SanDisk SDSDX3-002G-A21 2GB Extreme III SD Card
#9
4.8
based on 253 reviews
Ratings Distribution
5 star
229
4 star
51
3 star
6
2 star
0
1 star
0
Category Average
4.6
Low Price:
$29.99 at HiTechVendors.com
 Trusted:
$37.68 at pcRUSH
Find it at Amazon
$29.99 - $37.68
from 2 stores
More Images
Pros
  • Large capacity / good size (141)
  • Consistent performance (132)
  • Easy to use (117)
  • Fast (108)
  • Highly compatible (94)
  • Reliable (91)
  • Lightweight (36)
  • Well built / quality construction (29)
  • Convenient interface (28)
  • Writes/reads fast (20)
See less See more
Cons
  • Small capacity (7)
  • A little slow (1)
  • Card-reader problem (1)
  • Exposed contacts (1)
  • Flimsy (1)
  • Have not found any faults (1)
  • Haven't found any yet (1)
  • Incompatible (1)
  • It is fast (1)
Best Uses
  • Cameras (142)
  • Digital photography (55)
  • All-around (29)
  • Digital capture (26)
  • Image storage (24)
  • Computers (20)
  • Image transportation (19)
  • Portable images/multimedia (16)
  • Additional storage (13)
  • Printers (11)
Provided by Beach Audio
MODEL- SDSDX3-2048-901 VENDOR- SAN DISK CORPORATION
FEATURES- Extreme III Secure Digital memory card - 2GB
Serious professional photographers who demand one of the fastest,
most rugged, and most durable memory cards on the market choose
SanDisk Extreme III SD. Built to work under the
most challenging conditions, with SanDisk Extreme III you'll get
more speed, better performance, and unmatched reliability.
That's because only SanDisk Extreme III memory cards feature
innovative ESP Technology for the fastest speeds and highest
performance. ESP stands for "Enhanced Super-Parallel Processing".
Simply put, it means you are getting the fastest read/write speeds
available -- an amazing minimum 18MB per second sequential read and
write speed -- speed you'll definitely appreciate whenever you find
yourself shooting and storing pictures in harsh environments,
extreme temperatures or at high altitudes.
Every SanDisk Extreme III SD card comes with
RescuePRO so you can recover images, documents, mail, video, music
-- just about any digital file, with ease. Built with leading-edge
media recovery algorithms, RescuePro lets you preview recoverable
data before you try to retrieve it. With RescuePRO's unique
recovery algorithm for MPEG audio and MPEG video recovery
(MPEG-1/2/3) what you see, and what you hear, is what you can
recover.
* Designed to meet the critical speed and performance needs of serious
professional photographers--lets you quickly capture, view, upload and
transfer large image files.
* Ideal for demanding photo shoots under severe weather conditions -- heat,
cold, wind, rain, snow, etc.
* Built to perform in the most extreme environments and temperatures --
from -13 to 185 degrees F, -25 to 85 degrees C.
* Minimum 18MB/second sequential read and write.
* Durable, reliable and thoroughly tested -- temperature tested (heat and
cold); shock and vibration tested.
* Data recovery software -- ensures your photos will always be there (even
if you delete them accidentally).
* Dedicated, priority technical support hotline for direct customers of
SanDisk Extreme products.
* Included travel case keeps your memory cards organized.
www.sandisk.com
Specification Description
Model SDSDX3-002G-A21, SDSDX3-2048-901, SDSDX3-2048R, SDSDX3002GA21
UPC 619659022532
Flash Memory Type Secure Digital (SD) Card
Select Capacity 2 GB
Select Card Type Secure Digital Cards (SD)
Storage Size 2 GB
SanDisk SDSDX3-002G-A21 2GB Extreme III SD Card Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 20, 2009
SanDisk SDSDX3-002G-A21 2GB Extreme III SD Card Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
4.0
Quick Precision, Great Buy
"This is the best memory card I've ever had. It processes pictures much faster than an ordinary memory card so that I can continue to take priceless photos. The clarity is very good, and once I have downloaded the pictures to my computer (which is very simple and fast, it only took me about three or four minutes) I can zoom all the way in and crop it and the picture still is high quality. It has easy to use downl..." Read Full Review »
Jan 23, 2009 by Erin: technically challenged
See more positive SanDisk SDSDX3-002G-A21 2GB Extreme III SD Card reviews
3.0
its fast but not that fast
"as a professional photographer, i feel this product could benefit some changes, (obviously based upon my results only) the rate was not at 20mbps but i do appreciate the fact that the price was reasonable for the size and speed, i have also tried products like the "ultra" series wich is a litter faster, but i will most likely never buy anything faster then this for i feel i would be ripped off. but the fact that..." Read Full Review »
Oct 02, 2008 by the flickr
See more negative SanDisk SDSDX3-002G-A21 2GB Extreme III SD Card reviews
Displaying 1 - 5 of 253 Reviews
Show
Sort by
4.0
    Pros
  • Consistent Performance
  • DURABLE
  • Easy To Use
  • Fast
  • High Capacity
  • More »
    Cons
  • None
    Best Uses
  • All-Around
  • Cameras
  • Cell Phones
  • Computers
  • Printers
"This is the best memory card I've ever had. It processes pictures much faster than an ordinary memory card so that I can continue to take priceless photos. The clarity is very good, and once I have downloaded the pictures to my computer (which is very simple and fast, it only took me about three or …"  Read Full Review »
This was taken in the rain, with poor visibility
  • Made with Product
Was this Memory Media review on the SanDisk SDSDX3-002G-A21 2GB Extreme III SD Card helpful to you?
 Report Abuse  (2)  (0)  0 comments
Jan 23 2009
Mill Valley, CaA
I am:
  • Technically Challenged
Reviewed at:
[1 of 1 customers found this review helpful]
Doesn't get any better...
5.0
    Pros
  • Lightweight
  • Reliable
  • Strong Construction
    Cons
  • None
    Best Uses
  • Digital Capture
  • Digital Photography
  • Image Storage
  • Image Transportation
"This little baby packs a punch! It has great access speed and really saves time between photos for me. I have yet to try it at extreme temperatures, but have high hopes since this is supposed to be an area in which this card excels. Only gripe - at the time I bought it, 2 GB was the biggest size …"  Read Full Review »
4th of July
4th of July
  • Made with Product
 Report Abuse  (1)  (0)  0 comments
Jul 15 2007
Shotgun
Denver, CO
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Very Good for the Price!
4.0
    Pros
  • Reliable
    Cons
  • A little Slow
    Best Uses
"From the reviews I made my decision and actually thought this would be a little bit faster than it is. I do rapid shot photography and speed is very important to me.
Otherwise it has done great so far! It would be really great for someone on vacation as it holds 900 photos in my Nikon D40. "
Roping a calf
Roping a calf
  • Using Product
  • Made with Product
Jul 10 2007
Baltimore, OH
I am:
  • Professional
Reviewed at:
Best Buy!!
5.0
    Pros
  • Easy To Use
  • Great Value
  • Large Capacity
  • Reliable Performance
  • Writes/Reads fast
    Cons
  • None
    Best Uses
  • None
"2 GB is the perfect size for quick downloading to my computer. "
Extreme III used with Nikon D80 abd 135mm lens.
  • Made with Product
May 13 2009
Jack, man with a camera
Eden, NY
I am:
  • Semi Pro
Reviewed at:
Boy, that's fast!
5.0
    Pros
  • Great Value
  • Highly Compatible
  • Nice packaging
    Cons
  • None
    Best Uses
  • All-Around
  • Cameras
"After some not-so-lengthy research on the web, I found these cards to be among the fastest for use with my digital SLR (a Nikon D80) as far as read/write speeds were concerned. I bought several of these when I first purchased the camera over a year ago and I haven't had any failures or glitches, ye …"  Read Full Review »
May 20 2008
Scott
San Francisco, CA
I am:
  • Amateur photographer
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
