Sanus VM3 VisionMount LCD Wall Mount
#466
4.4
based on 12 reviews
Ratings Distribution
5 star
8
4 star
3
3 star
0
2 star
0
1 star
1
Category Average
4.4
Low Price:
$99.99 at Mounts and More
$99.99 at LCD Mounts Online
Find it at Amazon
$99.99
from 3 stores
More Images
Pros
  • Interfaces well with tv (7)
  • Adjustable (6)
  • Easy to install (6)
  • Multiple viewing angles (6)
  • Sturdy (5)
  • Easy setup (1)
See less See more
Cons
  • Tedious installation (1)
  • Will not hold a 26" lcd (1)
Best Uses
  • Home (2)
  • Office (2)
  • Anywall with studs (1)
  • Anywhere a mount is neede (1)
  • Bedroom (1)
  • Kitchen (1)
  • Tv's smaller than 21" (1)
Provided by Speaker Stands Online
The Sanus VisionMount is the ideal solution for mounting a flat panel LCD TV or computer monitor to a wall, ceiling or even under a cabinet. Extruded aluminum construction perfectly complements the high-tech look and feel of today's flat panels. The VisionMount is available in four models designed to fit every mounting and adjustment need. Every model uses VESA mounting standards and holds up to 30 pounds.
The patent pending SmoothLock adjustment mechanism provides effortless tilt and swivel adjustment with no tools required. The mount offers both the VESA 75 and VESA 100 mounting options.
Features:
  • Silver finish
  • Rigid extruded aluminum construction
  • Anodized finish matches look and feel of today's LCD TVs
  • Fits most LCD flat panel TVs and computer monitors (VESA 75 and VESA 100)
  • Smoothlock mechanism provides smooth tilt & swivel, effortless tightening and extreme rigidity
  • Supports up to 30 lbs.
  • +/- 30 degrees of tilt
  • 15" maximum extension from wall
  • Easy to install
  • Mounting hardware included
  • Revolutionary tapered bearing provides stronger, smoother pivot points
  • Extends 12" from wall
  • Ships ready-to-assemble
Need professional installation? Use the or the ! Give us a call with any questions!
Specification Description
Model VM3, VM3-b, VM3-s, VM3B
UPC 793795360045
# of Mount Studs 1
Brand Sanus
Color Code Black
Dimensions 4.5W x 14.5D x 6H inches
Extension Distance from Wall 15.25 inches
Flat Panel Width 28 - 37 inches
Material Metal
Mount Adjustability Articulating
Mount Compatibility VESA
Mount designed for Computer Monitors
Mount Size Range (from) 13
Mount Size Range (up to) 30
Placement Wall
Select Wall & Ceiling Mounts
Tilt/Roll Adjustment 15 Degrees Backward
TV Size 19
Type Full Motion Wall Mounts
Type Code Full Motion Mounts
VESA Compliant Yes
Warranty 10 Year Limited Warranty
Weight Capacity 30 lbs
Sanus VM3 VisionMount LCD Wall Mount Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 4, 2009
Sanus VM3 VisionMount LCD Wall Mount Reviews
Most helpful positive review
Most helpful negative review
4.0
A solid piece...
"Installed to hold an LG 23" LCD in a home office. Bracket was sturdy and well made. Conical bearing pivots were a pleasant surpise, wingut tensioners allow proper selectable resistance to movement, especially useful to prevent unwanted tilting. My only real complaints are more to do with wall mounts in general, especially those with LONG articulation capabilities. You need a STRONG attachment to the wall...e..." Read Full Review »
Feb 07, 2008 by Greg B.
See more positive Sanus VM3 VisionMount LCD Wall Mount reviews
1.0
Over rated! This mount doesn't work.
"I was told it would work for my new Sony 26" LCD tv and it would not hold it upright. [...]..." Read Full Review »
Feb 05, 2007 by Son of Mitch
See more negative Sanus VM3 VisionMount LCD Wall Mount reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
A solid piece...
4.0
    Pros
  • Easy To Adjust
  • Interfaces Well With TV
  • Multiple Viewing Angles
  • Sturdy
    Cons
  • Tedious Installation
    Best Uses
  • Office
"Installed to hold an LG 23" LCD in a home office. Bracket was sturdy and well made. Conical bearing pivots were a pleasant surpise, wingut tensioners allow proper selectable resistance to movement, especially useful to prevent unwanted tilting. My only real complaints are more to do with wall mou …"  Read Full Review »
Was this TV Wall Mount review on the Sanus VM3 VisionMount LCD Wall Mount helpful to you?
Feb 7 2008
Greg B.
Keene, NH
I am:
  • Gearhead
  • Professional
  • Tech Savvy
Reviewed at:
Price: $99.99
Works as expected
4.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Home
"The mount is holding a 19" Sharp LCD TV. Its great to be able to swing the TV to view in the kitchen and then while sitting at a table-height breakfast bar that projects into another room. I have read various reviews that reported that the mount would allow the TV to tilt forward and not hold its po …"  Read Full Review »
Sep 30 2008
VERP55
Columbia, MD
I am:
  • Enthusiast
Reviewed at:
[1 of 2 customers found this review helpful]
Good product
5.0
    Pros
  • Easy To Install
    Cons
  • None
    Best Uses
  • Bedroom
"This is the first time we have used this product, but so far are pleased with it, and plan to mount another flat screen TV on the wall in the guest bedroom using the LCD mount. We like the space saving feature and was surprised at how simple it was to mount - if you know where the studs are in your …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Jul 16 2007
Big R
Dallas, TX
I am:
  • Practical
  • Professional
Reviewed at:
Price: $99.99
Sanus VM3 LCD Wall Mount
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
"This product is sturdy, installs very easily, and looks great. Got for a good price also. "
May 3 2008
Matt
Iowa
I am:
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Great Mount for 19" Sharp LCD
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Home
"15" extension, lockable thumb screws at each articulation point, solid build quality "
Jan 4 2009
jmolli
New Jersey
I am:
  • Power User
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
