#57
based on 22 reviews
Ratings Distribution
| 5 star |
15 |
| 4 star |
3 |
| 3 star |
2 |
| 2 star |
0 |
| 1 star |
2 |
Category Average
$47.09 - $89.99
from 14 storesWhere to Buy
| No Tax Outside NY ends 09/09/15 |
BizRate Rating
Outstanding 9.7
BizRate Rating
Outstanding 9.4
BizRate Rating
Good 8.8
Product Reviews
[2 of 2 customers found this review helpful]
"I got this to mount a 26" LCD TV that I didn't need to tilt or swivel. I just wanted a nice clean flush wall mount. It is easy to install and the directions were easy to follow. I had it mounted within 30 minutes of opening the box. It is well constructed of strong steel and should last a lifetime. The TV can be slid from side to side several inches on the mount to aid in centering on the wall. The TV looks grea..." Read Full Review »
May 24, 2009 by HomeTheatreJunkie
See more positive Sanus 15" To 40" Flat Panel Black TV Wall Mount reviews
"I wonder why all those wallmounts are so expensive. We are talking about 3 pieces of metal here. If they price the cars the same way probably they will cost millions. Anyway the install is very easy. Comes with instructions. It depends where your connections are on the TV (on the side or on the back) the TV can be very flushed to the wall...." Read Full Review »
Mar 30, 2009 by al
See more negative Sanus 15" To 40" Flat Panel Black TV Wall Mount reviews
Displaying 1 - 5 of 22 Reviews
Sanus 15" To 40" Flat Panel Black TV Wall Mount Review
"I got this to mount a 26" LCD TV that I didn't need to tilt or swivel. I just wanted a nice clean flush wall mount. It is easy to install and the directions were easy to follow. I had it mounted within 30 minutes of opening the box. It is well constructed of strong steel and should last a lifetime. …" Read Full Review »
Pros
Cons
Best Uses
"I wonder why all those wallmounts are so expensive. We are talking about 3 pieces of metal here. If they price the cars the same way probably they will cost millions. Anyway the install is very easy. Comes with instructions. It depends where your connections are on the TV (on the side or on the back …" Read Full Review »
"I purchased a 40" LCD HDTV and this mount has worked out great. I didn't need a mount that swiveled or tilted, just wanted it to be low profile against the wall. It was an easy installation and has proven to be durable. There is a locking feature to ensure the TV does not get knocked off the wall. I …" Read Full Review »
"Bought "open box" discount. Found that according to the directions you have to center the bracket on a stud! If you're flexible with mounting location this is ok, but I needed to center above my fireplace where there are no studs on center. I considered using the off-center holes to mount (NOT IN TH …" Read Full Review »
"This mount is easy to install and holds my Samsung 32" LCD without a problem. Nice low profile and very easy to remove/replace tv to the wall for cleaning or attaching other components. For the price it cant be beat! "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.7
BizRate Rating
Outstanding 9.4
BizRate Rating
Good 8.8
| $1.99 Shipping On Orders Over $100 at TigerDirect |
BizRate Rating
Outstanding 9.1
| $1.99 Shipping on Orders Over $75 ends 12/31/09 | ||||
BizRate Rating
Outstanding 9.2
BizRate Rating
Good 8.8
BizRate Rating
Outstanding 9.4
| Code FALLSAVINGS33 : $5 Off Orders Over $50 |
BizRate Rating
Good 8.7
BizRate Rating
Good 8.8
BizRate Rating
Good 8.5
| Code SEARS5OFF50 : $5 Off Orders Over $50! |
BizRate Rating
Good 8.2
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
