SanDisk Cruzer 16GB USB Flash Drive
#4
4.5
based on 121 reviews
from $34.95 - $62.88
Ratings Distribution
5 star
215
4 star
89
3 star
10
2 star
7
1 star
8
Category Average
4.3
Low Price:
$34.95 at B&H Photo Video
 Trusted:
$34.99 at Super Media Store
Find it at Amazon
More Images
Pros
  • Easy to use (246)
  • Large capacity / good size (239)
  • Portable (232)
  • Reliable (220)
  • Easy setup (206)
  • Fast (183)
  • Durable (18)
  • Fast connectivity (17)
  • Quiet (16)
  • Versatile (14)
See less See more
Cons
  • Slow (13)
  • Difficult to set up (7)
  • Difficult to use (6)
  • Flimsy (5)
  • Unreliable (3)
  • Small capacity (2)
  • A little slow (1)
  • Annoying u3 system cd (1)
  • Bad lanyard hook (1)
Best Uses
  • Back-up (212)
  • File transfer (197)
  • Additional storage (170)
  • Music (92)
  • Video (83)
  • Multimedia (18)
  • Travel (17)
  • Laptops (14)
  • Large projects (6)
  • Multiple desktop applications (2)
Provided by OutdoorPros.com
Sandisk SDCZ6-016G-A11 SanDisk Cruzer Micro 16GB (Black) SanDisk Corporation, the inventor and world's largest supplier of flash storage cards, is a global leader in flash memory – from research, manufacturing and product design to consumer branding and retail distribution. Sandisk SDCZ6-016G-A11 SanDisk Cruzer Micro 16GB (Black) Features: • Security-One click password protected access control • Take your files plus U3™ compatible PC programs wherever you go* • Run any U3 programs* • McAfee® 30 day trial antivirus-Protect your PC and USB files • Skype™-Make video or voice calls from PC to PC (not available on Mobile sku's) • CruzerSync®-Synchronize your files and Outlook for access on any PC • No PC installation required to run the applications • For a full list of U3 compatible PC programs, go to www.u3.com • Ideal for Video • * U3 functionality is not supported under Linux or Mac OS (any version), but device is MSC • System Requirements: • Pentium PC or Macintosh computer with USB support • Windows 2000 SP4, XP and Vista • Linux and Mac OS X v10.1.2+ * • USB 2.0 high power required for high speed transfer • Cruzer Micro Package Contents: • • Capacity: 16GB • Cruzer Micro USB Flash Drive • Warranty information
Specification Description
Model 03AE0C68, SDCZ36-016G-A11, SDCZ36016GA11, SDCZ6-016G
UPC 619659050696
Accessory Indicator Yes
Benefits Personalize your drive with your favorite applications using U3Ideal for video, this is the easy way to store, share and play your fa
Capacity UOM mAh
Country Of Origin China
Description Header Take it with you.
Display Catalog Number 25-1111
Enclosure Color Black
Manufacturer Labor Warranty 2
Manufacturer Parts Warranty 2
MAP Price 0.0
Model SDCZ36-016G-A11
New Date Tue Jul 28 00:00:00 CDT 2009
Operating Temperature UOM ° F
Product Type 16GB
Supported Languages English
SanDisk Cruzer 16GB USB Flash Drive Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 18, 2009
SanDisk Cruzer 16GB USB Flash Drive Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
4.0
Cruzers are great; where's the O-ring?
"[...] Cruzers are the best flash drives for both casual and business use because of their easy use and reliability. I bought one for a client to retain their manuscript, and got another for my own use. I often save a client's work product on their flash drive and also on mine, so that they feel their data is completely safe in the event of PC failure.The drawback with this 16gb Cruzer bought from Radio Shack i..." Read Full Review »
Aug 01, 2009 by One Woman, Ink.
See more positive SanDisk Cruzer 16GB USB Flash Drive reviews
3.0
Better without software they install
"Use this product for backup and file transfer. Would have liked to been able to use the password feature without having to load the rest of the software. Uninstalled the software and just use it as a pure storage device. Works fine...." Read Full Review »
Nov 17, 2009 by Lenny
See more negative SanDisk Cruzer 16GB USB Flash Drive reviews
Displaying 1 - 5 of 121 Reviews
Show
Sort by
4.0
    Pros
  • Easy To Setup
  • Easy To Use
  • Fast
  • Great deal
  • High Capacity
  • More »
    Cons
  • Missing standard o-ring
    Best Uses
  • Additional Storage
  • Backup
  • File Transfer
  • Transport client data
"[...] Cruzers are the best flash drives for both casual and business use because of their easy use and reliability. I bought one for a client to retain their manuscript, and got another for my own use. I often save a client's work product on their flash drive and also on mine, so that they feel th …"  Read Full Review »
Cruzer 16gb Flash Drive: with O-ring
  • Picture of Product
Was this Flash Stick review on the SanDisk Cruzer 16GB USB Flash Drive helpful to you?
 Report Abuse  (1)  (0)  0 comments
Aug 1 2009
One Woman, Ink.
Fort Collins, CO
I am:
  • Casual user
[32 of 32 customers found this review helpful]
Awesome Cruzer
5.0
"Pros
Everything. I was up and running in 30 seconds.
Cons
None
Additional Thoughts
I received the Cruzer and figured I was going have to remove software and re-configure the disk from the way reveiws of the other sizes sounded. But, I stuck it in and it asked if I wanted the included software l …"  Read Full Review »
 Report Abuse  (32)  (0)  0 comments
Sep 24 2008
keeper75
New York
Reviewed at:
Price: $59.99
[2 of 2 customers found this review helpful]
Well worth the money
5.0
    Pros
  • Durable
  • Fast Connectivity
  • Quiet
  • Reliable
  • Versatile
    Cons
  • Flimsy Construction
    Best Uses
  • Backup
  • Laptops
  • Multimedia
  • Travel
"This is a great little piece of technology. I carry it with me since all my friends are techgeeks! You can exchange/share videos, music, office productivity (Word, Excell, Publisher, etc.) I like the retractable USB plug but I really love the ability to password protect my contents. It's easy to us …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jul 2 2009
DuMontch5
NYC
I am:
  • Tech Savvy
Reviewed at:
Price: $39.99
Great USB drives
4.0
    Pros
  • Easy To Setup
  • Easy To Use
  • High Capacity
  • Portable
  • Reliable
    Cons
  • U3 Software
    Best Uses
  • Backup
  • File Transfer
"I'm on my third Sandisk cruzer and they are great devices. I still carry my original 1 GB in my bag. My 2nd cruzer 4gb just died on me, but this was due to it being slammed in a door of a computer and it still lasted another 8 months after that. I'm look forward to using my new 16GB drive. The o …"  Read Full Review »
Aug 28 2009
M PRindle
Houston, TX
I am:
  • Power user
Great service on quality product!
4.0
    Pros
  • Easy To Setup
  • Fast
  • Portable
    Cons
  • None
    Best Uses
  • File Transfer
"The 16 GB is large enough to transfer from different computers all the files I would need. As well as acting as a backup for key files. "
Nov 10 2009
Paprgypc
Twin Lake, MI
I am:
  • Power user
Reviewed at:
Price: $39.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
