Seagate 1.5TB FreeAgent Desk for Mac External Hard Drive
#166
4.3
based on 8 reviews
Ratings Distribution
5 star
5
4 star
2
3 star
0
2 star
0
1 star
1
Category Average
4.1
Low Price:
$189.99 at J&R Electronics
 Trusted:
$202.27 at pcRUSH
Find it at Amazon
$189.99 - $210.99
from 3 stores
More Images
Pros
  • Quiet (6)
  • Fast (5)
  • Easy to install (4)
  • Highly compatible (4)
  • Reliable (4)
  • Easy to use (3)
  • Attractive design (2)
  • Easy setup (2)
  • Compact (1)
  • Durable (1)
See less See more
Best Uses
  • Additional storage (2)
  • Back-up (2)
  • High-end multimedia (2)
  • Home or business (1)
  • Photo storage (1)
  • Travel (1)
  • Video (1)
Provided by Super Warehouse
With its huge capacity and sleek design- the Mac-ready Seagate FreeAgent Desk storage solution delivers a powerful yet simple way to help safeguard all your photos- music- videos- and documents. You can get up and running quickly thanks to Mac formatting and time machine-readiness- then enjoy blazingly-fast transfer of your content with FireWire 800 and USB interfaces. Enjoy a modern design that complements your Mac system- and take advantage of a vertical profile that maximizes your workspace. You can count on the FreeAgent Desk storage solution to store everything on your Mac.
  • Product Description: FreeAgent Desk for Mac- hard drive- 1.5 TB- FireWire / FireWire 800 / Hi-Speed USB
  • Type: Hard drive- external
  • Form Factor: 3.5"
  • Dimensions (WxDxH): 1.5 in x 6 in x 7.3 in
  • Weight: 2.2 lbs
  • Enclosure Color: Silver
  • Capacity: 1.5 TB
  • Interface Type: IEEE 1394b (FireWire 800) / IEEE1394 (FireWire) / Hi-Speed USB
  • Data Transfer Rate: 800Mbps(FireWire800)/400Mbps(FireWire)/480Mbps(Hi-Sp.USB)
  • Spindle Speed: 7200 rpm
  • OS Required: Apple MacOS X 10.4.9 or later
  • Power Source: Included AC adapter
  • Manufacturer Warranty: 5 years warranty
Specification Description
Model 15TBDESKMAC, ST315005FJA105-RK, ST315005FJA105RK, st315005fja105-rk
UPC 763649012338
Buffer 32MB
Computer Compatibility Macintosh
Connection External
Data Transfer Rate 480Mbps Maximum External
Drive Capacity 1500GB 1.5TB
Hard Drive Capacity 1.5 TB
Interface USB 2.0 USB
Package Type Retail
Port Compatibility USB / Firewire
Power AC - 110-Volt AC House Current
Rotational Speed 7200 rpm
Select Desktop Drives
Select Interface Firewire,USB
Select Platform Macintosh
Storage Capacity 1.5TB
Type of Drive Hard Drive
Seagate 1.5TB FreeAgent Desk for Mac External Hard Drive Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 6, 2009
Seagate 1.5TB FreeAgent Desk for Mac External Hard Drive Reviews
Displaying 1 - 5 of 8 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
I would buy this product again and again
5.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
  • Quiet
  • Reliable
    Cons
  • None
    Best Uses
  • High-End Multimedia
"This is my favorite brand for me on external hard drives. I've tried other brands and for some reazon I have some times big problems. But, Seagate has worked for me, so far, just very good.
So, I recommend it. And hope and a near future I can buy same brand but with much more capacity, let us say …"  Read Full Review »
Was this External Computer Hard Drive review on the Seagate 1.5TB FreeAgent Desk for Mac External Hard Drive helpful to you?
 Report Abuse  (2)  (0)  0 comments
Jan 5 2009
Novato
Los Angeles, CA
I am:
  • Frequent User
Reviewed at:
So far so good
4.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Setup
  • Easy to use
  • Quiet
    Cons
  • None
    Best Uses
  • Additional Storage
  • Backup
"I have only had this product for 3 weeks but I must say I ma very happy with it. I am not using to play audio or video from it, but instead as a place to store audio samples to be loaded into virtual synths. So far its been reliable and fast enough for this type of use. "
Apr 7 2009
dricci
New York City
I am:
  • Power user
Reviewed at:
Price: $189.99
So Far So Good
4.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
  • Quiet
    Cons
  • None
    Best Uses
"My main usage of this external HD is for video and photos. Overall it seems to work well and transfers fairly fast considering the size and number of files I upload.
It is quiet, and only at times will it run a little warm. Both noise and temp are better than I expected.
I have only owned this …"  Read Full Review »
Mar 9 2009
nap.thug
brooklyn, ny
I am:
  • Frequent User
Reviewed at:
Fast, Reliable, 1.5 TB OH BOY!
5.0
    Pros
  • Durable
  • Easy to Use
  • Fast
  • Reliable
    Cons
  • None
    Best Uses
  • Home or Business
  • Travel
"I use it to store audio files for my voice over work. 1.5TB of storage! I remember when the Commodore 64 was a big deal because it had 64K of memory. With that size it can store current files and provide back up service. "
Dec 31 2008
Frank C
Houston TX
I am:
  • Value Oriented
Reviewed at:
Price: $202.27
[1 of 1 customers found this review helpful]
Horrible
1.0
"I bought the external hard drive back in January. It now fails to turn on after backing up all my personal photos from 1999 to 2009 because my computer hard drive was full. I contacted Seagate and they tell me its not a problem to replace the drive but to get folders that I had backed up it is going …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Apr 20 2009
Michael07
Noblesville, IN
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
