#4
based on 40 reviews
Ratings Distribution
| 5 star |
35 |
| 4 star |
4 |
| 3 star |
0 |
| 2 star |
1 |
| 1 star |
0 |
Category Average
Low Price:
Trusted:
Pros
Cons
Best Uses
Where to Buy
| No Tax Outside NY ends 09/09/15 |
BizRate Rating
Outstanding 9.7
| Free Shipping for the Holidays ends 12/25/09 |
BizRate Rating
Good 8.8
BizRate Rating
Outstanding 9.2
Product Reviews
"I used this product with an available wider back bracket to mount my 181 pound Panasonic Plasma. It is heavy on its own, and requires two sets of hands during the leveling/wall mounting part of installation. Once it was well secured, it handled the extreme weight without a problem. Aside from needing three people to lift the TV, the only tough part was tightening the locking screws at the end, because of the lim..." Read Full Review »
Dec 24, 2007 by mojofix
See more positive Sanus 27" to 84" Universal Flat Panel Wall Mount with Tilt (VMPL3) reviews
"Even though it says it works for TV's up to 84", it doesn't work for the Panasonic 65" Plasma. The plate that mounts on the wall expands to 42", which is the same width as the screws on the back of the TV. The mount would have worked great if it expanded to 44" so back it goes. I now know this TV requires a Panasonic mount part #ty-wk65pv7, which Best Buy doesn't currently sell...." Read Full Review »
Jan 26, 2008 by MattfromTexas
See more negative Sanus 27" to 84" Universal Flat Panel Wall Mount with Tilt (VMPL3) reviews
Displaying 1 - 5 of 40 Reviews
Sanus 27" to 84" Universal Flat Panel Wall Mount with Tilt (VMPL3) Review
Pros
Cons
Best Uses
Read Full Review »
Pros
Cons
Best Uses
"The screws that came with this mount were too small to fit the TV's rear screw holes (I think this is more a problem with the TV than the mount). A quick trip to Lowe's solved this problem. Installation itself was a snap. This mount comes with 2 different mount choices, a tilt one and a static on …" Read Full Review »
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"Im not much of a handy man, Im the guy that always asks someone else to do it for me.
But I thought I want my 65" LCD Sharp Aquos up tonight so I can start watching HDTV, so I went to the Hardware store & bought the bolts for my TV & a cement drill bit & I was watcthing tv in an Hour. this bracket
Read Full Review »
"I looked at a lot of different models for hanging a Panasonic 58" 750U plasma. It weighs around 150 pounds. I found that this Sanus unit was more than adequate for the job as it is rated for a much higher weight. The weight rating and the fact that it also expands so that you can span 3 studs on you …" Read Full Review »
Pros
Cons
Best Uses
"I'm using this product to wall-hang a 60" plasma TV. It is extremely well designed, and can accommodate almost any conceivable wall mounting situation. It is very sturdy and adaptable. Installation is straighforward. Due to its weight capacity - 280 lbs. - it is quite heavy. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.7
BizRate Rating
Good 8.8
BizRate Rating
Outstanding 9.2
BizRate Rating
Good 8.8
| $1.99 Shipping On Orders Over $100 at TigerDirect |
BizRate Rating
Outstanding 9.1
BizRate Rating
Good 8.8
| Code FALLSAVINGS33 : $5 Off Orders Over $50 |
BizRate Rating
Good 8.7
BizRate Rating
Outstanding 9.4
BizRate Rating
Good 8.8
BizRate Rating
Outstanding 9.4
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
