Samsung LN52B750 52" High Definition LCD HDTV
#5
4.7
based on 140 reviews
Ratings Distribution
5 star
112
4 star
23
3 star
3
2 star
0
1 star
2
Category Average
4.4
$1,713.06 - $2,699.00
from 16 stores
More Images
Pros
  • Attractive design (72)
  • High resolution (71)
  • Bright image (69)
  • Fast setup (63)
  • Good connection options (57)
  • Simple controls (47)
  • Reduced glare (41)
  • Off the chain (1)
  • Picture in picture (1)
  • This tv lets you adjust (1)
See less See more
Cons
  • Poor sound quality (7)
  • Difficult to set up (3)
  • Bad interface (1)
  • Judder motion problems (1)
  • Low resolution (1)
  • Nothing wrong so far (1)
  • Poor connection options (1)
  • Rear plug-in location (1)
  • Weak documentation (1)
Best Uses
  • Home theater (54)
  • Home (45)
  • Movies (41)
  • Wall mounting (26)
  • Bedroom (9)
  • Sd (1)
Provided by OneCall
Auto Motion Plus™240Hz Advanced
processing that reduces blur and enhances image detail when viewing fast motion video sequences.
HD-Grade 1920 (H) x 1080 (V) pixel
resolution High-resolution pixel density is combined with a built-in image scaler to handle inputs from a variety of digital and analog audio/video sources.
Touch of Color™ (ToC)
Samsung’s unique manufacturing process accents the surrounding bezel with a stylish red tone
Response time
A fast 2ms response time minimizes blurring of fast motion in sports programs.
Ultra Clear Panel Advanced LCD technology lets you enjoy crisp image details, natural skin tones, excellent shadow detail, and vibrant colors.
Medi@2.0
  • Internet@TV - Content Service Receive content from Yahoo!®, Flickr®, and more via on-screen TV widgets.
  • DLNA® Sync your connectable home electronics and display remote content on your TV.
  • Pre-loadedContent Library™ (Flash) Enjoy hours of built-in entertainment features, then personalize it by adding content that’s available online.
  • USB 2.0 Movie Show digital home movies, photos, PC presentations and more on your TV, using the remote.
    Wide Color Enhancer3 Optimizes a given color’s hue, resulting in more natural rendering of colors.
    Picture-in-Picture (PIP) Enables convenient, simultaneous viewing of TV programs and video or PC content sources.
    Game Mode enhances dark areas, sharpens the picture, speeds up the image processing response and enhances the sounds of your games. Picture and sound quality optimized for the special needs of gaming systems at the touch of a button.
    Energy Star® Compliant reduces energy consumption by up to 25% compared with standard TVs.
    SRS TruSurround HD™ creates an immersive, feature-rich surround sound experience from two speakers, complete with rich bass, high frequency detail and clear dialog.
    Stereo broadcast reception Supports multichannel sound (MTS) and second audio program (SAP) with 181-channel capacity.
  • Specification Description
    Model LN52B750
    UPC 036725229419
    Analog Audio (1) Rear Output
    Analog Audio (1) Side Input
    Analog Audio (3) Rear Input
    Analog Audio / Video (1) Side Input
    Aspect Ratio 16:9
    Command / Control EX-LINK
    Component Video (2) Rear Input
    Contrast Ratio 150000:1
    Contrast Ratio (Dynamic) 150,000:1
    DB15 (PC Video) Rear Input
    Depth (Inches) 12.0
    Energy Star Compliant Yes
    HDMI (1) Side Input
    HDMI (3) Rear Input
    HDTV HDTV Tuner Built In
    HDTV Native Resolution 1080p
    Height (Inches) 33.8
    Optical Rear Output
    PC Audio Rear Input
    Ports 2 x USB Side
    Refresh Frequency 240Hz
    Remote Control Included
    Resolution 1920 x 1080
    Response Time 2ms
    RJ45 Ethernet Rear Input
    Screen Size 50" to 60"
    Screen Size 52"
    Screen Size (inches) 52
    Select LCD Units
    Speakers 10 Watts x 2
    Speakers Built-in
    Stand Included
    Stand Swivel
    Standard Warranty 1 Year
    Surround Modes SRS TruSurround HD
    Technology HDTV
    Tuner ATSC
    Tuner NTSC
    Tuner QAM
    USB Port (2) Side Input
    Wall Mountable Yes
    Weight (Pounds) 67.5
    Width (Inches) 49.5
    Samsung LN52B750 52" High Definition LCD HDTV Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 3, 2009
    Samsung LN52B750 52" High Definition LCD HDTV Reviews
    Most helpful positive review
    [448 of 468 customers found this review helpful]
    Most helpful negative review
    [34 of 45 customers found this review helpful]
    5.0
    Great for mini home theater
    "I've been an HDTV owner for six years and during that time, I've assisted about two dozen friends in their HDTV home theater setups. I've just upgraded to the Samsung LN52B750 and I couldn't be happier. For reference, I'm upgrading from a Samsung DLP and I own another Samsung LCD HDTV. There's a lot that's misunderstood about this TV, so rather than the usual Pros and Cons, I'd like to share how I'm getting v..." Read Full Review »
    May 17, 2009 by EarlyMon
    See more positive Samsung LN52B750 52" High Definition LCD HDTV reviews
    1.0
    Nice out of box but 1 day later
    "I attached pictures above in the customer gallery to show what happened to my Samsung LN52B750 1 day after it was delivered. Red Green Blue vertical lines appeared on the left half of the screen. This is on all screens from cable tv to media play to hdmi input. TV worked beautifully for 1 day. Has anyone else experienced this problem? Called Samsung for support and a local repair person will come to the ho..." Read Full Review »
    Jun 04, 2009 by A. Alcid
    See more negative Samsung LN52B750 52" High Definition LCD HDTV reviews
    Displaying 1 - 5 of 140 Reviews
    Show
    Sort by
    5.0
    There's a …"  Read Full Review »
    Was this LCD TV review on the Samsung LN52B750 52" High Definition LCD HDTV helpful to you?
     Report Abuse  (448)  (20)  0 comments
    May 17 2009
    EarlyMon
    New Mexico, USA
    Reviewed at:
    Price: $2,699.00
    Samsung LN52B750 52" Black LCD TV
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Home Theater
    • Wall Mounting
    "This TV replaced our old (early 90's) rear projection 300# TV. The old tv was cutting edge technology when we got it and it served us well but it finally died.I did some research and decided on the LN52B750 52" Black Flat Panel Series 7 LCD HDTV by Samsung.I have not been disappointed. The tv has be …"  Read Full Review »
    Samsung LN52B750 52" TV on my wall
    Samsung LN52B750 52
    Jul 5 2009
    Neal A.
    Quincy, IL
    I am:
    • Enthusiast
    Reviewed at:
    Price: $1,778.18
    [51 of 59 customers found this review helpful]
    Almost perfect
    4.0
    "Got this from Amazon at a good price,though I'm sure it will drop a little more as the year goes on.
    This tv is spectacular! Absolutely stunning,jaw dropping picture. I can't say enough about it. Excellent blacks,infinitely tweakable to your liking.
    When I first turned it on I had the "The Office" c …"  Read Full Review »
     Report Abuse  (51)  (8)  0 comments
    Apr 30 2009
    M L
    Frankfort,IL
    Reviewed at:
    Price: $2,699.00
    [41 of 56 customers found this review helpful]
    WAW! Amazing HD Experience
    5.0
    "We waited for 8 months to get our new LCD. After doing research for 15days I went to Fry's to buy LN52A750 last week with $2k budget in my mind. However the sales rep said many people returned that TV because of its very glossy screen and he recommended me to buy LN52630 instead because it has non-r …"  Read Full Review »
     Report Abuse  (41)  (15)  0 comments
    Apr 27 2009
    SUDHIR
    Dallas, Tx
    Reviewed at:
    Price: $2,699.00
    [36 of 42 customers found this review helpful]
    This LCD really is great!
    5.0
    "I know a lot of you are looking at a lot of hdtvs. Let me tell I looked at all the t.vs in best buy to see how they look. I saw the ln46b650 as it stood out from the rest with clarity. So i decided to take a gamble and pre order this one. I even owned a pn50a760 plasma and sent it back because i …"  Read Full Review »
     Report Abuse  (36)  (6)  0 comments
    May 1 2009
    Jarod D. Makowski
    Columbia, NJ USA
    Reviewed at:
    Price: $2,699.00
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
