Close Login Module
Join
Sherwood 200-Watt High Current Stereo Receiver (RX-4109)
3.7
based on 93 reviews
Ratings Distribution
5 star
37
4 star
31
3 star
4
2 star
6
1 star
15
Category Average
0.0
$99.99 - $148.66
from 3 stores
More Images
Pros
  • Easy setup (53)
  • Clean sound (52)
  • Good power (48)
  • Accurate controls (42)
  • Durable (32)
  • Easy to use (13)
  • Good sound quality (10)
  • Easy to install (7)
  • Good value (7)
  • Safe (4)
See less See more
Cons
  • Limited functions (14)
  • Weak (4)
  • Poor sound (3)
  • Difficult to set up (2)
  • Bad impedence (1)
  • Broke in less than a year (1)
  • Could be more compact (1)
  • Cutsoff (1)
  • Difficult to use (1)
Best Uses
  • Basic systems (55)
  • Smaller rooms (33)
  • Larger rooms (15)
  • Audiophiles (11)
  • Home theater (10)
  • Inside (5)
  • Small jobs (3)
  • At home non-critical use (1)
  • Audio streaming (1)
  • Basic amp (1)
Where to Buy
$99.99
$139.00
$148.66
Product Reviews
Last update: Oct 22, 2009
Sherwood 200-Watt High Current Stereo Receiver (RX-4109) Reviews
Most helpful positive review
[9 of 9 customers found this review helpful]
Most helpful negative review
4.0
Very Cheap, But Surprisingly Very Good
"I’m an old audiophile, dating back to when “MacIntosh” was not the name of a computer. It was the name of the most prestigious of hi-fi components. What dismays me is that today’s manufacturers of audio equipment (some of them well known brands) rely on the ignorance of the consumer when it comes to audio specifications; and they can get away with it because there no longer seems to be any standards (IHSF) for t..." Read Full Review »
Oct 11, 2008 by drdos43
See more positive Sherwood 200-Watt High Current Stereo Receiver (RX-4109) reviews
1.0
Weak, get what you pay for
"I do not even feel safe with this item in my house, so much so i keep in unplugged from the wall when not in use, heres why; Amp number one = 2 months old, in the middle of watching a movie, with a moderate volume a stange smell came out of it. then POOF a large spark and smoke came out, then power would shut off. - It got sent away for 6 weeks, was unable to repair. so it was replaced under warranty. AMP NUMBER..." Read Full Review »
Sep 11, 2009 by Big topsy
See more negative Sherwood 200-Watt High Current Stereo Receiver (RX-4109) reviews
Displaying 1 - 5 of 93 Reviews
Show
Sort by
4.0
    Pros
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Exceptional Value
  • Good Power
    Cons
  • Limited Functions
  • Manual for Novice
    Best Uses
  • Audiophiles
  • Basic Amp
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"I’m an old audiophile, dating back to when “MacIntosh” was not the name of a computer. It was the name of the most prestigious of hi-fi components. What dismays me is that today’s manufacturers of audio equipment (some of them well known brands) rely on the ignorance of the consumer when it comes to …"  Read Full Review »
Was this review on the Sherwood helpful to you?
 Report Abuse  (9)  (0)  0 comments
Oct 11 2008
drdos43
San Antonio, TX
I am:
  • Audiophile
  • Musically Inclined
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Price: $99.99
[5 of 5 customers found this review helpful]
Great sound and construction on a budget
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"This receiver is one of the bangs for the buck for any hi-fi enthusiast. For such a low price, you can get sound quality that rivals most home theater systems that cost much more money. Less is definitely more in this case. The discrete amplification really helped improve the sound quality of wel …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Nov 24 2007
Bradley Olson
Bemidji, Minnesota USA
I am:
  • Audiophile
  • Practical
  • Professional
  • Tech Savvy
  • Technically Challenged
Reviewed at:
Price: $99.99
Good amplifier but radio is only fair
4.0
    Pros
  • Easy to Install
  • Has phono input
  • Sounds good
    Cons
  • FM Tuner overloads
  • Radio tuning confussing
    Best Uses
  • Big Jobs
  • Inside
  • Small Jobs
"I use the receiver in a stereo system containing a CD changer, Ipod, and a turntable. The amplifier section is easy to use, works well and sounds good.
The tuner section however is only fair. I live within 3 miles of two TV transmitter which overload the FM front end when connected to …"  Read Full Review »
Oct 22 2009
Jerry
San Diego, CA
I am:
  • Avid Do-It-Yourselfer
Reviewed at:
[2 of 2 customers found this review helpful]
Follow up
5.0
    Pros
  • Clean Sound
  • Easy To Set Up
  • Flexible controls
  • Great sound for any price
  • Unbelieveable Tuner
    Cons
  • None at this price
    Best Uses
  • Two ChannelStereo
"As a follow up, I couldn't resist commenting, once again, on the quality of the tuner in this admittedly budget receiver. Using the supplied antenna (this is recommended), with proper positioning, I am pulling in stations from as far as 60 miles away--including stations that I could not retrieve w …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Aug 3 2007
Todd C.
Indiana
I am:
  • Music Lover
Reviewed at:
Price: $99.99
[4 of 4 customers found this review helpful]
Excellent Replacement Receiver
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Basic Systems
  • Smaller Rooms
"Had to replace a receiver that finally died... powering two sets of old bookshelf speakers. This was perfect. In 20 minutes I had it hooked up and had half a dozen presets programmed. They don't advertise the remote control very well but it seems to have everything on it and is easy to operate. T …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Apr 29 2008
Frank of the North
Minnesota
I am:
  • Practical
Reviewed at:
Price: $99.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
