#561
based on 12 reviews
Ratings Distribution
| 5 star |
4 |
| 4 star |
6 |
| 3 star |
2 |
| 2 star |
0 |
| 1 star |
0 |
Category Average
$22.09 - $52.75
from 15 storesPros
Cons
Best Uses
Where to Buy
| No Tax Outside NY ends 09/09/15 |
BizRate Rating
Outstanding 9.7
BizRate Rating
Outstanding 9.4
BizRate Rating
Good 8.8
Product Reviews
"Most of us have been indocrinated with the belief that "you get what you pay for." The negative is that we may tend to reject things that cost less, on the belief that they can't be any good if they are priced way lower than "comparables." This product is fine and is excellent value if: 1) you don't neeed side-to-side movement of the tv, and 2) you can insure that the holes you will drill to mount it will resu..." Read Full Review »
Jun 02, 2009 by Mike
See more positive Sanus VMFb 13"-30" Flat Panel Wall Mount with Tilt Motion - Black reviews
"You need very small hands & finger that are VERY STRONG to adjust the angle and tighten final bolts.. Unit slides over bolts that have been screwed into a wood stud. The bolts are nearly flush with the wall except for the last few turns of the allen wrench. Once the TV & Bracket slides over the bolts they need to be tightened to secure to wall. I had to adjust the TV angles to each extreme (up to tighten bot..." Read Full Review »
Sep 14, 2007 by Mike
See more negative Sanus VMFb 13"-30" Flat Panel Wall Mount with Tilt Motion - Black reviews
Displaying 1 - 5 of 12 Reviews
Sanus VMFb 13"-30" Flat Panel Wall Mount with Tilt Motion - Black Review
Pros
Cons
Best Uses
"Most of us have been indocrinated with the belief that "you get what you pay for." The negative is that we may tend to reject things that cost less, on the belief that they can't be any good if they are priced way lower than "comparables." This product is fine and is excellent value if: 1) you don …" Read Full Review »
Pros
Cons
Best Uses
Read Full Review »
Pros
Cons
Best Uses
"Very smooth tilting action. Good range.
Cons: Stands off from the wall more than most other mounts of similar design and application.
Pros
Cons
Best Uses
"Good mounts. Sturdy, mated well with computer monitors (Sony 941 17") to create a cool dual screen above desk mounting. Looks clean and slick. Mounts are plenty heavy duty and had hardware to screw to monitors. Good price, good deal. "
Pros
Cons
Best Uses
"Product is very sturdy and works as expected; easy to install and very flat to wall so looks great in our room "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.7
BizRate Rating
Outstanding 9.4
BizRate Rating
Good 8.8
| $1.99 Shipping On Orders Over $100 at TigerDirect |
BizRate Rating
Outstanding 9.1
| $1.99 Shipping on Orders Over $75 ends 12/31/09 | ||||
BizRate Rating
Good 8.8
BizRate Rating
Good 8.8
| Code FALLSAVINGS33 : $5 Off Orders Over $50 |
BizRate Rating
Good 8.7
| Code SEARS5OFF50 : $5 Off Orders Over $50! |
BizRate Rating
Good 8.2
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
