Sanyo Xacti VPC-TH1 HD 720p Flash Camcorder
#215
3.7
based on 10 reviews
from $239.97 - $299.99
Ratings Distribution
5 star
4
4 star
3
3 star
1
2 star
0
1 star
2
Category Average
4.1
More Images
Pros
  • Comfortable to operate (1)
  • Durable (1)
  • Great features (1)
  • Great picture quality (1)
  • Great sound quality (1)
  • Simple controls (1)
See less See more
Best Uses
  • Documentaries (1)
  • Editing (1)
  • Hd shooting (1)
  • Home movies (1)
  • Movies/short films (1)
  • Travel (1)
Provided by Beach Audio
  • HD video image resolution up to 1280 x 720 and still image resolution up to 1600 x 1200
  • 30x optical, 1500x digital zoom
  • Face Chaser technology can detect up to 12 faces for photos and videos
  • High-speed sequential shooting: 13fps
  • 3D DNR noise-reducing function for clearer, more professional-looking video
  • 1/6" CMOS image sensor
  • High still sensitivity up to 1600 ISO
  • 3-hour 20-min continuous recording with long-life battery
  • 3.0" low-temperature polysilicon TFT color widescreen LCD display
  • Uses SD?/SDHC? memory cards up to 32GB
  • Includes rechargeable Li-Ion (DB-L50) battery and charger
  • Specification Description
    Model 086483073380, VPC-TH1BL, VPCTH1BL
    UPC 086483073380
    16 x 9 recording Yes
    Audio Recording Yes
    Auto Focus TTL contrast detection
    Auto Focus Points (Zones) 9
    Auto power saveĀ  Yes
    Battery Type Product
    Benefits Take HD video with resolutions up to 1280x720 and still images with resolutions up to 1600x1200Large 3" (diagonal) LCD display rotate
    Cables Included USB cable, A/V cable
    Camera Flash Built-in
    Camera/Camcorder Color Support Yes
    Capacity 1900
    Capacity UOM mAh
    Chemistry Lithium Ion
    Connections USB (1)A/V connector (1)
    Connector Type USB, A/V
    Continuous Burst or Capture ModeĀ  Yes
    Continuous Shooting Speed 13fps
    Controls / Adjustments 7-level brightness, 285° rotation
    Country Of Origin China
    Description Header Put the power of HD in your palm.
    Digital Still Camera Function Yes
    Digital Video Format MPEG-4
    Digital Zoom 50
    Display Catalog Number 55032594
    Display Features 230000 pixel resolution
    Display Languages Multi-language support
    Display Size 3 inches
    Effective Sensor Resolution 1100000 Pixels
    Enclosure Color Blue
    End Product Indicator Yes
    Expansion Slot(s) SD/SDHC
    Exposure Compensation ±1 EV steps in 1/3 EV steps
    Exposure Metering Spot, Multi-segment, Center-weighted
    Exposure Modes Program, Automatic
    Flash Modes Auto mode, Fill-in mode, Slow synchro, Flash OFF mode
    Focal Length 2.5mm~75mm
    Focal Length Equivalent to 35mm Camera 43mm~1290 mm
    Image Stabilizer Digital
    Image Storage 2M: 1600x1200, 1.1M: 1184x888, 0.9M[16:9]: 1280x720, 0.3M: 640x480
    Included in the Box Sanyo Xacti VPC-TH1 HD 720p Flash CamcorderRechargeable lithium ion battery (DB-L50)Battery chargerUSB cable
    Integrated Memory 43
    Integrated Memory UOM MB
    Lens Aperture F/1.8-4.3
    Lens Construction 10 elements in 7 groups
    Lens System Features 2 aspheric elements, 3 aspheric surfaces, built-in neutral density filter
    Lens System Type Zoom
    Light Sensitivity ISO50~1600
    Macro Focus Range 75 cm
    Manufacturer Labor Warranty 12
    Manufacturer Part Number VPC-TH1BL
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Max Operating Temperature 104 Fahrenheit
    Max Shutter Speed 1/10000
    Megapixel Range <2MP
    Microphone Operation Mode Stereo
    Microphone Technology Electret condenser
    Microphone Type Built-in
    Min Focus Range 2.5 inches
    Min Illumination 3 lux
    Min Operating Temperature 32 Fahrenheit
    Min Shutter Speed 2 Seconds
    Model VPC-TH1
    Operating Temperature UOM ° F
    Optical Sensor Type 1/6" CMOS
    Optical Zoom 30
    Power Device Rechargeable lithium ion battery (DB-L50)
    Product Depth 4.1
    Product Dimensions UOM inches
    Product Height 2.2
    Product Type Flash memory
    Product Weight 8
    Product Weight UOM ounces
    Product Width 2.1
    Rechargeable Yes
    Red Eye Reduction Yes
    Resolution 1.1 Megapixels
    Self Timer Yes
    Shooting Programs Lamp, Fireworks, Landscape, Beach/snow, Sports mode, Portrait mode, Night portrait
    Size Specialty
    Sound Output Mode Stereo
    Special Effects Sepia, Cosmetic, Black & White
    Still Image Format JPEG
    Supported Flash Memory SD/SDHC
    Supported Languages English
    Type LCD
    Video Capture HD-SHQ: 1280x720 (30 fps/ 9Mbps), TV-HR: 640x480 (60 fps/6Mbps), TV-SHQ: 640x480 (30 fps/3Mbps)
    White Balance Custom , Presets , Automatic
    White Balance Presets Cloudy, Sunlight, Fluorescent, Incandescent
    Zoom Adjustment Motorized drive
    Sanyo Xacti VPC-TH1 HD 720p Flash Camcorder Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Aug 24, 2009
    Sanyo Xacti VPC-TH1 HD 720p Flash Camcorder Reviews
    Most helpful positive review
    [12 of 12 customers found this review helpful]
    Most helpful negative review
    [10 of 10 customers found this review helpful]
    4.0
    It is HD - not bad for under $300
    "I also bought this camera without doing much research. I was looking for a camcorder that was HD "quality", uses SDHC memory card and for a price around $300. The Sanyo met all the criteria so I purchased it from Amazon. I also picked up a 16 gb Transcend memory card. Let's go over the PROS first -- . ++ It is really easy to use. Just point and shoot. Just like using a digital camera, except it's a digita..." Read Full Review »
    Apr 14, 2009 by A. Chan
    See more positive Sanyo Xacti VPC-TH1 HD 720p Flash Camcorder reviews
    3.0
    You Get What You Pay For . . .
    "I bought this camcorder for a "cheap" way to enter the HD world of video capturing. I will wait to get a much better camcorder once I figure out how to get around editing AVCHD (and when I buy a new computer that can handle HD video editing with ease). My main use for this camcorder is capturing orchestral performances, editing it, and uploading the video to YouTube in HD quality. I also like taking video tha..." Read Full Review »
    Apr 12, 2009 by CoronaLite
    See more negative Sanyo Xacti VPC-TH1 HD 720p Flash Camcorder reviews
    Displaying 1 - 5 of 10 Reviews
    Show
    Sort by
    3.0
    "I bought this camcorder for a "cheap" way to enter the HD world of video capturing. I will wait to get a much better camcorder once I figure out how to get around editing AVCHD (and when I buy a new computer that can handle HD video editing with ease). My main use for this camcorder is capturing o …"  Read Full Review »
    Was this Digital Camcorder review on the Sanyo Xacti VPC-TH1 HD 720p Flash Camcorder helpful to you?
     Report Abuse  (10)  (0)  0 comments
    Apr 12 2009
    CoronaLite
    Reviewed at:
    Price: $299.99
    4.0
    Let's go over the PROS firs …"  Read Full Review »
     Report Abuse  (12)  (0)  0 comments
    Apr 14 2009
    A. Chan
    Cerritos, CA
    Reviewed at:
    Price: $299.99
    Thrilled with product!
    5.0
      Pros
    • Comfortable to Operate
    • Durable
    • Great Features
    • Great Picture Quality
    • Great Sound
    • More »
      Cons
    • None
      Best Uses
    • Documentaries
    • Editing
    • HD Shooting
    • Home Movies
    • Movies/Short Films
    • More »
    "There are only two things that I have to share that are negative. And...one might be my own fault! :) Oops...
    1. I found the cd it came with useless. I thought it would physically show me how to do things...it was simply a copy of the instuction manuel (which does not resonate with my learning st …"  Read Full Review »
    Aug 24 2009
    Marie CT JP
    Mystic, CT.
    I am:
    • Casual User
    Reviewed at:
    Price: $258.95
    [1 of 1 customers found this review helpful]
    Great battery life for an entry HD camcorder
    4.0
    "I've had the camera for 1 month so far. This is my first Digital (HD or non-HD) Camcorder. I've used vhs and minidv camcorders before, so I have no comparison to other digital camcorders
    -Size: almost pocketable, but small enough to carry around in my messenger bag
    -Feel: feels durable. Wish it …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    May 19 2009
    T. Hwang
    Amazon
    Reviewed at:
    Price: $299.99
    [2 of 4 customers found this review helpful]
    Simply horrible
    1.0
    "I had such high hopes for this camcorder. I prefer this orientation of camera over the more common pistol grip many cheaper camcorders seem to be heading towards. But as soon as I powered this camera on, I was ready to return it...
    The video quality was horrible. Compared to my $100 Jazz HDV178, …"  Read Full Review »
     Report Abuse  (2)  (2)  0 comments
    May 16 2009
    D. Adams
    Lexington, NC
    Reviewed at:
    Price: $299.99
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
