Samsung LN52A650 52" Series 6 LCD Flat Panel HDTV
4.8
based on 430 reviews
Ratings Distribution
5 star
364
4 star
55
3 star
2
2 star
3
1 star
6
Category Average
4.4
More Images
Pros
  • High resolution (234)
  • Bright image (231)
  • Attractive design (229)
  • Good connection options (206)
  • Fast setup (202)
  • Simple controls (146)
  • Reduced glare (138)
  • Terrific picture (2)
  • 120hz motion plus (1)
  • 120hz very realistic (1)
See less See more
Cons
  • Poor sound quality (13)
  • Bad interface (6)
  • Poor connection options (5)
  • Bedroom or living room (1)
  • Color not as deep as plas (1)
  • Confusing / difficult controls (1)
  • Didn't buy it sooner (1)
  • Difficult to set up (1)
  • Difficult to use (1)
Best Uses
  • Home (171)
  • Movies (140)
  • Home theater (109)
  • Wall mounting (58)
  • Video (35)
  • Bedroom (20)
  • Family room (4)
  • Games (4)
  • Office (4)
  • Living room (2)
Provided by OneCall
Full 1080p HD resolution and 50,000:1 dynamic contrast ratio offer stunning image detail and vivid colors. Auto Motion Plus 120Hz(TM) and Ultra Clear Panel technology work together to offer the smoothest motion and boldest bright and dark tones. Stay connected to the web via the InfoLink RSS feature, with content provided by USA Today. And the WiseLink USB 2.0 input and user-friendly interface gives you access to pictures and playlists from a specially designed Wheel Remote.
HD-Grade 1920 (H) x 1080 (V) pixel resolution: High resolution pixel density with built-in image scaler to handle inputs from a variety of digital and analog audio/video sources.
CCFL—Cold Cathode Fluorescent Lamp: Provides colors in your picture that were not available before.
50,000:1 contrast ratio/500nit brightness: As two of the most important determining factors in overall picture quality, contrast and brightness levels achieve new heights in this latest generation LCD panel. Samsung`s new LCD TV`s give the most stunning realistic picture quality ever from a flat panel set.
Picture-in-Picture (PIP) enables convenient simultaneous viewing of TV programs and video or PC sources.
DNIe(TM) The Samsung Digital Natural Image engine. This exclusive Samsung technology dramatically improves the picture by enhancing the contrast, detail, white balance and reduces.
SRS TruSurround XT(TM): TruSurround is a patented SRS technology that solves the problem of playing 5.1 multichannel content over two speakers. TruSurround delivers a compelling, virtual surround sound experience through any two-speaker playback system, including internal television
Specification Description
Model LN52A650
UPC 036725228221
Analog Audio / Video (1) Rear Input
Analog Audio / Video (1) Side Input
Aspect Ratio 16:9
Coaxial Rear Input
Color Black
Command / Control EX-LINK
Compatible Formats 1080p
Component Video (2) Rear Input
Contrast Ratio 50,000:1
Contrast Ratio 50000:1
DB15 (PC Video) Rear Input
Depth (Inches) 4.1
Dynamic Contrast Ratio 50000:1
Energy Star Compliant Yes
HDMI (1) Side Input
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 1080p
Headphone Jack Side Output
Height (Inches) 34.1
Optical Rear Output
Ports 1 x HDMI Digital Audio/Video Side
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1080
RF (2) Rear Input
RJ45 Ethernet Rear Input
S-Video Rear Input
Screen Format 16:9 Widescreen TV Imaging
Screen Size 50" to 60"
Screen Size 52"
Screen Size (inches) 52
Screen Size (Inches/Diagonal) 52
Select LCD Units
Speakers Yes
Stand Swivel
Standard Warranty 1 Year Limited
Technology HDTV
Tuner ATSC
Tuner NTSC
Tuner QAM
TV Manufacturer’s Warranty (Labor) 1 Year
TV Manufacturer’s Warranty (Parts) 1 Year
USB Port Rear Input
Viewing Angle 178 degrees Horizontal
Viewing Angle 178 degrees Vertical
Width (Inches) 50.2
Samsung LN52A650 52" Series 6 LCD Flat Panel HDTV Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: LN52A650 52" Series 6 LCD Flat Panel HDTV
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 15, 2009
Samsung LN52A650 52" Series 6 LCD Flat Panel HDTV Reviews
Most helpful positive review
[11 of 14 customers found this review helpful]
Most helpful negative review
5.0
Best of the 52's
"Has the best user interface for calibration ever without having to enter the service menu. The colors are precise and consistent across the full spectrum of media from on-air HD signals to SD DVDs to Blu-Ray to Xbox 360 and PS3 Games. After using a calibration disc, I had to tweak a few settings after about 100 hours of use. Since then, the set has been rock-solid. As each input holds it's own calibration setti..." Read Full Review »
Aug 29, 2008 by Toonces T. Cat
See more positive Samsung LN52A650 52" Series 6 LCD Flat Panel HDTV reviews
1.0
Turns off
"As everyone says picture is awesome, but I was one of the lucky ones that got a set that turns off and on by itself every few minutes. I did the firmware upgrate but it didn't help.After a problem with my local tv repairman Samsung told me they would find someone outside my service area to help me, well 2 to 4 days is now 6 days and no word. This is a more common problem than many think but if you roll the dice ..." Read Full Review »
Jan 21, 2009 by KC
See more negative Samsung LN52A650 52" Series 6 LCD Flat Panel HDTV reviews
Displaying 1 - 5 of 430 Reviews
Show
Sort by
Best of the 52's
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Games
  • Movies
  • Video
After using a calibration disc, I had to tweak a few settings …"  Read Full Review »
Film images taken with a Nikon D1X
  • DVD Images - OPPO 983H
Game images taken with a Nikon D1X
  • Game Images - Xbox 360
Was this LCD TV review on the Samsung LN52A650 52" Series 6 LCD Flat Panel HDTV helpful to you?
 Report Abuse  (11)  (3)  0 comments
Aug 29 2008
Toonces T. Cat
Deep South Texas
I am:
  • Engineer
  • IT Professional
  • Tech Savvy
Reviewed at:
[5 of 7 customers found this review helpful]
Impressed
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"I did a lot of research before buying this particular set. It was best rated for the size, (being 52") it has a clear sharp picture, the sound is really good, none of the change in volume as you change chanels, it's like having a movie theatre in your home. We hung it above a fireplace and have tw …"  Read Full Review »
  • Picture of Product
  • Using Product
 Report Abuse  (5)  (2)  0 comments
Jan 7 2009
Queen Swamphag
Whitney Point, NY
I am:
  • Enthusiast
Reviewed at:
[3 of 3 customers found this review helpful]
This Is a Wonderful TV
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • Movies
"Its subdued red outlined bezel looks great,the game mode works great,a smooth clear picture,Superb picture quality, loads of options and settings,wonderful detail deep blacks bright vivid colors. "
 Report Abuse  (3)  (0)  0 comments
Feb 11 2009
KT
Maine
I am:
  • Enthusiast
Reviewed at:
[1 of 1 customers found this review helpful]
BUY IT !!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • Movies
"Excellent 52" LCD TV. I've had my eye on this particular model since it first came out in 2007. Amazing picture, makes regular DVD even look better without having to upgrade to Bluray player. Price was way to good to pass up.[...] Thanks again Abe's of Maine ! "
  • Using Product
 Report Abuse  (1)  (0)  0 comments
Feb 3 2009
Westcoast buyer
Hercules CA
I am:
  • Enthusiast
Reviewed at:
[2 of 5 customers found this review helpful]
LOVE this TV!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"We use this TV in our brightly lit living room. It is mounted above our fireplace.It does have a slight glare, but we mostly watch it at night anyways. The set-up was easy and the connections are great. We love the red trim around it, makes it unique! "
Our new TV
Our new TV
 Report Abuse  (2)  (3)  0 comments
Sep 6 2008
Ethan the Cable Guy
Raleigh, NC
I am:
  • Practical
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
