Sanus VisionMount Speaker Wall Mounts
#85
4.3
based on 12 reviews
Ratings Distribution
5 star
6
4 star
5
3 star
0
2 star
1
1 star
0
Category Average
4.4
$49.99 - $59.99
from 3 stores
More Images
Pros
  • Quality mounting hardware (6)
  • Attractive design (5)
  • Sturdy (5)
  • Easy setup (3)
See less See more
Cons
  • No jam screws for rear (1)
  • Not low profile (1)
  • Securing hardware not inc (1)
  • Shows cables (1)
  • Unstable (1)
Best Uses
  • Saving space (5)
  • Surround sound speakers (5)
  • Wall mounting (4)
  • Improving sound (3)
Provided by CSN Stores
The VisionMount WMS2 Speaker Wall Mount allows for wall mounting larger bookshelf speakers. Clamps adjust in length from 3" to 12" and offers 130 degrees of horizontal motion and 30 degrees of vertical motion.
Specs:
  • Capacity is 15 lbs.
  • Sold in pairs
  • Black finish
  • Dimensions: 5.25" W x 11-15" D x 9.25" H
  • Ships ready-to-assemble
  • For satellite speakers
Assembly Instructions
Sanus VisionMount Speaker Wall Mounts Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Apr 18, 2009
Sanus VisionMount Speaker Wall Mounts Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
4.0
Jam screws missing, possibly unsafe
"I'm familiar with these from an installation performed by a distributor in Tampa, who installed multiple pair of Monitor Audio Silver 3s. I ordered 2 pair myself, and discovered in order to ensure safe mounting, and avoid forward tipping and falling (as noted with the Tampa installer), two pointed screws through the holes in the rear bracket base are required. Without these a user can mount the speakers with eno..." Read Full Review »
Aug 16, 2007 by Grand Rapids Audio guy
See more positive Sanus VisionMount Speaker Wall Mounts reviews
2.0
Watch out for moving speakers
"I was disappointed in this product. The good news is, it is well-made and reasonably easy to install. Attachment to the wall is rock-solid. Unfortunately, the way it holds the speaker is not. The speaker simply sits on a thin arm, with adjustable braces at the front and back. Nothing stops it from moving (or falling) side-to-side. Even the front brace seems short if you have the speaker tilting forward. No saf..." Read Full Review »
Nov 13, 2006 by Samuel
See more negative Sanus VisionMount Speaker Wall Mounts reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
4.0
    Pros
  • Attractive Design
  • Easy Setup
  • Quality Mounting Hardware
    Cons
  • No Jam screws for rear
  • Unstable
    Best Uses
  • Improving Sound
  • Saving Space
  • Surround Sound Speakers
  • Wall Mounting
"I'm familiar with these from an installation performed by a distributor in Tampa, who installed multiple pair of Monitor Audio Silver 3s. I ordered 2 pair myself, and discovered in order to ensure safe mounting, and avoid forward tipping and falling (as noted with the Tampa installer), two pointed s …"  Read Full Review »
Rear bracket illustration and instructions
  • Picture of Product
  • Using Product
Was this Speaker Stand & Mount review on the Sanus VisionMount Speaker Wall Mounts helpful to you?
 Report Abuse  (1)  (0)  0 comments
Aug 16 2007
Grand Rapids, MI
I am:
  • Musically Inclined
  • Professional
  • Tech Savvy
Reviewed at:
Price: $49.99
Good buy
4.0
    Pros
  • Sturdy
    Cons
  • Not low profile
    Best Uses
  • Improving Sound
  • Saving Space
  • Wall Mounting
"I had to wall mount my surround bookshelf speakers since I have an 18 month old daughter. I wanted to cause as little damage to my speakers (drilling) as possible, while securing them safely. The WMS2 did the trick with 12lb. JMLab bookshelf speakers. As with the other reviewers, I had to use 1" sc …"  Read Full Review »
Nov 26 2007
Benjie Borromeo
New York City
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $49.99
Good Item
4.0
    Pros
  • Attractive Design
  • Sturdy
    Cons
  • Securing Hardware Not Inc
    Best Uses
  • Saving Space
  • Wall Mounting
"Just like everyone here says, this product is very good, and at a good price. I would recommend the same as to secure the speakers to the mount. I didn't want to drill my speakers, so used velcro taped to the base and the bottom of the speaker; it is actually very secure, as all you need is to make …"  Read Full Review »
Dec 10 2007
JJ
San Juan, PR
I am:
  • Tech Savvy
Reviewed at:
Price: $49.99
Very sturdy well built
5.0
    Pros
  • Attractive Design
  • Sturdy
    Cons
  • Shows Cables
    Best Uses
  • Improving Sound
"I have aprerion 422 satellite speakers @ 6 lbs each.I got these because speaker just sits in the mount.Mine are not tilted. If you are going to tilt them read other reviews.One has tips how to secure them that the instructions don't mention. Very very sturdy "
Jan 1 2008
Tyler&Bailey's dad
Warwick ,NY
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $49.99
2.0
Unfortunately, the way it holds the speaker is not. The speaker simply sits on a thin arm, with adjustable braces at the front and back. Nothing stops it from …"  Read Full Review »
Nov 13 2006
Samuel
Wilmington, DE
Reviewed at:
Price: $49.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
