#555
based on 34 reviews
Ratings Distribution
| 5 star |
20 |
| 4 star |
10 |
| 3 star |
1 |
| 2 star |
1 |
| 1 star |
2 |
Category Average
$220.59 - $562.10
from 12 storesPros
Cons
Best Uses
Where to Buy
| No Tax Outside NY ends 09/09/15 |
BizRate Rating
Outstanding 9.7
| $1.99 Shipping On Orders Over $100 at TigerDirect |
BizRate Rating
Outstanding 9.1
BizRate Rating
Good 8.8
Product Reviews
[2 of 2 customers found this review helpful]
"I looked at alot of wall mounts before I purchased this one. I bought it a year and a half ago for $350.00. It was alot more money than I wanted to spend, but I figured I would have it, and use it for many years to come. I can't tell you about the other units on the market, but this one works great. I have a 37" TV mounted to it, but someday will use it for a 46". I have it set up where my TV is pointed down sli..." Read Full Review »
Sep 23, 2007 by CorvetteKid
See more positive Sanus 30" to 50" Universal Articulating Flat Panel Mount (VMAA18) reviews
"After you install it, If it does not need to be level, you are good, but if for some reason you need to level it, That is when the big headache begins. They provide an allen wrench, BUT the screws to move to make level are supertigh, The wrench becomes useless, the head of the screws will be deformed because you will try to put the allen wrench in it. it does fit but the force you apply to move the screws will d..." Read Full Review »
Aug 16, 2008 by Roller
See more negative Sanus 30" to 50" Universal Articulating Flat Panel Mount (VMAA18) reviews
Displaying 1 - 5 of 34 Reviews
Sanus 30" to 50" Universal Articulating Flat Panel Mount (VMAA18) Review
Pros
Cons
Best Uses
"After you install it, If it does not need to be level, you are good, but if for some reason you need to level it, That is when the big headache begins. They provide an allen wrench, BUT the screws to move to make level are supertigh, The wrench becomes useless, the head of the screws will be deforme …" Read Full Review »
"I looked at alot of wall mounts before I purchased this one. I bought it a year and a half ago for $350.00. It was alot more money than I wanted to spend, but I figured I would have it, and use it for many years to come. I can't tell you about the other units on the market, but this one works great. …" Read Full Review »
"I selected the Sanus Vmaa18 because I wanted to be able to face my 42in plasma 45 deg left or right in addition to straignt on. I also wanted easy access to the rear connnectors. In addition, I wanted to minimize the distance between the TV and the wall when the cantilever mount was full retracted. …" Read Full Review »
Pros
Cons
Best Uses
"This seemed to be the right wall mount for my new 40" TV. I wanted one to be heavy-duty enough to comfortably support the TV, as well as offering vertical and horizontal tilting. Parts are packaged clearly. Instructions are OK but probably shouldn't be attempted by someone who has never put stuff …" Read Full Review »
"I bought this mount with my Sony XBR4, which was recommended by the BB employee. I read reviews that explained how terribly weak the lags bolts are. I did not even attempt to use the supplied lag bolts. I purchased steel lag bolts from Lowes, which were excellent. Even the Lowes employee commented o …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.7
BizRate Rating
Outstanding 9.1
BizRate Rating
Good 8.8
BizRate Rating
Outstanding 9.2
| $1.99 Shipping on Orders Over $75 ends 12/31/09 | ||||
BizRate Rating
Good 8.8
BizRate Rating
Good 8.7
BizRate Rating
Good 8.8
BizRate Rating
Good 8.5
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
