Sharp 37-inch AQUOS 1080p LCD Flat Panel HDTV - LC-37D64U
#14
4.7
based on 95 reviews
from $969.00
Ratings Distribution
5 star
63
4 star
31
3 star
1
2 star
0
1 star
0
Category Average
4.4
$969.00 at Rainbow Appliance
Find it at Amazon
Find it at Ebay
More Images
Pros
  • High resolution (89)
  • Great picture quality (83)
  • Attractive design (80)
  • Fast setup (77)
  • Good connection options (70)
  • Wide viewing angle (61)
  • Simple controls (58)
  • Easy setup (2)
  • Beautiful hd (1)
  • Easy to use (1)
See less See more
Cons
  • Poor sound quality (13)
  • Not enough connection options (3)
  • Poor connection options (3)
  • Confusing / bad remote control (1)
  • Contrast ratio (1)
  • Difficult to set up (1)
  • Internal tuner too slow (1)
  • Need more sound for such (1)
  • No pip (1)
Best Uses
  • Home (66)
  • Movies (38)
  • Bedroom (24)
  • Home theater (19)
  • Video (12)
  • Wall mounting (12)
  • Office (4)
  • Kitchen (3)
  • Family room (1)
  • Slim lines style is great (1)
Provided by Beach Audio
The Aquos D64U Series fits a large screen size into incredibly small footprints. The depth of the D64U series is reduced by 30% by changing the layout of the circuits inside the LCD panel. Advanced Super View/Black TFT Panel is utilized to provide 10,000:1 dynamic-contrast Ratio with Enhanced Picture Contrast Technology and 4ms response time. Place the TV practically anywhere in the room with a 176 degrees wide viewing angle. Enhanced Black Level provides the deepest, most accurate black of any flat panel TV. Aquos engine with ASV technology provides high performance Video Processing for the brightest, most vivid colors and images. Advanced Super View / Black TFT LCD Panel Type
  • 1920 x 1080 Pixel Resolution
  • 450cd/m2 Brightness
  • 176 Degrees Horizontal & Vertical Wide Viewing Angles
  • Up to 60,000 Hours Lamp Life
  • 15 W + 15 W Audio System
  • Tuning System ATSC / QAM / NTSC Tuning System
  • 10,000:1 Dynamic Contrast Ratio and 4ms response time produce spectacular picture quality
  • 2000:1 Native Contrast Ratio 2000:1
  • Aspect Ratio 16:9
  • 4-wavelength Backlight System
  • AN-52AG4 Optional Wall Mount Brackets
  • Input Ports: 3x HDMI (1 side, 2 rear), 2x HD Component (1 side, 1 rear), 1x 15-pin RGB PC, 1x S-Video, 3x Composite Video (1 side, 2 rear), 1x RS-232C 9-pin and 4x Audio (L/R) Inputs
  • All inputs are compatible with 1080p sources
  • Specification Description
    Model 2069632, LC-37D64U, LC37D64U
    UPC 074000370753
    16:9 Mode Yes
    Battery Type Remote
    Benefits 37" (diagonal) LCD TV delivers crystal-clear images that are realistic and detailedFull HD 1080p (1920x1080) resolution for the sharp
    Capacity UOM mAh
    Chemistry Alkaline
    Closed Caption Capability Yes
    Compliant Standards UL Listed, FCC/DHHS Certificated
    Controls / Adjustments Backlight, contrast, brightness, color, tint, sharpness
    Country Of Origin Mexico
    Description Header Go slim.
    Display Catalog Number 55027571
    Display Languages English, Spanish, French
    Display Size 37 inches
    Enclosure Color Black
    End Product Indicator Yes
    Features Enhanced black levels provide the deepest, most accurate black176° viewing angles are so wide you can see the TV from virtually a
    Image Aspect Ratio 16:9
    Included in the Box Sharp 37" Aquos LC-37D64U LCD TVRemote control"AAA" alkaline batteriesAC cordCable clampStand bas
    Inputs 1 x "F" Plug(Antenna/Cable), 2 x HDMI(HDMI), 2 x Component(Component), 4 x RCA(Audio), 1 x VGA(Analog RGB (PC IN)), 1 x DB-9(RS-232), 1 x S-Video(S-Vi
    Manufacturer Labor Warranty 12
    Manufacturer Part Number LC-37D64U
    Manufacturer Parts Warranty 12
    MAP Price 1499.99
    Max Operating Temperature 104 Fahrenheit
    Min Operating Temperature 32 Fahrenheit
    Model LC-37D64U
    Operating Temperature UOM ° F
    Output Power / Total 10 watts
    Outputs 1 x DB-9(RS-232), 1 x Digital(Digital audio out), 1 x RCA(Audio out)
    Power Consumption Operational 180W
    Product Disclaimer Due to manufacturers' policies, RadioShack.com cannot accept returns on this item for any reason. Check the box for damage when you receive it. If it
    Product Type Flat-panel TVs
    Product Weight 45.2
    Product Weight UOM pounds
    Reception System ATSC/NTSC
    Screen Size Range 31-40"
    Size AAA
    Speaker(s) Built-in, 10W + 10W
    Speakers Included 2 Speakers
    Supported Languages English, Spanish, French
    Technology IR
    TV Diagonal Size 37 inches
    TV Resolution 1920x1080
    TV Technology LCD
    Type LCD
    V-Chip Control Yes
    Voltage 1.5
    Voltage Required 120V, 60Hz
    Voltage UOM Volts
    Sharp 37-inch AQUOS 1080p LCD Flat Panel HDTV - LC-37D64U Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Jun 25, 2009
    Sharp 37-inch AQUOS 1080p LCD Flat Panel HDTV - LC-37D64U Reviews
    Most helpful positive review
    [24 of 24 customers found this review helpful]
    Most helpful negative review
    5.0
    HDTV at its best!
    "I did a lot of research before I bought my Sharp Aquos 37" TV. I was first looking at Samsung but I kept reading reviews that said the sound was bad, so I decided to look into technical reviews and I am glad I did. I have watched football on my friends HDTV and everything in the background seemed to jump around. Upon reading reviews I found this was a result of a slow response time of the TV. Another thing I lo..." Read Full Review »
    Sep 08, 2008 by Da Dawg
    See more positive Sharp 37-inch AQUOS 1080p LCD Flat Panel HDTV - LC-37D64U reviews
    3.0
    Sharp Aquos Buyer
    "The picture is great; however, the sound quality is quite poor. The sound has very, very low amplitude at max. level - - even though the speakers are rated at 15-Watts per chanel/speaker, and the speakers sound really tinny...." Read Full Review »
    Mar 18, 2009 by Sharp Aquos Buyer
    See more negative Sharp 37-inch AQUOS 1080p LCD Flat Panel HDTV - LC-37D64U reviews
    Displaying 1 - 5 of 95 Reviews
    Show
    Sort by
    HDTV at its best!
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Good Connection Options
    • Good Resolution
    • Reduced Glare
      Cons
    • Difficult to Setup
      Best Uses
    • Home
    I have watched football on my friends HDTV and everything in the background seemed …"  Read Full Review »
    Was this LCD TV review on the Sharp 37-inch AQUOS 1080p LCD Flat Panel HDTV - LC-37D64U helpful to you?
     Report Abuse  (24)  (0)  0 comments
    Sep 8 2008
    Da Dawg
    Nashville TN
    I am:
    • Casual User
    Reviewed at:
    [5 of 5 customers found this review helpful]
    NICE QUALITY BY TOP NOTCH BRAND LCD TV
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Good Resolution
      Cons
    • Contrast Ratio
    • Price
    • Sound
      Best Uses
    • Home
    • Video
    "The Aquos LCD TV was put in our 16' x 13' apartment living room. 37" should be the minimum size for any TV to be put in a living room, in my opinion.
    I feel that the graphics performance and response time are consistently well, as described in the reviews and specifications on the Aquos D64 series …"  Read Full Review »
     Report Abuse  (5)  (0)  0 comments
    Aug 14 2008
    William
    Houston, TX
    I am:
    • Practical
    Reviewed at:
    [1 of 1 customers found this review helpful]
    Marvelous Picture!
    4.0
      Pros
    • Bright Image
    • Fast Setup
    • Good Resolution
      Cons
    • Absurd Remote
      Best Uses
    • Home Theater
    "This was an impromptu purchase after my daughter's friend killed my favorite TV with the Wii Remote. Papa has to have his big screen![...] the TV emerged perfect!I picked the Sharp because it's the only 37" model that fits in our custom entertainment center. All the rest are too big. Plus, we have a …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Jan 9 2009
    Dusty Lens
    Washington DC
    I am:
    • Enthusiast
    Reviewed at:
    My first 1080P TV
    4.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • Good Sound
      Cons
    • Only 2 HDMI inputs
    • Poor Connection Options
      Best Uses
    • Bedroom
    "This unit replaced a very good 27" Sony CRT TV. It took two stout men a good effort to remove the Sony from the shoulder high bracket. It only took one of us with mild effort to replace it with the Sharp Aquos. My limited electrical bandwidth is very happy with the lower power requirements. It a …"  Read Full Review »
    Feb 27 2009
    RJake
    BayRidge, Brooklyn, NY (Best Pizza)
    I am:
    • Enthusiast
    Reviewed at:
    [2 of 2 customers found this review helpful]
    great set .. but needs more HDMI imputs
    4.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • Reduced Glare
      Cons
      Best Uses
    • Home
    • Movies
    "Great set with awsome picture and sound, but limited connection options are a problem for people that need atleast 3 HDMI ports ( cable box, dvd player, video game) This set has only 2
    and not the 3 stated in the discription. If I had know this set only had 2 HDMI I would not have bought it. I wou …"  Read Full Review »
     Report Abuse  (2)  (0)  0 comments
    May 27 2008
    Oofahvinny
    Deer Park Long island
    I am:
    • Tech Savvy
    Reviewed at:
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
