Seagate 500GB OneTouch 4 External Hard Drive
4.0
based on 60 reviews
Ratings Distribution
5 star
236
4 star
184
3 star
38
2 star
24
1 star
55
Category Average
4.1
More Images
Pros
  • Easy setup (419)
  • Easy to use (408)
  • Large capacity / good size (355)
  • Fast (239)
  • Portable (232)
  • Reliable (209)
  • Quiet (55)
  • Attractive design (40)
  • Quality construction (20)
  • Compact (16)
See less See more
Cons
  • Unreliable (36)
  • Slow (26)
  • No on/off switch (15)
  • Difficult to use (13)
  • Difficult to set up (11)
  • Size (3)
  • Bulky (2)
  • Noisy (2)
  • Small capacity (2)
Best Uses
  • Back-up (360)
  • Additional storage (329)
  • Video (170)
  • File transfer (147)
  • Music (137)
  • Photo storage (43)
  • Upgrade (13)
  • Photos (3)
  • Doorstop (2)
  • Paper weight (2)
Provided by Super Warehouse
For everyone with data-protection needs that is looking for an elegantly simple- full-featured backup and storage solution- the Maxtor OneTouch 4 Plus sports a new vault-like industrial design that conveys security and protection. The elegant color scheme and design make it a good fit in any home or office setting.
  • Type:  Hard drive- external
  • Form Factor: 3.5"
  • Capacity: 500 GB
  • Interface Type: IEEE 1394 (FireWire) / Hi Speed USB
  • Data Transfer Rate: 400 Mbps (FireWire) / 480 Mbps (Hi-Speed USB)
  • Spindle Speed: 7200 rpm
  • Buffer Size: 16 MB
Specification Description
Model 500GBLITEWM, 500GBMAXTORLITE, STM305004OTA3E1, STM305004OTA3E1-RK
UPC 763649004333
Buffer 16MB
Computer Compatibility PC and Macintosh
Connection External
Data Transfer Rate 480Mbps External Maximum USB 2.0
Drive Capacity 500GB
Hard Drive Capacity 500 GB
Interface USB 2.0 USB
Package Type Retail
Port Compatibility USB
Rotational Speed 7200 rpm
Select Desktop Drives
Select Interface USB
Select Platform Windows,Macintosh
Storage Capacity 500GB
Type of Drive Hard Drive
Seagate 500GB OneTouch 4 External Hard Drive Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 500GB OneTouch 4 External Hard Drive
See all eBay results
  at eBay.com
Product Reviews
Last update: Nov 16, 2009
Seagate 500GB OneTouch 4 External Hard Drive Reviews
Most helpful positive review
[7 of 7 customers found this review helpful]
Most helpful negative review
[9 of 9 customers found this review helpful]
5.0
Great drive
"I had previously tried the Western Digital My book essential and ended up returning it. It made a whining noise and was slow. I purchsased this maxtor and love it. I am using the firewire port and it flies. I read somewhere that firewire doesn't hog your system resources like USB 2.0, and that makes sense. I also like how this drive has 2 firewire plugs so that you can daisy chain other firewire periphials ..." Read Full Review »
Feb 05, 2008 by Michael Metcalf
See more positive Seagate 500GB OneTouch 4 External Hard Drive reviews
3.0
Good drive, crippled software
"This drive has huge capacity, and is very easy to set up. Unfortunately the Maxtor Manager software does NOT allow you to "Backup what you want" as stated on the box. It will only perform automatic backup of the My Documents and Desktop folders for the user currently logged in. This isn't so great if you have multiple users with their own My Documents folder (each user must perform or schedule their own backups)..." Read Full Review »
Jan 08, 2008 by Biking Bum
See more negative Seagate 500GB OneTouch 4 External Hard Drive reviews
Displaying 1 - 5 of 60 Reviews
Show
Sort by
[6 of 6 customers found this review helpful]
Large storage, easy back up
5.0
"Bought it when my first computers hard drive crashed. After i got the hard drive back online, this backed up everything on there within an hour. Very large storage space which is helpful. fast transfer times and 7200 rpm. I currently have 3 computers backed up on it and havent seen a single problem …"  Read Full Review »
Was this External Computer Hard Drive review on the Seagate 500GB OneTouch 4 External Hard Drive helpful to you?
 Report Abuse  (6)  (0)  0 comments
Nov 18 2007
bringblinkback
Olney, Maryland
Reviewed at:
Couldn't be simpler
4.0
    Pros
  • Attractive Design
  • Easy To Setup
  • Easy to use
  • Fast
  • High Capacity
    Cons
  • Lacks system backup
  • No back up for outlook
  • No backup for favorites
    Best Uses
  • Additional Storage
  • Backup
"Installation was as simple as plugging it in, and selecting which files to back up is just as easy. I got some odd error messages on pics but they're there and open.
The best part is that it runs every night without any action from me. I've checked & it picks up any changed files. A great reli …"  Read Full Review »
Jan 22 2009
mschannon
Virginia
I am:
  • Power user
Reviewed at:
[3 of 3 customers found this review helpful]
very disappointed
1.0
"The first drive I bought installed fine, however when running first backup it started giving disk errors, and caused blue screen with bad drive errors and chkdsk couldn't fix. Also failed Seatools. Support had me reformat, but that didn't fix - drive failed again. Exchanged at BestBuy for another, a …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Dec 30 2007
matrixchic
Chicago, IL
Reviewed at:
Great Product for Peace of Mind
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Setup
  • Easy to use
  • High Capacity
  • More »
    Cons
  • None
    Best Uses
  • Backup
  • Photo Storage
"I am using this external hard drive to provide back up for photos and also documents. It was very easy to install and provides greater service that I will really need, which is fine.The one issue I had is that I don't need to back up these files regularly; so a daily or even weekly back up is not n …"  Read Full Review »
Apr 21 2009
Barbara
Branford CT
I am:
  • Casual user
Reviewed at:
code 10 = drive is dead
1.0
"We used this product for 5 months with no problem. Then, one day we turned it on and while the computer recognizes that the drive is there (in the device manager and the system tray), the device drivers will not load properly. I use the Seagate (manufacturer) SeaTools to help diagnose, and it says " …"  Read Full Review »
Feb 10 2008
dbmor10
Hill Country, TX
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
