Sears Nav-Mat Portable GPS Dash Mount
#2
4.6
based on 179 reviews
Ratings Distribution
5 star
143
4 star
33
3 star
5
2 star
7
1 star
4
Category Average
4.1
$9.27 - $19.99
from 16 stores
More Images
Pros
  • Easy to use (77)
  • Works well with gps (35)
  • Quality construction (34)
  • Well made (30)
  • Improves functionality (29)
  • Easy to install (27)
  • Easy setup (10)
  • Durable (3)
  • Sturdy (3)
  • Attractive design (2)
See less See more
Cons
  • Pricey (2)
  • Difficult to use (1)
  • Does slide a little (1)
  • Don't scratch the disk (1)
  • Don`t apply (1)
  • Expensive vs materials (1)
  • Hard to install (1)
  • Heavy / bulky (1)
  • I did not find any (1)
  • Large footprint (1)
Best Uses
  • Car (37)
  • Auto (35)
  • Travel (25)
  • Boating (4)
  • Upgrade (3)
  • Boat (1)
  • Dash mount (1)
  • Garmin 350 holds great (1)
  • Keeping gps in place (1)
  • On your gps on the dash (1)
Provided by OutdoorPros.com
Bracketron UFM-100-BL Nav-Mat Portable GPS Dash Mount Bracketron is one of the leading suppliers of mounting solutions and accessories for GPS, Satellite Radios, Cell Phones, iPods, iPhones, Laptop Computers and other mobile electronics. The Nav-Mat is the most convenient mounting accessory for your portable GPS today. Using the physics of weight distribution along with high tech anti-skid materials, it creates a solid mounting base while turning your windshield mounted GPS into a dash mounted GPS. The Nav-Mat conforms to the contours of your dashboard, allowing it to work on uneven or textured surfaces while the anti-skid underside keeps the device from sliding. Designed to work with devices up to several pounds using the stock windshield suction mount sold with most popular GPS units, the Nav-Mat requires no tools for installation and can easily be moved from vehicle to vehicle or put out of sight when leaving the vehicle. Also works well with other Bracketron Windshield Mounts for mounting devices such as Satellite Radio, Cell Phones and MP3 Players. * May not be suitable for use with the TomTom Go 720 and Go 920/920T. Please Note: The stock windshield mounts provided with these units do not provide sufficient clearance height to the unit needed to work properly with the Nav-Mat. Owner of the units may want to consider purchasing the Bracketron GPS Windshield Mount which will provide the necessary clearance. Bracketron UFM-100-BL Nav-Mat Portable GPS Dash Mount Features: • Works with Most Stock Windshield Mounts included with the device • Weighted, Anti-Skid Base • Conforms To Your Dash • No Tools Required • Holds up to Several Pounds • Easily View Your GPS While Driving • Uses The Stock GPS Windshield Mount • Portable And Stow-Able, Keep Out of View - Anti-Theft! • 1 Year Warranty • The Nav-Mat has been certified RoHS compliant
Specification Description
Model 32446, UFM-100-BL, UFM-100BL, UFM100BL
UPC 874688001051
color null
Select Accessory Unit Mounts
size null
sku 107883
skuprice 29.9500
style UFM100BL
taxable Y
Sears Nav-Mat Portable GPS Dash Mount Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 10, 2009
Sears Nav-Mat Portable GPS Dash Mount Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
5.0
A must-have for vehicle electronics
"After investing in a GPS unit, I wanted to make sure that it wasn't stolen. Since thieves will break into a vehicle looking for electronics when they see the circle left by window mounts, the Bracketron Nav-Mat is THE practicle solution. I use my Nav-Mat primarily in my Jeep Wrangler. I have been off road with my GPS mounted to the Nav-Mat and it doesn't budge. The way it's designed with a non-slip bottom make..." Read Full Review »
Jun 29, 2008 by Jeep Fan
See more positive Sears Nav-Mat Portable GPS Dash Mount reviews
1.0
DO NOT BUY!!!!!
"I bought this thinking that it would be a nice thing to have to hold my GPS unit while I was driving. It turns out to be a piece of junk. The suction cup stops sticking after about a week and after that you have to spit on it to get it to stick. And after a while it just stops sticking. Save your money and don't buy this. Go with the garmin one that they sell or get another one. If you do buy it it's just a wast..." Read Full Review »
Aug 27, 2009 by streetchic78 "Streetchic78"
See more negative Sears Nav-Mat Portable GPS Dash Mount reviews
Displaying 1 - 5 of 179 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • None
I use my Nav-Mat primarily in my Jeep Wrangler. I have bee …"  Read Full Review »
In my Jeep
In my Jeep
  • Using Product
Was this GPS Accessory review on the Sears Nav-Mat Portable GPS Dash Mount helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jun 29 2008
Jeep Fan
Central PA
I am:
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Price: $12.99
Rock solid mount
5.0
    Pros
  • Easy To Use
  • Improves Functionality
  • Works Well With GPS
    Cons
  • None
    Best Uses
  • Auto
"This is a great product to use with any auto GPS unit that uses a suction mount.It does not leave any marks on the windsheild or the dash, it is also very easy to just pick up and hide under the seat or trunk. The best thing is it just doesnt move from were you decide to place it on you dash, this u …"  Read Full Review »
Nov 9 2009
Liverache
Erie, Pa
I am:
  • Casual User
Reviewed at:
Price: $12.99
[8 of 8 customers found this review helpful]
This is what you need!!
5.0
"Been looking for a way to keep from having to stick my GPS bracket on the windshield. This is the product. A weighted bean-bag with a disk in the center. It is heavy enough to stay put on sharp curves. The suction disk is large and easy to unhook. You can move it around as needed to avoid direct sun …"  Read Full Review »
 Report Abuse  (8)  (0)  0 comments
Aug 25 2007
BigSteve
Atlanta, Ga.
[1 of 1 customers found this review helpful]
Use And Hide Your GPS
5.0
    Pros
  • Easy To Use
  • Well Made
    Cons
  • None
    Best Uses
  • Auto
  • Boating
  • Travel
"My Honda Odyssey has a windshield that slopes away from the dashboard at a very steep angle. Placing my Garmin GPS on that windshield placed it so far away from my point of view that viewing, (and hearing), the information was almost impossible. Now, with the Dash Pad, it's on the dashboard--direc …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Oct 7 2009
Llabesab
Eastchester, New York
I am:
  • Power User
Reviewed at:
Price: $12.99
[5 of 5 customers found this review helpful]
Very Good Product
5.0
"Used this on a trip from Las Vegas to San Diego and I never saw my portable GPS system move even a millimeter. On first look, it looks like a weakling but when you use it, you'll be impressed. Will definitely recommend using this if you're driving in California and Minnesota where mounting anything …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Oct 14 2007
joshua15
Las Vegas, NV
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
