Sima Products Corporation CK-2 Lens Cap keeper leash (Cap to lens)
4.3
based on 186 reviews
Ratings Distribution
5 star
119
4 star
37
3 star
15
2 star
5
1 star
10
Category Average
4.2
Low Price:
$0.99 at ClubMac
 Trusted:
$2.25 at B&H Photo Video
$0.99 at OnSale
see all stores
$0.99 - $2.25
from 6 stores
More Images
Pros
  • Easy to use (132)
  • Lightweight (116)
  • Durable (81)
  • Reliable (53)
  • Improves function (41)
  • Compact (16)
  • Cheap (3)
  • Affordable (2)
  • Consistent reactions (2)
  • Convenient (2)
See less See more
Cons
  • Flimsy (8)
  • Not durable (8)
  • Not functional (6)
  • Difficult to use (4)
  • Heavy / bulky (3)
  • Poor design (2)
  • A tad short (1)
  • Adhesive is weak (1)
  • Could be stronger (1)
Best Uses
  • Everyday (119)
  • Travel (69)
  • Landscapes (21)
  • Macro (17)
  • Home (16)
  • Photography (13)
  • Sports/action (13)
  • Portraits (11)
  • Studio (8)
  • Active pursuits (1)
Provided by CameraWorld.com
Ever forgotten to put the lens cap back on your lens and then walked off without it? This tidy cap keeping system will solve that problem and is especially designed for those of us with more than one lens.
An elastic band fits around the barrel of the lens and is connected by a short string to a small plastic disc that is glued to the lens cap. Remove the cap and simply let it dangle below the lens.
Sima Products Corporation CK-2 Lens Cap keeper leash (Cap to lens) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Sima Products Corporation CK-2 Lens Cap keeper leash (Cap to lens) Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
[4 of 6 customers found this review helpful]
4.0
Does the job!!
"I have nikon SLR with various lenses. The lens cap holder makes it easy to just remove the cap and start taking pictures. I don't have to keep looking around for the cap. I have yet to see how long the adhesive stays on the cap from the cap holder, but so far it seems like a good way from losing the lens caps...." Read Full Review »
Jan 09, 2008 by Molardaddy
See more positive Sima Products Corporation CK-2 Lens Cap keeper leash (Cap to lens) reviews
2.0
Not All That I Hoped For
"I purchased three of these lens cap leashes, one for each of the three Nikkor lenses that I use on my Nikon D80 - 50mm f/1.8D, 18-55mm f/3.5-5.6G & 70-300mm f/4.5-5.6G. However, one of the leashes was defective on arrival. The adhesive button that adheres to the lens cap is equipped with a string which is joined to an elastic band byway of a crimped metal clasp. When I was adjusting the elastic band around the 7..." Read Full Review »
Jan 21, 2009 by RGB
See more negative Sima Products Corporation CK-2 Lens Cap keeper leash (Cap to lens) reviews
Displaying 1 - 5 of 186 Reviews
Show
Sort by
Junk
1.0
    Pros
  • None
    Cons
  • Not Durable
  • Not Functional
  • Poor Design
    Best Uses
  • none
"I tried the CapKeeper and all that happened was it bumped and banged the lens cap on everthing around me. Loud and distracting banging. Put the cap in your front pocket, it's better and free.
Imagine a lens cap dangling 2 feet below your camera, flopping all over the place as you move around! "
Was this Camera Accessory review on the Sima Products Corporation CK-2 Lens Cap keeper leash (Cap to lens) helpful to you?
Nov 10 2009
Gizmo
Manchester, CT
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $2.25
Great idea
5.0
    Pros
  • Durable
  • Easy To Use
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Everyday use
  • Home
  • Landscape Photography
  • Macro Photography
  • Portraits
  • More »
"I have always been a big fan of these, easy to use, slip it on and forget it never loose your lens cap. I recommend them to everyone. "
Nov 10 2009
Imaginique
Plymouth, MA
I am:
Reviewed at:
Price: $2.25
2.0
    Pros
  • Easy To Use
    Cons
  • Bulky
  • Not Durable
    Best Uses
  • None
"I purchased three of these lens cap leashes, one for each of the three Nikkor lenses that I use on my Nikon D80 - 50mm f/1.8D, 18-55mm f/3.5-5.6G & 70-300mm f/4.5-5.6G. However, one of the leashes was defective on arrival. The adhesive button that adheres to the lens cap is equipped with a string wh …"  Read Full Review »
 Report Abuse  (4)  (2)  0 comments
Jan 21 2009
RGB
Chicago
I am:
Reviewed at:
Price: $2.25
Wish there was another way to do this.
2.0
    Pros
  • Lightweight
    Cons
  • Not Durable
  • Poor Design
    Best Uses
  • Traveling
"Needed a functional way to hold a cap without having to hold it in your hand. First cap keeper separated at the attaching point and had to be reglued. Second cap keeper's elastic stretched out. Elastic slides along lens and gets caught. Works great if you aren't using the camera! "
Nov 16 2009
Bev
Pittsburgh
I am:
Reviewed at:
Price: $2.25
talk about value!
5.0
    Pros
  • Durable
  • Easy To Use
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Everyday use
  • Traveling
"For something that is practically free, this is a pretty amazing thing! I have one on all my lenses. The cap stays attached without having to worry about putting it in a pocket or carrying it in your hand. The only way I can imagine having a lens without one is if I buy a pancake or a lens otherwise …"  Read Full Review »
Nov 3 2009
rocdoc
Washington, DC
I am:
Reviewed at:
Price: $2.25
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
