SanDisk 4 GB Extreme III SDHC Card
#6
4.8
based on 560 reviews
Ratings Distribution
5 star
468
4 star
91
3 star
7
2 star
2
1 star
3
Category Average
4.6
Low Price:
$29.95 at Abes of Maine
 Trusted:
$34.95 at B&H Photo Video
Find it at Amazon
$29.95 - $49.99
from 16 stores
More Images
Pros
  • Large capacity / good size (311)
  • Reliable (291)
  • Easy to use (276)
  • Consistent performance (168)
  • Writes/reads fast (167)
  • Fast (160)
  • Good value (125)
  • Highly compatible (107)
  • Convenient interface (74)
  • Lightweight (74)
See less See more
Cons
  • Incompatible (9)
  • Small capacity (4)
  • Capability issues (3)
  • Corrupts files (2)
  • Unreliable performance (2)
  • Bad for old card readers (1)
  • Big but camara require it (1)
  • Can't visually label it (1)
  • Case too thin and small (1)
Best Uses
  • Cameras (181)
  • Digital photography (143)
  • Portable images/multimedia (137)
  • Storing images/multimedia (101)
  • Image storage (64)
  • Digital capture (55)
  • Image transportation (55)
  • All-around (52)
  • Computers (29)
  • Printers (8)
Provided by Beach Audio
MODEL- SDSDRX3-4096-A21 VENDOR- SAN DISK CORPORATION
FEATURES- Extreme III SDHC Card with Reader- 4GB (4096 MB)
Serious professional photographers who demand one of the fastest,
most rugged, and most durable memory cards on the market should
choose the SanDisk Extreme III SD card. Built to work under the
most challenging conditions, with SanDisk Extreme III you'll get
more speed, better performance, and unmatched reliability.
That's because only SanDisk Extreme III memory cards feature
innovative ESP Technology for the fastest speeds and highest
performance. ESP stands for "Enhanced Super-Parallel Processing".
Simply put, it means you are getting the fastest read/write speeds
available -- an amazing minimum 20MB per second sequential read and
write speed -- speed you'll definitely appreciate whenever you find
yourself shooting and storing pictures in harsh environments,
extreme temperatures or at high altitudes.
Every SanDisk Extreme III SD card comes with RescuePRO so you can
recover images, documents, mail, video, music -- just about any
digital file, with ease. Built with leading-edge media recovery
algorithms, RescuePRO lets you preview recoverable data before you
try to retrieve it. With RescuePro's unique recovery algorithm for
MPEG audio and MPEG video recovery (MPEG-1/2/3) what you see, and
what you hear, is what you can recover.
SanDisk Extreme III expands its award-winning, professional line of
memory cards with a new 4GB SDHC (Secured Digital High Capacity)
card. The SanDisk Extreme III 4GB SDHC memory card offers speed,
performance and reliability to ensure you get your photos every
time. A 4GB memory card can store more than 2,000 high-resolution
pictures or up to 8 hours of MPEG 4 video. As an added bonus, the
card is packaged with a bonus SanDisk MicroMate--a $20 value -- so
that users have a one-stop shop solution for capturing, storing and
transferring their images.
* What is SDHC?
To support the higher capacity needs, SD cards are now requiring a
different design. The new SD 2.0 specifications which supports 4GB and
up, is called Secure Digital High Capacity (SDHC). The SD Association
has created and defined 3 speed classes to help you identify speed and
performance capabilities/minimum requirements of SDHC cards and their
SDHC host products. Details on the SD 2.0 specification:
http://www.sdcard.org or SanDisk.com/SDHC
Cards address data (read and write) at numerous speeds. Many factors
impede this performance. SDHC guarantees a minimum read and write speed
necessary to handle recording high quality video and audio. The maximum
card speed may vary, but you can always depend on SDHC cards to meet
your SDHC host product's high quality performance requirements.
* SDHC Compatibility Information
Because SDHC works differently (supports the new higher capacity cards)
this new card format is not backwards compatible with legacy SD format
host devices.
The SDA speed class rating was developed to identify minimum data
transfer and latency requirements for a host application and provide a
means for consumers to match those requirements with an appropriately
rated SD card. For example, in the emerging application of real-time
video capture (camcorders, camera phones etc), in order to ensure smooth
capture and playback of video, the camera buffer RAM must never
experience a data over-run or under-run. This requires that the card
communicate certain parameters to the camera and then meet some minimum
governing parameters. An SDA speed class rating of 6 means that the
card will be able to transfer (with specifically defined latencies and
data allocation units) data in a random fashion without interruption.
Consumers should look at the intended host device to select the correct
speed class rating in the card they buy. Since speed class 6 is
currently the highest rating defined by SDA, it doesn't necessarily mean
that a speed class 6 is the fastest card that a consumer can buy for all
applications.
By contrast, SanDisk's minimum performance rating of, for example,
20MB/sec on Extreme III cards states the performance level that those
cards will deliver for sequential write and read operations in non-real-
time applications such as file transfers between a card and a computer
or in digital cameras between the camera's buffer and the card. In this
case, the statement of performance allows customers to make a relative
comparison between cards of differing performance and price points.
SanDisk Extreme III cards are also speed class 6 rated.
www.sandisk.com
Specification Description
Model SDSDRX3-4096-A21, SDSDRX3-4096A21, SDSDRX3-4096R, SDSDRX34096A21
UPC 619659033149
color null
Flash Memory Type Secure Digital High Capacity (SDHC)
SD Card Formats SDHC - SD High Capacity
Select Capacity 4 GB
Select Type Secure Digital Cards (SD)
size null
sku 163026
skuprice 54.9900
Storage Capacity 4GB
Storage Size 4 GB
style SDSDX3004GA31
taxable Y
SanDisk 4 GB Extreme III SDHC Card Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 18, 2009
SanDisk 4 GB Extreme III SDHC Card Reviews
Most helpful positive review
Most helpful negative review
[2 of 4 customers found this review helpful]
5.0
Unbelievable Speed
"I bought my first digital camera, a Nikon D70, about 5 years ago. I researched media cards and decided on SanDisk. Well 5 years and 3 Nikon DSLR cameras later I now have 6 SanDisk cards. The 4GB Extreme III class 6 being the newest. I was always happy with the read and write speeds of my cards but I was absolutely shocked at the speed of the new class 6 SDHC Sandisk Extreme III... I downloaded and imported..." Read Full Review »
Feb 27, 2009 by Buddabob
See more positive SanDisk 4 GB Extreme III SDHC Card reviews
3.0
Fast but inconvenient
"We got this card to replace a 2GB Ultra II that was in our camera bag that somebody walked off with. The 4GB Extreme III is fast and has a large capacity; the problem with it is that we can no longer just connect our Canon PowerShot A630 to the computer with a USB cable to download our photos. Now we have to remove the Extreme III card from the camera, insert it into the SanDisk MicroMate reader (that came wit..." Read Full Review »
Sep 01, 2008 by Papa
See more negative SanDisk 4 GB Extreme III SDHC Card reviews
Displaying 1 - 5 of 560 Reviews
Show
Sort by
Unbelievable Speed
5.0
    Pros
  • Consistent Performance
  • Easy To Use
  • Fast
  • High Capacity
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Cameras
"I bought my first digital camera, a Nikon D70, about 5 years ago. I researched media cards and decided on SanDisk. Well 5 years and 3 Nikon DSLR cameras later I now have 6 SanDisk cards. The 4GB Extreme III class 6 being the newest. I was always happy with the read and write speeds of my cards b …"  Read Full Review »
Bald Eagle near St. Augustine FL
  • Using Product
Was this Memory Media review on the SanDisk 4 GB Extreme III SDHC Card helpful to you?
Feb 27 2009
Buddabob
Jacksonville, FL
I am:
  • Tech Savvy
Reviewed at:
Price: $44.00
Excellent performance and capacity
5.0
    Pros
  • Easy To Use
  • Great Value
  • Large Capacity
  • Reliable Performance
  • Writes/Reads fast
    Cons
  • None
    Best Uses
"This card has excellent storage, speed, and performance than other memory cards I have used. I would highly recommend it to anyone. "
Rainbow and Lambchop
  • Made with Product
  • Using Product
Nov 18 2009
LadyArray
Conway, AR
I am:
  • Semi Pro
[1 of 1 customers found this review helpful]
When you need more memory, right NOW!
5.0
    Pros
  • Cost Effective
  • Easy To Use
  • Fast
  • High Capacity
  • Highly Compatible
    Cons
  • None
    Best Uses
  • All-Around
  • Cameras
  • Computers
"When you need to keep up with a new Nikon D90 camera shooting stills quickly, over a prolonged period, the 4g Extreme III stays with you! It was great being able to drop that new SanDisk card in and then just shoot without worrying about running out of space, or waiting for the shots to record. It …"  Read Full Review »
A small part of an Autumn day's capture...
  • Using Product
 Report Abuse  (1)  (0)  0 comments
Oct 13 2008
Tom
Binghamton, NY
I am:
  • Photographer
So far so Good!
5.0
    Pros
  • Lightweight
  • Reliable
    Cons
  • None so far
    Best Uses
  • Digital Capture
  • Digital Photography
"I am using it on a Canon 1Ds Mark ll. It is the back-up card and so far it is working great. "
The Houston Texas Skyline
  • Made with Product
Sep 26 2007
Carl the photographer
Houston, Tx.
I am:
  • Professional
Reviewed at:
Price: $44.00
[3 of 3 customers found this review helpful]
This card is FAST!
5.0
    Pros
  • Convenient Interface
  • Lightweight
  • Reliable
  • Strong Construction
  • Very Fast
    Cons
  • None yet
    Best Uses
  • Digital Capture
  • Image Storage
  • Image Transportation
"I currently shoot with a Nikon D80 & have been using another brand of 2GB 133 speed Pro SD Card. My only complaint with that combo has been when I shoot a series of rapid sequence shots & the buffer fills after six RAW exposures, always stalling my camera at the most inapropriate time. After reading …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Oct 29 2008
Bill
Shennandoah Valley, VA.
I am:
  • Photo Enthusiast
Reviewed at:
Price: $34.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
