reception
    Best Uses
  • Car
  • Home stereo
  • Music
  • News
  • Talk Shows
  • More »
"MUCH more static than my old Sportster, even with second antenna. Would recommend only if you use it with an auxiliary plug into radio or have it professionally installed, if you live in an urban area with much of the dial occupied with FM stations. I have stock radio on Focus. Works better connecte …"  Read Full Review »
Aug 27 2009
CG
Tacoma, Washington
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Outstanding
5.0
    Pros
  • Attractive Design
  • Clear Display
  • Easy To Install
  • Easy To Use
  • Portable
  • More »
    Cons
  • None
    Best Uses
  • Car
  • Music
  • News
  • Sports
  • Talk Shows
  • More »
"Well for the goofy people sayin the reception is not good they need to have it profesionaly installed..the reason for the poor reception is the person hookin it up didnt read the instruction,s...I never had one pulled it out of the box within 30 min,s i had it working clear as a bell. "
Mar 29 2009
Trucker
middletown,ohio
I am:
  • Technically Challenged
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
