SanDisk Extreme III SDHC 8GB Card
#3
4.8
based on 574 reviews
Ratings Distribution
5 star
468
4 star
100
3 star
2
2 star
0
1 star
4
Category Average
4.6
Low Price:
$47.95 at Abes of Maine
 Trusted:
$54.95 at B&H Photo Video
Find it at Amazon
$47.95 - $92.00
from 16 stores
More Images
Pros
  • Reliable (450)
  • Large capacity / good size (239)
  • Easy to use (234)
  • Writes/reads fast (224)
  • Fast (213)
  • Lightweight (179)
  • Good value (140)
  • Convenient interface (124)
  • Durable (45)
  • Well built / quality construction (19)
See less See more
Cons
  • Writes/reads slow (5)
  • Capability issues (4)
  • Slow (3)
  • Small capacity (3)
  • Pricey (2)
  • Weak construction (2)
  • Bit overpriced (1)
  • Compatibility (1)
  • Could be faster 30mbs (1)
Best Uses
  • Digital photography (240)
  • Portable images/multimedia (192)
  • Storing images/multimedia (148)
  • Image storage (132)
  • Digital capture (126)
  • Image transportation (95)
  • Cameras (10)
  • Mp3 storage (6)
  • Everyday (4)
  • Travel (4)
Provided by Zappos
The SanDisk Extreme III SDHC 8GB Card with MicroMate Reader is fast, durable and extremely reliable storage for serious professional photographers. Card Features Specifications ; 8 GB Flash memory. ; SD and SDHC compatible card. ; 133x card with minimum 20MB per second sequential read/write speeds. ; Speed rated Class 6. ; Temperature tested to work in -13deg; F to 185deg; F. ; RescuePRO Recovery Software included. ; Travel case for transport. MicroMate USB 2.0 Reader Specifications ; Transfer files between digital devices and computer. ; High-Speed USB 2.0 certified. ; Single slot supports SD and SDHC cards. ; Minimum system requirements: PC or Mac with USB support. Windows 2000/XP or Mac OS X 10.1.2 and later. USB 2.0 port for high-speed transfer. Included ; SanDisk Extreme III SDHC 8GB Card. ; MicroMate Reader. ; Travel case. ; Software CD-ROM.
Specification Description
Model SDSDRX3-8192-A21, SDSDRX38192A21, SDSDX3-008G-A31, SDSDX3-8192-A21
UPC 619659033156
color null
Flash Memory Type Secure Digital High Capacity (SDHC)
SD Card Formats SDHC - SD High Capacity
Select Capacity 8 GB
Select Type Secure Digital Cards (SD)
size null
sku 163034
skuprice 89.9900
Storage Capacity 8GB
Storage Size 8 GB
style SDSDX3008GA31
taxable Y
SanDisk Extreme III SDHC 8GB Card Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 14, 2009
SanDisk Extreme III SDHC 8GB Card Reviews
Most helpful positive review
Most helpful negative review
[13 of 13 customers found this review helpful]
5.0
Very Good, Very Fast, Just what I wanted
"This card is fast enough not to slow down my Canon Xsi in rapid fire sport mode. A string of 15 shots at full resolution did not phase the system. Grandchildren at a socker meet generate once in a lifetime oportunities that come in spurts of pictures, then nothing for a few minutes. I will buy more of this media during the summer...." Read Full Review »
Jun 10, 2009 by Richard
See more positive SanDisk Extreme III SDHC 8GB Card reviews
1.0
8GB Extreme III SDHC by SanDisk
"The card performs well, however my card quit working for me after less tham 3 months. The prongs on the card fell apart and I contacted SanDisk directly for a replacement and they said the problem was physical damage. I feel that for what I paid for the card they should stand behind it and replace it at no charge to me. I feel that you should be able to use a product not just leave it in the case and look at ..." Read Full Review »
Jan 18, 2009 by Whitey
See more negative SanDisk Extreme III SDHC 8GB Card reviews
Displaying 1 - 5 of 574 Reviews
Show
Sort by
5.0
    Pros
  • Great Value
  • Large Capacity
  • Reliable Performance
  • Writes/Reads fast
    Cons
  • None
    Best Uses
"This card is fast enough not to slow down my Canon Xsi in rapid fire sport mode. A string of 15 shots at full resolution did not phase the system. Grandchildren at a socker meet generate once in a lifetime oportunities that come in spurts of pictures, then nothing for a few minutes. I will buy more …"  Read Full Review »
Corbin doing his thing
Was this Memory Media review on the SanDisk Extreme III SDHC 8GB Card helpful to you?
Jun 10 2009
Richard
Greenwood, IN
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $79.95
One of the fastest and reliable Card...
5.0
    Pros
  • Easy To Use
  • Great Value
  • Large Capacity
  • Writes/Reads fast
    Cons
  • None
    Best Uses
"This is the best SDHC card i have ever bought. I bought 3 8GB SDHC Extreme III card. I never had any problem with this card. I use this card in Canon T1i.[...] I always liked Abes of Maine and i dont work for them hehe....Thanks to Abes for good deal on Canon T1i "
This is taken by Canon T1i with 8GB Extrem SDHC
Jul 7 2009
Simpy
New York
I am:
  • Semi Pro
Reviewed at:
Price: $47.95
Amazing performance
5.0
    Pros
  • Convenient Interface
  • Fast
  • Lightweight
  • Reliable
    Cons
  • none
    Best Uses
  • Digital Photography
  • Image Storage
"I use this in my 10 megapixal digital camera, and I get fantastic speed, and color. Each picture comes out clear, with amazing resolution. I get much better results than I did with 2 other different memory cards. "
2 Sexy Woman Rolls, and a Red Dragon Roll, Yumm!
  • Using Product
Jan 25 2009
Farmer Tom
Tampa Bay area
I am:
  • Photo Enthusiast
Reviewed at:
Price: $47.95
1.0
    Pros
  • Fast
  • Lightweight
    Cons
  • Unreliable Storage
    Best Uses
  • Image Storage
"The card performs well, however my card quit working for me after less tham 3 months. The prongs on the card fell apart and I contacted SanDisk directly for a replacement and they said the problem was physical damage. I feel that for what I paid for the card they should stand behind it and replace …"  Read Full Review »
 Report Abuse  (13)  (0)  0 comments
Jan 18 2009
Whitey
Hurricane, UT
I am:
  • Photo Enthusiast
Reviewed at:
Price: $54.95
Great Card So Far!
5.0
    Pros
  • Easy To Use
  • Great Value
  • Large Capacity
  • Writes/Reads fast
    Cons
  • None
    Best Uses
"I've used this for only a few weeks since receiving it, but I'm very comfortable that it's going to work out just perfect. It's fast and, best of all, is supposed to be reliable. I am ordering a second one soon. "
Nov 10 2009
Lee
Denver, CO
I am:
Reviewed at:
Price: $54.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
