Sharp 46" AQUOS 1080p LCD Flat Panel HDTV
#343
4.3
based on 9 reviews
Ratings Distribution
5 star
6
4 star
2
3 star
0
2 star
0
1 star
1
Category Average
4.4
$1,166.99 at Overstock.com
Find it at Amazon
Find it at Ebay
$1,166.99
from 1 store
More Images
Pros
  • Attractive design (7)
  • Great picture quality (6)
  • Wide viewing angle (6)
  • Simple controls (5)
  • Fast setup (4)
  • High resolution (3)
  • Good connection options (2)
  • Can watch it for hours (1)
  • Easy to mute commercials (1)
  • Great with blu ray disc (1)
See less See more
Cons
  • Breaks down (1)
Best Uses
  • Movies (7)
  • Home (6)
  • Video (2)
Provided by Beach Audio
Sharp, a long time leader in the LCD market, offers you the perfect way to join the 1080p revolution. The LC-46D92U 46" 16:9 AQUOS HD 1080p LCD Television is a stylish LCD TV, that easily enhances the decor of any family room, living room and den. The world of TVs has shifted to HD and the LC-46D92U offers you a resolution of 1080p which is full HD quality and clarity.With an ultra wide viewing angle of 176, you'll always get great image quality, whether you're sitting directly in front of the TV or off to the side. When you take all this into account, and add their ultra fast response time and their bright, sharp picture, the LC-46D92U is a must have for anyone ready to join the world of 1080p HDTV.
  • 46" widescreen HDTV (16:9 aspect ratio)
  • built-in digital (ATSC) and analog (NTSC) tuners for over-the-air TV broadcasts (antenna required)
  • built-in QAM cable TV tuner receives unscrambled programs without a set-top box (cable service required)
  • Advanced Super View/Black LCD panel (1920 x 1080 pixels)
  • 120Hz Frame Rate Conversion for clearer motion
  • 4-millisecond pixel response time
  • 3000:1 contrast ratio (15,000:1 dynamic)
  • 176(H) x 176(V) viewing angle
  • Multi-Pixel technology for better viewing from the sides
  • 5-Wavelength Backlight System for improved color accuracy and intensity
  • detachable stereo speakers (15 watts x 2)
  • illuminated multibrand remote control
  • picture settings memory for each video input
  • 7 A/V inputs, including: -2 composite video -1 S-video -2 component video (accepts signals up to 1080p) -1 DVI-I video/PC input (accepts signals up to 1080p) -3 HDMI v1.2 digital audio/video inputs (accepts signals up to 1080p)
  • RF input for antenna/cable signals
  • optical digital audio output for Dolby Digital
  • Energy Star compliant
  • detachable stand (stand "footprint" is 26"W x 12-1/4"D)
  • wall-mountable (bracket not included)
  • 44-3/4"W x 28-3/4"H x 4-7/8"D (31-1/4"H x 12-1/4"D on stand)
  • weight: 65 lbs. (without stand)
  • Specification Description
    Model LC-46D92U, LC46D92U
    UPC 074000363885
    Screen Size 41" to 49"
    Select LCD Units
    Sharp 46" AQUOS 1080p LCD Flat Panel HDTV Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Jul 1, 2008
    Sharp 46" AQUOS 1080p LCD Flat Panel HDTV Reviews
    Displaying 1 - 5 of 9 Reviews
    Show
    Sort by
    [1 of 1 customers found this review helpful]
    Sharp LC-46D92U
    4.0
      Pros
    • Attractive Design
    • Great Picture
    • Reduced Glare
      Cons
    • None
      Best Uses
    • Home
    • Movies
    "[...] I immediately unpacked it and set it up. The picture is outstanding connected to my Comcast HD programming thru either component or HDMI cables.I've watched alot of sports on this TV and haven't noticed the pixelation that I've seen in other store demo models - especially during fast panning …"  Read Full Review »
    Was this LCD TV review on the Sharp 46" AQUOS 1080p LCD Flat Panel HDTV helpful to you?
     Report Abuse  (1)  (0)  0 comments
    Mar 13 2007
    phogan
    Odenton, MD
    Reviewed at:
    the LC46D92U is a marvel of technology
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Video
    "It's strange but they made the 82U
    more attractive than the 92U. Looks aren't
    everything though. It's what's inside that counts.
    It has a native contrast ratio of 3,000. to 1.
    The new Feb 24th 2008 LC46SE94U has a ratio
    of 2,700. to 1, so I guess although my 92 is older
    it still may be …"  Read Full Review »
    Mar 8 2008
    Dr Paul
    OTTAWA ONTARIO CANADA
    I am:
    • Couch Potato
    • Practical
    • Technically Challenged
    Reviewed at:
    Mike Norris
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Home
    • Movies
    "I've owned my LC46D92U since Sept 2007 and am
    very happy with it. I'll keep it until I can buy
    a 50 inch OLED for under 2,000.00. That should be in
    about 4 or 5 years. 2013 for sure. The whole TV
    industry will be OLED's within 6 - 7 years. There's
    also laser television in Australia and it's sup …"  Read Full Review »
    Jul 1 2008
    mike the couch potato
    Ottawa Ontario Canada
    I am:
    • Couch Potato
    Reviewed at:
    An out of this world picture
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Good Resolution
    • Reduced Glare
    • More »
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Video
    "We use this tv in a room with lots of windows and there is absolutely no glare from the windows on the screen. Picture is sharp and bright. Black piano frame is very attractive. Took a little time for me to set up , but I'm a novice. "
    May 13 2008
    Savingoak
    minnesota
    I am:
    • Practical
    Reviewed at:
    Glad I waited for the new model.
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Reduced Glare
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    "Fantastic picture and absolutely no banding issues as with the 62u model. Sharp really thought of everything with this new unit.
    Set up was simple and picture adjustments are easy. You've really got to see this beauty. "
    Feb 14 2007
    Captain Kirk
    Fox Lake, IL
    Reviewed at:
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
