SanDisk 2GB Cruzer Micro U3 Smart USB 2.0 Flash Drive
#345
4.3
based on 20 reviews
from $9.99 - $12.99
Ratings Distribution
5 star
375
4 star
251
3 star
54
2 star
21
1 star
27
Category Average
4.3
Low Price:
$9.99 at J&R Electronics
$10.99 at MacMall
Find it at Amazon
More Images
Pros
  • Easy to use (497)
  • Portable (466)
  • Easy setup (374)
  • Fast (365)
  • Reliable (360)
  • Large capacity / good size (320)
  • Well built / quality construction (16)
  • Easy to install (9)
  • Convenient interface (4)
  • Durable (4)
See less See more
Cons
  • Difficult to use (31)
  • Difficult to set up (26)
  • Unreliable (25)
  • Small capacity (17)
  • Slow (10)
  • Flimsy (2)
  • No increase in speed (2)
  • No lanyard (2)
  • Weak construction (2)
Best Uses
  • File transfer (388)
  • Back-up (336)
  • Additional storage (330)
  • Music (92)
  • Video (64)
  • Upgrade (15)
  • Multimedia (7)
  • Multiple desktop applications (7)
  • Photos (6)
  • Replacement (4)
Provided by OnSale
Cruzer Micro 2GB USB U3 Smart Flash Drive (Black) Now ships with U3 smart technology which gives you the ability to carry your files AND your software on a secure USB drive. New retractable USB connector eliminates the need for caps. Cruzer Micro now ships with U3 smart technology. Co-Invented by SanDisk, U3 technology gives you the ability to carry your files AND your software on a secure USB drive. You can have your wallpaper, preferences, favorites, profiles, and more - everything you need for a familiar computing experience on any PC, wherever you go.Includes Skype exclusively on all Cruzer Micro and Cruzer Titanium USB flash drives. Make voice and video calls from PC to PC anywhere in the world.Cruzer Micro allows you to easily carry and transfer key documents, pictures, music and video clips from one computer to another. The new retractable USB port eliminates the need for caps and protects your USB connector.Key Features:
  • Convenient. So light and portable, it can be taken anywhere.
  • Smart design. No more lost caps! Retractable USB connector prevents accidental breakage and prolongs product life.
  • Preloaded with software. Contains valuable Skype, CruzerSync, SignupShield, McAfee 30-day try-and-buy trial software plus a U3 tutorial.
  • U3 enabled. The leading standard for smart-drive computing.
  • Key chain ready. Small size makes it easy to carry with a set of keys. (A preassembled key ring comes with the drive).
  • Affordable. Users can enjoy performance and value in equal measure.
System Requirements:
  • Hi-Speed USB 2.0 certified (backwards compatible with all USB 1.1 ports)
  • Compatible with Windows 2000, SP4 and XP
  • Certified Windows 2000 and XP
  • U3 functionality only supported on Windows 2000 (SP4 and later) & XP OS
What can I store on my U3 smart drive?
  • Photos 1 : up to 4800
  • Songs 2 : up to 480
  • Video - minutes 3 : up to 640
  • Photo: 1 megapixel camera 1600 x 1200 with 5:1 compression = 384KB per image, 8-bits per pixel.
  • MP3 song: 2 song estimated at 4 minutes compressed at 128kb/second x 60 = 7680kb/minute.
  • MPEG Video: 3 MPEG-4 QCIF 1 minute clip = 384kb/second x 60 seconds, or 23,040kb per minute.
Specification Description
Model 619659033736, D4B34043, SDCZ6-2048-, SDCZ6-2048-A10
UPC 619659025380
Accessory Indicator Yes
Age range 12 years and up
Benefits Retractable USB connector; small, portable and U3 smart enabledHi-Speed USB 2.0 certified (backwards compatible with all USB 1.1 port
Capacity UOM mAh
Country Of Origin China
Description Header Cruise into performance overdrive.
Display Catalog Number 55027776
Enclosure Color Black
Manufacturer Labor Warranty 2
Manufacturer Part Number SDCZ6-2048-A11
Manufacturer Parts Warranty 2
MAP Price 0.0
Model SDCZ6-2048-A11
Operating Temperature UOM ° F
Product Depth 2.25
Product Dimensions UOM inches
Product Height 0.31
Product Type 2GB
Product Width 0.811
Required to function Windows 2000, SP4 or XP
Supported Languages English
SanDisk 2GB Cruzer Micro U3 Smart USB 2.0 Flash Drive Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 19, 2009
SanDisk 2GB Cruzer Micro U3 Smart USB 2.0 Flash Drive Reviews
Most helpful positive review
Most helpful negative review
5.0
I would buy this product again and again
"This product came in handy, because I had a presentation and I was able to record everything on this flash drive. Everything went without a hitch...." Read Full Review »
Mar 08, 2008 by Rose
See more positive SanDisk 2GB Cruzer Micro U3 Smart USB 2.0 Flash Drive reviews
3.0
Another U3 infested flash drive, YAY!
"Cruzer is a standard in the flash drive industry, certainly, but users that have older Cruzers won't need yet another copy of (the ever viral) U3 software; at least the newer U3 is easily deleted. I do like the Cruzers retractable design, but I would prefer a physically smaller package since other manufacturers are putting 4Gigs into a thumbnail sized package. Yeah, the others do not retract, but the Cruzers des..." Read Full Review »
Aug 06, 2008 by mmmmna
See more negative SanDisk 2GB Cruzer Micro U3 Smart USB 2.0 Flash Drive reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
cost too high!
4.0
    Pros
  • Easy To Setup
  • Easy To Use
  • High Capacity
  • Portable
  • Reliable
    Cons
  • None
    Best Uses
  • Additional Storage
  • Backup
  • File Transfer
  • Music
  • Video
"great product but was only [$] at Staples.price could be lower. "
Was this Flash Stick review on the SanDisk 2GB Cruzer Micro U3 Smart USB 2.0 Flash Drive helpful to you?
Nov 19 2009
mom
ny,ny
I am:
  • Casual user
[1 of 1 customers found this review helpful]
I will be buying another one!
5.0
    Pros
  • Easy To Install
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Multimedia
"I basically purchased this so that I could transport information, pictures, files, video clips from my home computer to my office computer, etc. I also wanted the capability to store pictures so when I travel I can easily plug in and show distant relatives family pictures. It is extremely user frien …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Oct 29 2007
Vanestle
Dallas, TX
I am:
  • Casual User
Cheap Flash Drive
3.0
    Pros
  • It's inexpensive
    Cons
  • Cheap Enclosure-Bad LED
    Best Uses
  • None
"For the price, it’s a nice flash drive, but the cheap plastic enclosure is a bit disconcerting. No cap to lose is always a good thing. The LED does not function correctly. Sometimes it lights up after insertion, but goes dead a few minutes later. Sometimes it will not light at all. Lately, the LED …"  Read Full Review »
Oct 22 2007
JK
Chicago IL
very good for the price
5.0
"This is very good price for a 2GB flash drive. It is nicely made and it has very good menu to set it up how you would like to use it. I very good buy if you want to save data on something else other than your hard drive. "
Nov 16 2009
tmorri603
Portsmouth, VA
Reviewed at:
Price: $11.99
Purchased this unit for ...
1.0
"Purchased this unit for use as a boot disk for the Ultimate Boot Disk 4 Windows software(UBCD4Win). It works great, was instantly recognized by the BIOS and loaded flawlessly. I have used Sandisk products in the past and have never had a problem. I used the 2 gig version because of the FAT32 file sy …"  Read Full Review »
Nov 5 2009
slickdome
Undisclosed
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
