Sennheiser Electronic CX380 In-Ear Headphone with Pouch
#774
3.8
based on 13 reviews
from $4.99 - $74.95
Ratings Distribution
5 star
5
4 star
4
3 star
2
2 star
0
1 star
2
Category Average
3.9
More Images
Pros
  • Comfortable (9)
  • Lightweight (9)
  • Powerful bass (8)
  • Great sound quality (7)
  • Compact (6)
  • Durable (4)
  • Long cord (1)
  • Noise isolating (1)
  • Water resistant (1)
See less See more
Cons
  • Falls off/out of ear (3)
  • Cord too short (2)
  • Bright orange color (1)
  • Broke down too quickly (1)
  • Cable-produced noise (1)
  • Cord too long (1)
  • Poor sound quality (1)
  • Too much ambient noise (1)
Best Uses
  • Working out (9)
  • Running (8)
  • Portable devices (7)
  • Travel (5)
  • Music (3)
  • With my computer (3)
  • Home audio (2)
Provided by Overstock.com
This noise-isolating ear-canal phone delivers an outstanding, bass-driven stereo sound. An optimal and secure fit in the ear-canals is assured with the inclusion of a set of ear adapters (S/M/L sizes). Sport II CX 380 stereo earphone also ensures a high attenuation of ambient noise, letting you enjoy your music during your workout. The earphone sweat and water-resistant construction also makes them ideal for use when engaged in sporting activities.*Manufacturer: Sennheiser Electronic Corporation *Manufacturer Part Number: CX380 *Manufacturer Website Address: www.sennheiser.com *Product Line: Sport II *Product Model: CX 380 *Product Name: Sport II CX 380 Stereo Earphone *Product Type: Earphone *Connectivity Technology: Wired *Wireless Technology: Not Applicable *Earpiece Design: Earbud *Earpiece Type: Binaural *Wireless Technology: Not Applicable *Host Interface: Mini-phone *Form Factor: Open *Weight: 0.423 oz *Package Contents: *Sport II CX 380 Stereo Earphone *Ear Adapter Set (S/M/L) *Cable Clip *Carrying Pouch
Specification Description
Model CX 380, CX380
UPC 615104145405
color null
Connection Type Wired
Cord Length 4.5 feet
Country Of Origin Germany
Ear Pad Clips - Clip to the ear
Frequency Response 17Hz-21,000Hz
Headband No Headband
Headphone Type Ear Bud
Impedance 16 Ohms
Noise Cancel Capable Yes
Sensitivity 113 db
size null
sku 156203
skuprice 74.9500
Sound Mode Stereo
style CX380
taxable Y
Sennheiser Electronic CX380 In-Ear Headphone with Pouch Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 31, 2009
Sennheiser Electronic CX380 In-Ear Headphone with Pouch Reviews
Most helpful positive review
Most helpful negative review
[3 of 3 customers found this review helpful]
4.0
No so much for sports
"I bought it for running outdoors, since it's a Sport series, waterproof, sounded ideal. I like everything, the light weight, durability, design, sound quality is not superb but it's decent, outside noise isolation is good. Only one weakness: while running the cord bounces against my neck or chest and this is transmitted into the headphone as a clear drumming/hammering noise. It's disturbing, annoying. Everything..." Read Full Review »
Jun 29, 2009 by Daniel
See more positive Sennheiser Electronic CX380 In-Ear Headphone with Pouch reviews
3.0
Don't play with vigor
"This is a great product if you only consider top brands, like me. But if you're willing to shop down, you can probably find something that stays in the ears better while running vigorously...." Read Full Review »
Feb 19, 2009 by Jerseyboy
See more negative Sennheiser Electronic CX380 In-Ear Headphone with Pouch reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
3.0
    Pros
  • Comfortable
  • Good Bass
  • Lightweight
  • Rich Sound
    Cons
  • Cord Too Short
  • Falls Off/Out Of Ear
  • Too Much Ambient Noise
    Best Uses
  • Music
  • Portable Devices
  • Running
  • Working Out
"This is a great product if you only consider top brands, like me. But if you're willing to shop down, you can probably find something that stays in the ears better while running vigorously. "
Was this Headphones review on the Sennheiser Electronic CX380 In-Ear Headphone with Pouch helpful to you?
 Report Abuse  (3)  (0)  0 comments
Feb 19 2009
Jerseyboy
NYC
I am:
  • Audiophile
  • Frequent Traveler
4.0
    Pros
  • Comfortable
  • Compact
  • Durable
  • Lightweight
  • Noise Isolating
  • More »
    Cons
    Best Uses
  • Home Audio
  • Portable Devices
  • Travel
  • With My Computer
  • Working Out
"I bought it for running outdoors, since it's a Sport series, waterproof, sounded ideal. I like everything, the light weight, durability, design, sound quality is not superb but it's decent, outside noise isolation is good. Only one weakness: while running the cord bounces against my neck or chest an …"  Read Full Review »
Jun 29 2009
Daniel
New York, NY
I am:
  • Frequent Traveler
  • Runner
Reviewed at:
Price: $74.95
Sweat and water-resistant.... NOT
1.0
    Pros
  • Comfortable
  • Good Bass
    Cons
    Best Uses
  • Running
  • Travel
  • Working Out
"I work out and run a lot; I went through a dozen of in-ear headphones from different vendors over the last few years. Most of them are like umbrellas - in average any model under [$]deteriorates in two to four months, so durability is my primary concern. Previous Sennheiser pair that I owned (not l …"  Read Full Review »
Jun 15 2009
Cozzamara
New York, NY
I am:
  • Audiophile
  • Frequent Traveler
Best headphones yet
5.0
    Pros
  • Durable
  • Good Bass
  • Lightweight
  • Rich Sound
    Cons
    Best Uses
  • Running
  • Travel
  • Working Out
"These have to be the best earphones I have purchased to date. I have been searching for the longest time to find in-ear headphones that actually stay IN your ear. I usually run for an hour at the gym and so far these ear phones have not only stayed perfectly in my ears, but they also have Excellent …"  Read Full Review »
Jul 6 2009
Treadmill junkie
Tampa, FL
I am:
  • A runner
  • Student
Reviewed at:
Price: $74.95
garbage
1.0
    Pros
  • Compact
  • Lightweight
    Cons
  • Poor Sound
    Best Uses
  • Running
  • Working Out
"the CX380 goes out unnormal sound. I really hate it! this model I bought on friday, returned on Sunday. The sound quality is really bad. In same brand, its quality is lower than the CX300, even though CX300 is cheaper. In different brand, sony EX85 is better than CX380, but EX85 is only about 40 dol …"  Read Full Review »
Jul 12 2009
cloudywind
brooklyn ny
I am:
  • Student
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
