Sherwood 200 Watt Stereo Receiver (RX-4105)
#296
3.9
based on 39 reviews
from $89.00 - $228.80
Ratings Distribution
5 star
13
4 star
16
3 star
3
2 star
3
1 star
3
Category Average
4.3
More Images
Pros
  • Easy setup (26)
  • Great sound quality (25)
  • Good power output (21)
  • Accurate controls (19)
  • Durable (15)
  • Easy to install (3)
  • Simple / intuitive controls (3)
  • Attractive design (2)
  • Good price / value (2)
  • Nice features (2)
See less See more
Cons
  • Limited functions (6)
  • Lack of power (4)
  • Difficult to set up (1)
  • Lack of subwoofer connect (1)
  • Limited features (1)
  • No mono out (1)
  • No surround sound feature (1)
  • Not dependable (1)
  • Not enough connection options (1)
Best Uses
  • Basic systems (22)
  • Smaller rooms / apartments (10)
  • Large rooms (9)
  • Home theater (8)
  • Audiophiles (6)
  • Home (2)
  • Radio (2)
  • Everyday (1)
  • Multiple cd's (1)
  • Old school stereo suround (1)
Provided by CameraWorld.com
The Sherwood RX-4105 100 Watt Stereo Receiver. In our modern, surround sound driven audio universe where home theater enthusiasts hear airplanes fly overhead and bombs exploding around them, one might think that mere Stereo is old fashioned. But don't be mislead — humans have only two ears and stereo is still a significant life form. Our case in point: the RX-4105. It's actually an update of our market leading RX-4100/4103. rated at 100 watts, we've reduced distortion significantly. It's now less than 0.20% from 20 Hz to 20 kHz and we've improved the reliability with a new layout borrowed from our higher end models. The RX-4105 has a good AM/FM tuner with the ability to pre-set up to 30 favorite stations. It has inputs for 4 audio sources to accommodate your sound gear. And the sound is phenomenal — as you'd expect from a company that dates its own existence to before stereo's birth. And the RX-4105 has at least one unexpected grace: the ability to independently select up to two sets of loudspeakers via the supplied remote control. (Audio purists will be pleased to know that this relay-controlled switching puts the speakers in parallel, maintaining their individual sound qualities.)
Specification Description
Model RX-4105, RX4105, SHDRX4105
UPC 093279441766
# of AM/FM Tuner Presets 30
Accessory Indicator Yes
AM/FM Radio Yes
Audio Input Tape, Tuner, VCR, CD
Audio Response Bandwidth 20-20000Hz
Benefits Supports 100W RMS per channel with no more than 0.08% THDAllows for remote switching for 2 pairs of loudspeakers (in parallel)
Capacity UOM mAh
Connectivity Technology Wired
Controls Bass, treble
Country Of Origin China
Description Header Solid and dependable.
Display Catalog Number 55022697
Features Totally Discrete Amplifiers (TDAS) provided for all channelsBass and treble tone controls allow you to select the perfect balance for
Included in the Box ReceiverRemote control
Input Impedance 8 ohms
Manufacturer Labor Warranty 2
Manufacturer Part Number RX-4105
Manufacturer Parts Warranty 2
MAP Price 0.0
Model RX-4105
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 4.875
Product Length 14
Product Type A/V receivers
Product Weight 21
Product Weight UOM pounds
Product Width 17.375
Speakers Included 0 Speakers
Supported Languages English
System Components 1 Speakers
Timer Sleep
Total Harmonic Distortion 0.08 %
Sherwood 200 Watt Stereo Receiver (RX-4105) Questions
Questions and Answers
Where to Buy
$89.00
$99.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$89.26
Shop CameraWorld with FREE Shipping/No Sales Tax! ends 12/31/99
Show all 10 stores
_
Product Reviews
Last update: Nov 14, 2009
Sherwood 200 Watt Stereo Receiver (RX-4105) Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
[3 of 4 customers found this review helpful]
5.0
"Don't judge a book by it's price"
"I bought this unit to replace a 20 year old Radio Shack Stereo amp that is no longer available. I use it mainly to amplify my TV audio. I also like the AM-FM tuner, that receives alot of stations, with the included antennas. I have 2 sets of speakers hooked up, & like the A & B switching. I have 2 speakers on the top shelf next to the amp & 2 on the floor. It really sounds like a home theater system, without the..." Read Full Review »
Dec 06, 2007 by Goldenrod
See more positive Sherwood 200 Watt Stereo Receiver (RX-4105) reviews
3.0
You get what you pay for...
"Good value for the money. Plenty of volume with efficient speakers. Construction quality is adequate (China). Engineering is poor (U.S.). Heat sink for power amp is internal, entire top of cabinate is perforated for ventilation. Make sure you put down your drink before standing near this receiver! Allow plenty of room above for ventilation, or you will cook this unit. Radio reception is adequate. Connectivity is..." Read Full Review »
Jun 25, 2008 by The Grey Ghost
See more negative Sherwood 200 Watt Stereo Receiver (RX-4105) reviews
Displaying 1 - 5 of 39 Reviews
Show
Sort by
Excellent Value
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Basic Systems
"[...] It was extremely easy to set up(I just use it for my CD player and the AM/FM radio.) I saw in several other reviews complaints about the radio reception.I found no fault at all. I live 30-40 miles from the city and there are lots of hills between me and it and have had troubles with other rece …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Sherwood 200 Watt Stereo Receiver (RX-4105) helpful to you?
Nov 10 2009
cowboy22
Spring Branch, Tx.
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $89.00
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
  • More »
    Cons
  • No input for a turntable
    Best Uses
  • Audiophiles
  • Basic Systems
  • Home Theater
  • Smaller Rooms
  • TV
"I bought this unit to replace a 20 year old Radio Shack Stereo amp that is no longer available. I use it mainly to amplify my TV audio. I also like the AM-FM tuner, that receives alot of stations, with the included antennas. I have 2 sets of speakers hooked up, & like the A & B switching. I have 2 s …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Dec 6 2007
Goldenrod
LaPorte, IN
I am:
  • Musically Inclined
  • Practical
Reviewed at:
Price: $99.99
Great low cost LFE amp
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • none at this price level
    Best Uses
  • Audiophiles
  • Basic Systems
  • Home Theater
  • Larger Rooms
  • Smaller Rooms
"I've used 3 receiver amplifiers in the past year with this one able to rival the 20+ year old monster Sanyo amp that I had hooked up. When coupled with an eq it produces LFE sound reproduction below 63hz very accurately. Bass is tight and omni directional. Any one looking for a budget solution for a …"  Read Full Review »
Jan 27 2008
Bryan
Vine Grove, Kentucky
I am:
  • Tech Savvy
Reviewed at:
Price: $99.99
Only worth [$]
2.0
    Pros
  • Accurate Controls
  • Easy To Set Up
    Cons
  • Poor Sound
  • Weak
    Best Uses
  • Basic Systems
  • Smaller Rooms
"I thought 100 watts would be enough to give a good sound but there was NO decent bass!My old Pioneer gave a MUCH better bass response.It is a nice receiver BUT if you don't need a good bass response than this might be a good receiver for you. It is only worth [$].I returned the receiver and started …"  Read Full Review »
Nov 21 2009
Steve
Huntingdon Valley, PA
I am:
  • Tech Savvy
Reviewed at:
Price: $99.99
3.0
    Pros
  • Easy To Set Up
  • Good Power
  • Handsome Unit
  • Phono PreAmp
  • Remote Control
  • More »
    Cons
  • Limited Features
  • Poorly Engineered
  • Requires Open Shelf
  • Runs hot
    Best Uses
  • Basic Systems
  • Smaller Rooms
"Good value for the money. Plenty of volume with efficient speakers. Construction quality is adequate (China). Engineering is poor (U.S.). Heat sink for power amp is internal, entire top of cabinate is perforated for ventilation. Make sure you put down your drink before standing near this receiver! A …"  Read Full Review »
 Report Abuse  (3)  (1)  0 comments
Jun 25 2008
The Grey Ghost
Long Island, N.Y.
I am:
  • Audiophile
Reviewed at:
Price: $99.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
