Sanus VMPL3 VisionMount TV Wall Mount In Silver
#184
4.8
based on 6 reviews
Ratings Distribution
5 star
5
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$132.00 at www.sayera.com
 Trusted:
$135.00 at Meijer.com
Find it at Amazon
$132.00 - $219.56
from 5 stores
More Images
Pros
  • Easy assembly (5)
  • Supports weight (4)
  • Attractive design (3)
  • Holds all components (3)
  • Easy to move (2)
  • Smooth edges (2)
  • Easy to wire (1)
See less See more
Cons
  • Heavy / bulky (1)
Best Uses
  • Space saver (4)
  • Convenience (3)
  • Decoration (1)
Provided by B&H Photo Video
The Sanus VisionMount TV Wall Mount VMPL3s (Silver) is a wall mount designed for large, 27" to 84" flat-screen displays up to 280 lb. With this unit, your display mounts only 2-1/2" from the wall, offering a seamless installation that matches the clean aesthetic of your display. Sanus' patent-pending "Virtual Axis" fingertip tilting system provides smooth tilt motion and stays in position at any angle, allowing for easy adjustments. Two (2) universal mounting brackets allow the display to be attached and detached from the installed mount as needed. Safety bolts lock this mount safely in place, keeping people from tampering with or removing your display. All installation hardware is included.
Specification Description
Model SASVMPL3S, VMPL3S, VMPL3s
UPC 793795360595
Color 27" to 84" Flat Panel TV
color null
Material Wall-mountable
size null
sku 150090
skuprice 249.9900
style VMPL3S
taxable Y
Sanus VMPL3 VisionMount TV Wall Mount In Silver Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 27, 2008
Sanus VMPL3 VisionMount TV Wall Mount In Silver Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
Great product for a great price
5.0
    Pros
  • Attractive Design
  • Easy to Assemble/Wire
  • Holds All Components
  • Supports Weight
    Cons
  • NONE
    Best Uses
  • Convenience
  • Decoration
  • Space Saver
"A great product with all the accessories you will need to install any type of TV. From lag bolts for 2x4's to accessories for concrete applications...it covers them all. The option of tilt and low profile mounting is great as well. Easily supports 200 lbs on two 2x4's and the installation was a bree …"  Read Full Review »
Was this TV Wall Mount review on the Sanus VMPL3 VisionMount TV Wall Mount In Silver helpful to you?
May 27 2008
Caltek
Peterborough, ON
I am:
  • Bargain Hunter
  • Practical
Reviewed at:
Very good, recomended
5.0
    Pros
  • Attractive Design
  • Easy To Move
  • Smooth Edges
  • More »
    Cons
  • None
    Best Uses
  • Space Saver
"I used this for my samsung 52" lcd. It fits very good on three studs.I like the way it was made. I will recomend to every one don't buy cheap mount. This is a quality mount in 1/3rd of store price. I got very good deal form B&H. I also recomend before you buy check with B&H.
J.C. "
Apr 10 2008
J.C.
Los Angeles, Ca
I am:
  • Bargain Hunter
  • High-End Shopper
Reviewed at:
Highly recommended for any size screen
5.0
    Pros
  • Attractive Design
  • Easy To Move
  • Easy to Wire
  • More »
    Cons
  • None
    Best Uses
  • Convenience
"Very easy to mount, fits perfectly and easily to screen, extra heavy duty rails and brackets, "bullet-proof" "
Apr 30 2008
doc
Bridgeport, Connecticut
I am:
  • Practical
TV Mount review
4.0
    Pros
    Cons
  • None
    Best Uses
  • Space Saver
"Product was packaged well, and shippment was on time. "
May 21 2008
Snoopy
Los Alamitos, CA
I am:
  • Bargain Hunter
This mount worked out ...
5.0
"This mount worked out great. The item was received two days after purchasing it. Installed like a charm and does not move unless I move it. [...] "
Dec 17 2005
Michael A
Undisclosed
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
