Sharp LC-60E77UN 60-inch 120Hz 1080p LCD HDTV
#136
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
$1,995.18 - $2,699.98
from 16 stores
More Images
Pros
  • Attractive design (1)
  • Bright image (1)
  • Fast setup (1)
  • Good connection options (1)
  • High resolution (1)
  • Simple controls (1)
See less See more
Best Uses
  • Home (1)
  • Home theater (1)
  • Movies (1)
  • Wall mounting (1)
Provided by OneCall
Full HD 1080p (1920 x 1080) Resolution for the sharpest picture possible.
10-Bit ASV Superlucent LCD Panel from Sharp’s state-of-the-art Kameyama factory for a more lifelike picture, truer blacks, reduced reflection and fast response time.
120Hz Fine Motion Enhanced for fast-motion picture quality.
Spectral Contrast Engine XD for unrivaled deep blacks and delicate contrast management.
Active Contrast – Dynamic range extension based on advanced real-time picture analysis for greater sense of depth.
Active Color picture processing results in rich color, especially in bright scenes.
Wide Viewing Angles (176°H x 176°V) Sharp's AQUOS® LCD TVs’ viewing angles are so wide, you can view the TV clearly from practically anywhere in the room.
AQUOS LINK™ enables convenient control of AQUOS Blu-ray Disc™ players.
High Brightness (450 cd/m2) AQUOS LCD TVs are very bright. You can put them virtually anywhere – even near windows, doors or other light sources – and the picture is still vivid.
Built-in ATSC / QAM / NTSC Tuners provide access to DTV and analog TV channels.*1
Six 1080p Compatible Inputs including four HDMI™ inputs (v 1.3 with Deep Color) and two HD component inputs.
OPC (Optical Picture Control) automatically adjusts brightness to suit room lighting.
Specification Description
Model LC-60E77UN, LC60E77UM, LC60E77UN
UPC 074000372108
Aspect Ratio 16:9
Brightness 450 cd/m2
Component Video (2) Rear Input
Composite Video (2) Rear Input
DB15 (PC Video) (1) Rear Input
Depth (Inches) 17.6
Energy Star Compliant Yes
HDMI (4) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Height (Inches) 37.4
Refresh Frequency 120 Hz
Resolution 1920 x 1080
Response Time 4ms
RS-232C (1) Rear Input
S-Video (1) Rear Input
Screen Size (inches) 60
Speakers 10 Watts x 2
Speakers Built-in
Stand Included
Tuner ATSC
Tuner NTSC
Tuner QAM
Viewing Angle 176 degrees Horizontal
Viewing Angle 176 degrees Vertical
Weight (Pounds) 92.6
Width (Inches) 56.6
Sharp LC-60E77UN 60-inch 120Hz 1080p LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 3, 2009
Sharp LC-60E77UN 60-inch 120Hz 1080p LCD HDTV Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Sharp LC60E77UN
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"TV is paired with Bose 16 speaker system, Denon 2310 AV reciver, Oppo blu-ray player and Verizon DVR. Outstanding image, easy setup, looks great. Some glare from the screen from bright light sources. Screen resolution is so good that it's apparent if programming was shot on tape or film. "
Was this LCD TV review on the Sharp LC-60E77UN 60-inch 120Hz 1080p LCD HDTV helpful to you?
 Report Abuse  (1)  (0)  0 comments
Nov 3 2009
Hugh Otto Dewitt
Virginia Beach, VA
I am:
  • Enthusiast
Reviewed at:
Price: $1,995.18
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
