SanDisk 16GB Extreme IV Compact Flash Card
#12
4.8
based on 63 reviews
Ratings Distribution
5 star
52
4 star
11
3 star
0
2 star
0
1 star
0
Category Average
4.6
$199.00 - $349.99
from 6 stores
More Images
Pros
  • Large capacity / good size (50)
  • Reliable (46)
  • Writes/reads fast (43)
  • Easy to use (42)
  • Good value (22)
  • Fast (9)
  • Consistent performance (6)
  • Highly compatible (5)
  • Convenient interface (3)
  • Durable (3)
See less See more
Cons
  • Pricey (2)
  • A bit pricy (1)
  • Have not found valid con (1)
  • No cons the best (1)
  • No cons wish it was 32gb (1)
  • Price but you knew that (1)
  • Software compatibility (1)
  • Writes/reads slow (1)
Best Uses
  • Portable images/multimedia (36)
  • Storing images/multimedia (21)
  • Cameras (7)
  • Digital photography (4)
  • Upgrade (2)
  • Any photo needs (1)
  • Digital capture (1)
  • Everyday (1)
  • Great for action photos (1)
  • Image storage (1)
Provided by Buzzillions.com
SanDisk 16GB Extreme IV CompactFlash Cards are for the high-end professional photographers, who require the highest possible performance and the largest capacities for their medium format digital camera backs and high-end digital single lens reflex (SLR) cameras. Extreme IV memory cards feature innovative ESP (Enhanced Super-Parallel Processing) technology and utilize the UDMA (Ultra Direct Memory Access) Standard, which involves a process by which data can be moved from a storage device very efficiently, without laboring the host device's processor. Cards that utilize the UDMA standard provide high performance rated at 45 MB/s (266x), and are only compatible with cameras that are UDMA compliant. Every SanDisk Extreme IV CompactFlash card comes with RescuePRO Deluxe so you can recover images, documents, mail, video, music - just about any digital file, with ease. Built with leading-edge media recovery algorithms, RescuePRO Deluxe lets you preview recoverable data before you try to retrieve it. With RescuePRO's unique recovery algorithm for MPEG audio and MPEG video recovery (MPEG-1/2/3) what you see, and what you hear, is what you can recover.
Specification Description
Model SDCFX4-016G-901, SDCFX4016G901, sdcfx4016g901
UPC 619659051853
Compact Flash Format Compact Flash Card
Flash Memory Type CompactFlash (CF) Card
Select Capacity 16 GB
Select Type Compact Flash Cards
Storage Capacity 16GB
Storage Size 16 GB
SanDisk 16GB Extreme IV Compact Flash Card Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
SanDisk 16GB Extreme IV Compact Flash Card Reviews
Displaying 1 - 5 of 63 Reviews
Show
Sort by
SanDisk Awesome
5.0
    Pros
  • Easy To Use
  • Great Value
  • Huge capacity
  • Large Capacity
  • Reliable Performance
  • More »
    Cons
  • None
    Best Uses
  • Nikon sandisk are bff's
"in high res jpg mode i get 1400 pics per card in my d3 nikon! and the rebates actually come! "
  • Using Product
  • Made with Product
  • Using Product
  • Made with Product
Was this Memory Media review on the SanDisk 16GB Extreme IV Compact Flash Card helpful to you?
Sep 2 2009
the bulldog
Miami, Fl
I am:
  • Professional
Reviewed at:
Price: $199.00
[6 of 6 customers found this review helpful]
You mean you dont have one of these yet?
5.0
    Pros
  • Convenient Interface
  • Huge Storage Fast
  • Lightweight
  • Reliable
  • Strong Construction
    Cons
  • Price But you knew that
    Best Uses
  • Professional
"This card is just crazy. I'll just leave Sandisks quality alone, you know how good their cards are. More about the storage and the speed. As the previous poster stated, In full quality raw on a D300 you get over 700 pictures. If you bump it back to Full raw plus jpeg you still get over 500. This car …"  Read Full Review »
 Report Abuse  (6)  (0)  0 comments
Oct 26 2008
Joe Rych
Birdsboro, PA
I am:
  • Pro Photographer
Reviewed at:
Price: $219.95
[10 of 10 customers found this review helpful]
Woah!
5.0
    Pros
  • Durable
  • Easy To Use
  • Improves Product Function
    Cons
  • None
    Best Uses
  • None
"Can you say "space"? What about "speed"?
I've got a 8GB Extreme IV, which I now use as backup and then I've got this baby. It gives me space for about 700 RAW shots on my D300 and works hard and fast to record those images.
Could have gone for two 8GBs but it was more or less the same thing, …"  Read Full Review »
 Report Abuse  (10)  (0)  0 comments
Sep 24 2008
Gabriel
Plantation, FL
Reviewed at:
Price: $219.95
[3 of 3 customers found this review helpful]
Extremely fast CF card!
5.0
    Pros
  • Consistent Performance
  • Easy To Use
  • Fast
  • High Capacity
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Cameras
"Using this card with a Canon EOS 5D Mark II.
Very fast. The 45MB/s write speed means the 5D Mark II can write to the card without interruption; even when shooting sustained full format 21.1 MPixel tandem Raw and JPEG in 3.9 fps Burst mode. I have tested up to 5 seconds of continuous shooting …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Feb 18 2009
Animation Professor
Orange County, CA
I am:
  • Multimedia Professional
  • Tech Professional
  • Tech Savvy
Reviewed at:
Price: $219.95
high speed and large capacity
4.0
    Pros
  • High speed
  • Increased capacity
    Cons
  • A bit pricy
    Best Uses
  • Everyday use
  • Sporting Events
  • Traveling
"Using the card with D700 which takes full advantage of high speed UDMA.
Very handy for sports and other action photography.
High capacity definitely helps especially if you shoot RAW.
It's a bit pricey comparing to competing products from Lexar, but I used both and had a much better luck with San …"  Read Full Review »
Oct 3 2008
photonut
Bay Area, CA
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $219.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
