Samsung UN46B6000 - LUXIA 46" Black LED Flat Panel LCD HDTV
#56
4.6
based on 86 reviews
Ratings Distribution
5 star
65
4 star
14
3 star
3
2 star
2
1 star
2
Category Average
4.4
$1,529.00 - $2,599.00
from 13 stores
More Images
Pros
  • Attractive design (33)
  • High resolution (32)
  • Bright image (31)
  • Good connection options (29)
  • Fast setup (27)
  • Simple controls (23)
  • Reduced glare (18)
  • Lightweight (1)
  • Thin (1)
See less See more
Cons
  • Poor sound quality (13)
  • Low resolution (2)
  • Artifacts on fast motion (1)
  • Backlight fluctuation (1)
  • Bad interface (1)
  • Brightness issues (1)
  • Difficult to set up (1)
  • Glare (1)
  • Narrow viewing angle (1)
  • No wireless internet (1)
Best Uses
  • Home (26)
  • Movies (24)
  • Home theater (20)
  • Wall mounting (20)
  • Bedroom (13)
  • Sports hd viewing (2)
Provided by Buzzillions.com
Full HD-Grade Pixel Resolution - 1080p high-resolution pixel density is combined with a built-in image scaler to handle inputs from a variety of digital and analog audio/video sources. Game Mode - This mode enhances dark areas, sharpens the picture, speeds up the image processing response and enhances the sounds of your games. Picture and sound quality are optimized for the special needs of gaming system with the touch of a button. Ultra Clear Panel - Advanced LCD technology allows you to enjoy crisp image details, natural skin tones, excellent shadow detail and vibrant colors. Auto Motion Plus 120Hz - Auto Motion Plus 120Hz technology keeps even the fastest onscreen motion smooth and natural. Touch of Color - Samsung's unique manufacturing process accents the surrounding bezel with a stylish red tone. Mega Dynamic Contrast Ratio - Experience an incredible level of detail with this Samsung HDTV. A high contrast ratio provides sharper images, more distinct colors and a more realistic appearance. Wide Color Enhancer Pro - Optimizes a given color's hue, resulting in more natural rendering of colors. SRS TruSurround HD - Creates an immersive, feature-rich surround sound experience from two speakers, complete with rich bass, high frequency detail and clear dialogue. Environmentally Conscious - With the same passion we have for delivering groundbreaking HD excitement and style, Samsung is dedicated to preserving the environment with LED TVs, through reduced power consumption (up to 40% savings versus 2008 Samsung conventional LCD TVs) and eco-friendly manufacturing techniques. Connections - HDMI (4), Component Video, USB 2.0 (2), PC, Ethernet, Optical Sound Output.
Specification Description
Model 2397105, UN46B6000, UN46B6000VFXZA
UPC 036725229907
Analog Audio (1) Rear Output
Analog Audio (2) Rear Input
Aspect Ratio 16:9
Component Video Rear Input
Contrast Ratio 1000000:1
DB15 (PC Video) Rear Input
Energy Star Compliant Yes
HDMI (4) Rear Input
HDTV HDTV Tuner Built In
Optical Rear Output
PC Audio Rear Input
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1080
RJ45 Ethernet Rear Input
Screen Size 46"
Screen Size (inches) 46
Stand Included
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port (2) Rear Input
Wall Mountable Yes
Samsung UN46B6000 - LUXIA 46" Black LED Flat Panel LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 9, 2009
Samsung UN46B6000 - LUXIA 46" Black LED Flat Panel LCD HDTV Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Do not listen to the skeptics
"LED pssh. That's what I thought at first when I first got into the market for a new tele. After doing a fair amount of research on the led tech, I found the Samsung UN series to be the best fit for my budget and user requirements. What will I use this for? Probably the same as most people out there in a market for a home video system: Movies Gaming Gen HD Tele Multimedia Files etc User Usability/ Interface:..." Read Full Review »
Jun 19, 2009 by pulpVcious
See more positive Samsung UN46B6000 - LUXIA 46" Black LED Flat Panel LCD HDTV reviews
1.0
Poor picture, horrid audio
"We bought one and am sorely disappointed with the picture quality. I have crisper, sharper images on a cheap Polaroid LCD and the old Sony WEGA looks fantastic. The in store display looked crisp and sharp and they were showing Goldfinger from cable. Also, the audio out jack on this Luxia 6000 46" is defective out of the box. Thankfully the store we bought it from has a 30 day money back satisfaction gaurante..." Read Full Review »
Sep 05, 2009 by kelley maria
See more negative Samsung UN46B6000 - LUXIA 46" Black LED Flat Panel LCD HDTV reviews
Displaying 1 - 5 of 86 Reviews
Show
Sort by
5.0
"LED pssh. That's what I thought at first when I first got into the market for a new tele. After doing a fair amount of research on the led tech, I found the Samsung UN series to be the best fit for my budget and user requirements. What will I use this for? Probably the same as most people out there …"  Read Full Review »
Was this LCD TV review on the Samsung UN46B6000 - LUXIA 46" Black LED Flat Panel LCD HDTV helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jun 19 2009
pulpVcious
Alexandria, VA
Reviewed at:
Price: $1,839.99
More Style than Substance
3.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • Artifacts on Fast Motion
  • Backlight Fluctuation
  • Bad Viewing Angles
    Best Uses
  • Bedroom
  • Home
  • Wall Mounting
"For those wanting an attractive TV when off, this is the creme of the crop. It's glossy black finish and super thin panel look beautiful anywhere you put it. And with Samsung's wall mount (sold separately), you could hang it flush with the wall, just like a picture frame.
However, if your uses …"  Read Full Review »
Oct 29 2009
James K
Los Angeles, CA
I am:
  • Enthusiast
Reviewed at:
Price: $1,588.18
Small issues but I still love it.
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
    Cons
  • Bad Interface
  • Poor Sound
    Best Uses
  • Bedroom
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"I mainly use it connected to a media center PC. I have it connected using a dvi to himi cable. Windows looks great and everything is readable. I plan on trying some games out, but haven't hooked a gaming pc up to it yet.
The image is fantastic once you get all your colors set up in windows. When …"  Read Full Review »
Oct 13 2009
Enjoy
Dayton, OH
I am:
  • Enthusiast
Reviewed at:
Price: $1,588.18
Worth the wait
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • Movies
  • Sports HD Viewing
"Our friends insisted over the past 4 years that we needed to enter the flat screen market. My wife and I chose to wait for prices to level and improvements in technology. After extensive research and viewing numerous options, we selected the Samsung UN46B6000 LED about 2 months ago. It was worth …"  Read Full Review »
Oct 17 2009
LonghornAlum01
Austin,TX
I am:
  • Enthusiast
Reviewed at:
Price: $1,588.18
Sweet TV. Sweet Deal. OneCall Is All....
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Movies
  • Wall Mounting
"Ordered this for Mom. She wanted the thinnest one available.
She is very pleased with the picture this set produces.
And that makes me happy too...........If you know what I mean.... "
Nov 9 2009
Steve
Dallas, TX
I am:
  • Enthusiast
Reviewed at:
Price: $1,847.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
