Sherwood 4-Channel 100W Stereo Receiver (Model #RX-4109)
#115
4.7
based on 6 reviews
from $146.47 - $179.00
Ratings Distribution
5 star
4
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.3
More Images
Pros
  • Accurate controls (6)
  • Easy setup (6)
  • Great sound quality (6)
  • Good power output (5)
  • Durable (4)
  • Has phono input (1)
  • Versatile (1)
See less See more
Cons
  • Nothing i can think of (1)
Best Uses
  • Basic systems (5)
  • Smaller rooms / apartments (3)
  • Home theater (1)
  • Multiple rooms / whole house (1)
  • Office for two zones (1)
  • Whole home audio (1)
Provided by Kmart
Rated At 100W Rms X 2 With Less Than 0.20% From 20 Hz 20 Khz Into 8 100W X 4 In Multi-Room Mode 25-Key Unified Remote Switch 4 Pairs Of Loudspeakers From The Front Panel Or Via Remote 5 Audio Inputs Including Phono And Tuner Multi-Source, Dual-Zone Capable For Use As Free-Standing Unit Or As A Zone 2/3 Receiver/Amplifier Bass And Treble Tone Controls Totally Discrete Amplifier Stage (Tdas) Quartz Pll Synthesized Digital Tuning Preset Scan 30 Randomly Preset Stations Digital Encoder Volume Control System Illumination Sleep Timer Dim: 5"H X 17.375"W X 13"D
Specification Description
Model RX-5502, RX5502
UPC 093279453943
# of AM/FM Tuner Presets 30
AM/FM Radio Yes
Audio Response Bandwidth 20Hz~20kHz
Battery Type Remote
Benefits Supports 100 watts RMS per channel with no more than 0.2% THD from 20 Hz to 20 kHz into 8 ohmsFeatures five audio inputs, including p
Capacity UOM mAh
Channels 4 Channels
Chemistry Alkaline
Connections Headphone 1/4" (1)FM antenna (1)AM antenna (1)Phone RCA (1)CD RCA (1)Aux RCA (2)DVD anal
Country Of Origin China
Description Header When it's the music that matters.
Display Catalog Number 55031854
Enclosure Color Black
End Product Indicator Yes
Included in the Box Sherwood RX-4109 stereo receiverRemote control"AAA" batteries (2)FM wire antennaAM loop antennaUs
Manufacturer Labor Warranty 12
Manufacturer Part Number RX-5502
Manufacturer Parts Warranty 12
MAP Price 0.0
Model RX-5502
Operating Temperature UOM ° F
Output Power / Total 400 watts
Product Depth 14.5
Product Dimensions UOM inches
Product Height 17.5
Product Type Amplifiers
Product Weight 21
Product Weight UOM pounds
Product Width 5.5
Size AAA
Supported Languages English
Technology IR
Total Harmonic Distortion 0.05 %
Type LED
Voltage 1.5
Voltage UOM Volts
Sherwood 4-Channel 100W Stereo Receiver (Model #RX-4109) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Mar 18, 2009
Sherwood 4-Channel 100W Stereo Receiver (Model #RX-4109) Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
Outstanding for this low price
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Easy To Set Up
  • Good Power
  • Has phono input
    Cons
  • None
    Best Uses
  • Basic Systems
  • Smaller Rooms
"This has a phono input, a must, and very rare, especially at this price. Sound is clean, noise-free, good output from low bass to high end. Controls pretty obvious and easy to use.
A few minor annoyances: It doesn't power up directly, but goes into standby & I have to push a separate standby bu …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Sherwood 4-Channel 100W Stereo Receiver (Model #RX-4109) helpful to you?
Feb 1 2008
The Old Listener
Eastern MA
I am:
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Works as advertised and then some!
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
  • More »
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
  • Smaller Rooms
"I have a four room setup: living room (main), kitchen, bathroom, and backyard.Works perfectly in all or separate configurations with a minimal loss in the backyard speakers with the all on configuration, but probably due to cable run and not the unit itself.Setup was easy though banana post configur …"  Read Full Review »
Oct 16 2008
Pat
Union, NJ
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Great Receiver, Great Value
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Basic Systems
  • Whole Home Audio
"Superb receiver for what it's designed for. Rather unique features with 4 stereo channels! Simple/Basic operation with nice quality speaker cabling connectors. All in all, probably the best value out there in a basic receiver with more than the normal amount of channels. "
Oct 14 2007
Rod
West Melbourne, FL
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Great Receiver!
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Whole House Surround
"I use this receiver to run four sets of speakers in my home (Living Room, Kitchen, Dining Room and Outside) and it's perfect. It's easy to set up and provides good sound to all rooms. It's ideal for whole house surround and the price is right. "
Mar 18 2009
Joe
Omaha, NE
I am:
  • Practical
Reviewed at:
Practical Price and Very Useful
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Easy To Set Up
  • Good Power
    Cons
  • Nothing I can think of
    Best Uses
  • Basic Systems
  • Smaller Rooms
"I am using this for a two zone office system with ceiling speakers. This little receiver is perfect and easy to use and practically priced. "
Nov 13 2008
Dylan Head
Chattanooga, TN
I am:
  • Audiophile
  • Professional
  • Tech Savvy
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
