Close Login Module
Join
Samsung LUXIA 46" Black LED Flat Panel LCD HDTV
#65
4.6
based on 24 reviews
Ratings Distribution
5 star
16
4 star
7
3 star
1
2 star
0
1 star
0
Category Average
4.4
$1,699.00 - $2,799.00
from 10 stores
More Images
Pros
  • Attractive design (20)
  • Bright image (20)
  • High resolution (18)
  • Simple controls (15)
  • Fast setup (14)
  • Good connection options (13)
  • Reduced glare (10)
  • Best picture available (1)
  • Great picture and price (1)
  • Incredibly thin (1)
See less See more
Cons
  • Poor sound (7)
  • Cost factor (1)
  • Difficult to set up (1)
  • More glare than other lcd (1)
  • Needs a sound bar (1)
  • Poor connection options (1)
  • Poor sound quality (1)
  • Pricey (1)
  • Sound could be better (1)
  • Sound is ok (1)
Best Uses
  • Home (14)
  • Home theater (13)
  • Movies (12)
  • Wall mounting (11)
  • Bedroom (5)
  • Apple tv (1)
  • Home gym (1)
  • Nintendo wii (1)
  • Ps3 blu-ray (1)
  • Xbox 360 (1)
Where to Buy
$1,699.00
$1,728.18
BizRate Rating Outstanding 9.1
$2,027.00
Show all 10 stores
Product Reviews
Last update: Oct 20, 2009
Samsung LUXIA 46" Black LED Flat Panel LCD HDTV Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
Unbeleivable Technology all in one box.
"I bought this Monster Samsung UN46b7000 LED TV from Paige, THANKS PAIGE, at ONECALL about a week ago[...] Top Notch. This TV is extremely intimidating from the number of inputs and outputs that it has. You really want to plug absolutely everything into it. But I started with the basics. Digital Cable, Xbox 360, PS3, and an Apple TV all running through HDMI 2.0. All inputs and the tv itself can summed up in ..." Read Full Review »
Apr 14, 2009 by Ace Deucy
See more positive Samsung LUXIA 46" Black LED Flat Panel LCD HDTV reviews
3.0
Unfortunate
"The external audio output, which is essential with this unit considering the understandably poor sound from the integrated speaker, cannot be controlled from the TV's remote. This is a major oversight by the designers. Also, the red trim around the perimeter is not beneficial. However, it is really thin, so if you need to slide your tv under the door occasionally, this is your tv...." Read Full Review »
Aug 06, 2009 by mimi's handyman
See more negative Samsung LUXIA 46" Black LED Flat Panel LCD HDTV reviews
Displaying 1 - 5 of 24 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • Cost Factor
    Best Uses
  • Apple TV
  • Bedroom
  • Home
  • Home Theater
  • Movies
  • More »
"I bought this Monster Samsung UN46b7000 LED TV from Paige, THANKS PAIGE, at ONECALL about a week ago[...] Top Notch. This TV is extremely intimidating from the number of inputs and outputs that it has. You really want to plug absolutely everything into it. But I started with the basics. Digital …"  Read Full Review »
Was this LCD TV review on the Samsung helpful to you?
 Report Abuse  (2)  (0)  0 comments
Apr 14 2009
Ace Deucy
Celebration, Florida
I am:
  • Power User
Reviewed at:
Price: $2,027.00
More than Satisfied
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • More glare than other LCD
    Best Uses
  • Home
  • home gym
  • Home Theater
  • Movies
  • Wall Mounting
"I am currently using it in my home gym. However, I think it is highly suitable to be the center piece of a home theater system. In addition to the great picture, I was impressed by its ability to stream video and audio from my DNLA server on my Linux PC. (I use miniDNLA). Some reviewers criticized t …"  Read Full Review »
Oct 14 2009
Hazem
Oakland, CA
I am:
  • Enthusiast
Reviewed at:
Price: $1,728.18
Great TV with amazing quality!
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • Poor Sound
    Best Uses
  • Bedroom
  • Home
  • Home Theater
  • Wall Mounting
"The picture quality is outstanding, especially when watching Blu-Ray movies. The actors/actresses look so real! Only problem is the sound. The TV does get loud, but seems weird that the sound comes from the back of the television...almost has to echo from off the wall. "
Oct 5 2009
DJ from Jersey
NJ
I am:
  • Casual User
Reviewed at:
Price: $2,027.00
The TV is great - the seller is 50%/50%
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Resolution
    Cons
  • Poor Sound
    Best Uses
  • Home
"i got the TV and the box was closed and on top was taped the wall mount.
the base of the TV was clearly used or refurbished since it's was marked and was missing one of plastic sliders teeth, anyway i was still able to attached it to the TV.
the TV is Great if you watching HD it like you are in th …"  Read Full Review »
Oct 8 2009
Adi
New York NY
I am:
  • Casual User
Reviewed at:
Price: $1,728.18
Simply Awsome Picture
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Resolution
  • Reduced Glare
  • Simple Controls
    Cons
  • Poor Sound
    Best Uses
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"Without question the best picture on the market today. It is too bad it didn't come in a 50 or 52 inch model as I wanted a bigger picture than 46 inches but the 55 inch was too big form my location and way too expensive. After looking at the 46 inch now at home instead of in the store, the size is …"  Read Full Review »
May 23 2009
Valrico Bob
Valrico, Florida
I am:
  • Enthusiast
Reviewed at:
Price: $2,027.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$1,699.00
$1,728.18
$2,027.00
BizRate Rating Outstanding 9.6
$2,029.00
No Tax Outside NY
$2,029.00
$2,029.00
BizRate Rating Outstanding 9.3
$2,029.98
BizRate Rating Outstanding 9.4
$2,029.99
5% off orders at Abt.com
$2,029.99
$2,799.00
Out Of Stock
$2,162.99
BizRate Rating Outstanding 9.0
$2,199.99
$2,999.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
