Sharp 46" Class Full HD 1080p LCD HDTV with Digital Tuner (Model #LC46SB54U)
#440
4.4
based on 60 reviews
Ratings Distribution
5 star
41
4 star
11
3 star
2
2 star
4
1 star
2
Category Average
4.4
Low Price:
$749.99 at MacMall
 Trusted:
$829.99 at Adorama
$749.99 at ClubMac
see all stores
$749.99 - $1,309.00
from 5 stores
More Images
Pros
  • Attractive design (2)
  • Fast setup (2)
  • Good connection options (2)
  • Reduced glare (2)
  • Bright image (1)
  • High resolution (1)
  • Simple controls (1)
See less See more
Cons
  • Dull image (1)
  • Poor 75001 dynamic (1)
Best Uses
  • Home (1)
  • Movies (1)
Provided by OneCall
The new LC-46SB54U Full HD 1080p LCD TV provides a slim, versatile high-definition television solution with a distinctive design. It features a high-performance ASV LCD panel for high brightness, a 7500:1 Dynamic Contrast Ratio, low-reflection glare protection and wide viewing angles.
  • Full HD 1080p (1920 x 1080) ASV LCD Panel displays 16:9 widescreen programs in their native aspect ratio without the need for scaling or other video processing.
  • Built-in ATSC / QAM / NTSC Tuners for DTV and analog TV viewing.
  • High Brightness (450 cd/m2) Sharp`s LCD TVs are very bright, so you can put them virtually anywhere – even near windows, doors or other light sources – and the picture is still vivid.
  • 2 HDMI(TM) Inputs for convenient connection to digital devices.
  • 176 degrees Viewing Angles are so wide you can view Sharp LCD TVs from virtually anywhere in the room!
  • 60,000-Hour Lamp Life: Sharp's LCD backlight life is long enough to give you viewing pleasure for many years.
  • 7500:1 Dynamic Contrast Ratio provides incredible images whether you're watching dark or bright scenes!
  • 6ms Response Time ensures you will enjoy fast-motion video without blurring or delay.
  • PC Input conveniently turns your TV into a PC monitor.
  • Specification Description
    Model LC-46SB54U, LC46SB54U
    UPC 074000370876
    Analog Audio (4) Rear Input
    Aspect Ratio 16:9
    Brightness 450 cd/m2
    Color Black Cabinet
    Compatible Formats 1080p
    Compatible Formats 480p
    Compatible Formats 720p
    Component Video (2) Rear Input
    Composite Video (3) Rear Input
    Contrast Ratio 1,500:1
    Contrast Ratio 1500:1
    Contrast Ratio (Dynamic) 7,500:1
    Depth (Inches) 12.8
    Dynamic Contrast Ratio 7500:1
    HDMI (2) Rear Input
    HDTV HDTV Tuner Built In
    HDTV Capable HD Tuner is included
    HDTV Native Resolution 1080p
    Height (Inches) 29.9
    Lamp Life (hours) 60000
    Ports 2 x RCA Component Video In Rear
    Refresh Frequency 60 Hz
    Resolution 1920 x 1080
    Screen Format 16:9 Widescreen TV Imaging
    Screen Size 41" to 49"
    Screen Size 46"
    Screen Size (inches) 46
    Screen Size (Inches/Diagonal) 46
    Select LCD Units
    Speakers 10 Watts x 2
    Speakers Built-in
    Stand Included
    Stand Pedestal
    Technology HDTV
    Tuner ATSC
    Tuner NTSC
    Tuner QAM
    TV Manufacturer’s Warranty (Labor) 90 Days
    TV Manufacturer’s Warranty (Parts) 1 Year
    Viewing Angle 176 degrees Horizontal
    Viewing Angle 176 degrees Vertical
    Wall Mountable Yes
    Weight (Pounds) 61.7
    Width (Inches) 43.4
    Sharp 46" Class Full HD 1080p LCD HDTV with Digital Tuner (Model #LC46SB54U) Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Aug 17, 2009
    Sharp 46" Class Full HD 1080p LCD HDTV with Digital Tuner (Model #LC46SB54U) Reviews
    Most helpful positive review
    Most helpful negative review
    [4 of 6 customers found this review helpful]
    5.0
    Not just another generic 5star rating
    "This TV is the real deal. The Colors are Vivid, the Blacks are true blacks. Thats what set this TV apart from the other comparable TVs in its class. The TV is the fall '08 upgrade of the LC46SB54U which has 4.3 out of 5 stars on its rating. Except they increased its connectability and contrast ratio to 10,000:1 "I love fact that the TV has a USB input so you can update your set with the newest software updates..." Read Full Review »
    Dec 01, 2008 by HonestFamilyMan
    See more positive Sharp 46" Class Full HD 1080p LCD HDTV with Digital Tuner (Model #LC46SB54U) reviews
    3.0
    good for price but thats it
    "The picture quality on the dynamic 7500:1 contrast is very poor and the color is way off and you cant adjust it. the other picture settings are o.k.. for the price . Any thing on Blu Ray looks great as well as PS3 and Xbox360. Analog signals look good. I could not find any info on the contrast ratio on the other settings the owners manual doesntstate any contrast numbers only the 7500:1 for dynamic. there is als..." Read Full Review »
    Jun 27, 2008 by J.B.Hendershot
    See more negative Sharp 46" Class Full HD 1080p LCD HDTV with Digital Tuner (Model #LC46SB54U) reviews
    Displaying 1 - 5 of 60 Reviews
    Show
    Sort by
    3.0
      Pros
    • Attractive Design
    • Fast Setup
    • Good Connection Options
    • Reduced Glare
    • Simple Controls
      Cons
    • Dull Image
      Best Uses
    • Movies
    I could not find any info on the contrast rat …"  Read Full Review »
    Was this LCD TV review on the Sharp 46" Class Full HD 1080p LCD HDTV with Digital Tuner (Model #LC46SB54U) helpful to you?
     Report Abuse  (4)  (2)  0 comments
    Jun 27 2008
    J.B.Hendershot
    lynn Ma
    I am:
    • Gearhead
    • Professional
    • Tech Savvy
    Reviewed at:
    5.0
    The TV is the fall '08 upgrade of the LC46SB54U which has 4.3 out of 5 stars on its rating. Except they increased its connectability and contrast rati …"  Read Full Review »
    Dec 1 2008
    HonestFamilyMan
    Lansing, IL
    [1 of 1 customers found this review helpful]
    Worth Every Penny
    5.0
    "I did alot of research and going over my budget I found this TV to be exactly what I was looking for in a HD LCD TV. This Sharp TV is an absolute compliment to our living room and the picture quality is superb in Blue Ray and HD. The basic channels in 480i are clear and acceptable in non HD format ( …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Jul 7 2008
    ArmyVeteran
    Central, NJ
    Reviewed at:
    a few problems
    4.0
    "I purchased this Sharp 46 inch lcd on Black Friday. The price was great. This is my first experience with an lcd tv and I didn't know quite what to expect. For the most part, I am extrememly pleased with the display. The HD picture is truly amazing. Brightness and contrast are also great. The sound …"  Read Full Review »
    Feb 5 2009
    wwwalzes
    I am a retiree livng in L.A.
    This is a great TV
    5.0
    "I purchased this TV not long ago from Best Buy. I absolutely love it. The picture is incredible when watching movies on my Blu-Ray Disk player or when watching Hi-Def television programming. Especially Hi-Def sports. I've been watching this TV for months and still every time I watch it I marvel at h …"  Read Full Review »
    Oct 20 2008
    Renrag
    San Diego, CA
    Reviewed at:
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
