Samsung LN19A450 19-inch LCD Flat Panel Television
4.5
based on 85 reviews
Ratings Distribution
5 star
53
4 star
25
3 star
5
2 star
1
1 star
1
Category Average
4.4
Pros
  • Attractive design (62)
  • High resolution (56)
  • Fast setup (53)
  • Great picture quality (52)
  • Good connection options (50)
  • Simple controls (47)
  • Wide viewing angle (38)
  • Great sound quality (1)
  • Trendy/stylish dresser (1)
See less See more
Cons
  • Poor sound quality (6)
  • Difficult to set up (3)
  • Absolutely nothing (1)
  • Closed capt is too small (1)
  • Low resolution (1)
  • Narrow viewing angle (1)
  • Nothing bad (1)
  • Onoff delay is long (1)
  • Poor image quality (1)
  • Program info hard to see (1)
Best Uses
  • Kitchen (23)
  • Bedroom (22)
  • Home (22)
  • Office (9)
  • Movies (7)
  • Wall mounting (6)
  • Video (4)
  • Bathroom (1)
  • Camper (1)
  • Pc monitor (1)
Provided by Buzzillions.com
3,000:1 contrast ratio
Contrast and brightness levels achieve new heights in this LCD TV. Watch movies and shows come to life with enhanced details in very dark or bright scenes. Enjoy a more realistic, sharper picture quality that’s sure to catch your eye.
3 HDMI - high definition inputs
Three High Definition Multimedia Interface™ (HDMI) connections make your TV a multimedia centerpiece. Connect HD digital devices like disc players, game consoles and satellite dish components using the 2 rear connections and use the side-mounted input for cameras, camcorders, and laptops.
Entertainment mode
Picture and sound quality are optimized at just the touch of a button. Achieve the ultimate high-definition experience while playing video games, watching sports events and movies.
wide color enhancer 2
Whereas blue, green and red shaded areas of the picture are washed out on conventional screens, wide color enhancer lets you experience more brilliant colors. Simply imagine a wider range of colors than you ever thought possible.
ENERGY STAR compliant
By being ENERGY STAR compliant you are assured that your SAMSUNG model is helping the environment by using less energy while saving you money. ENERGY STAR is a joint program of the U.S. Environmental Protection Agency and the U.S. Department of Energy promoting energy efficiency.
Hidden bottom speakers
Less is more. Just because you can’t see the stylishly concealed speakers doesn’t mean you won’t hear the unbelievably clear sound radiating from them.
Specification Description
Model LN19A450, LN19A450C1DXZA, SAMLN19A450
UPC 036725228320
Analog Audio Rear Input
Aspect Ratio 16:9
Color Black
color null
Compatible Formats 720p
Component Video Rear Input
Composite Video Rear Input
Contrast Ratio 3,000:1
Contrast Ratio 3000:1
DB15 (PC Video) Rear Input
Depth (Inches) 7.1
Dynamic Contrast Ratio 10000:1
Energy Star Compliant Yes
HDMI Rear Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 720p
Headphone Jack Rear Output
Height (Inches) 15.2
Optical Rear Output
Ports 1 x HDMI Digital Audio/Video In Rear
Refresh Frequency 60 Hz
Remote Control Included
Resolution 1440 x 900
RF Rear Input
RS-232C Yes
S-Video Rear Input
Screen Format 16:9 Widescreen TV Imaging
Screen Size 11" to 20"
Screen Size 19"
Screen Size (inches) 19
Screen Size (Inches/Diagonal) 19
Select LCD Units
size null
sku 132634
skuprice 369.9900
Speakers 3W x 2
Stand Included
Stereo Modes SRS TruSurround XT
style SAMLN19A450
taxable Y
Technology HDTV
Viewing Angle 150 degrees Horizontal
Viewing Angle 160 degrees Vertical
Wall Mountable Yes
Weight (Pounds) 11.2
Width (Inches) 18.8
Samsung LN19A450 19-inch LCD Flat Panel Television Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: LN19A450 19-inch LCD Flat Panel Television
See all eBay results
  at eBay.com
Product Reviews
Last update: Jun 10, 2009
Samsung LN19A450 19-inch LCD Flat Panel Television Reviews
Most helpful positive review
[10 of 13 customers found this review helpful]
Most helpful negative review
[2 of 3 customers found this review helpful]
5.0
I would buy it again
"I bought the TV to replace a 13" tube TV that will not be able to receive over the air signals next year when broadcasts go digital. Since I had used my discount coupons for the converter boxes for my two larger TVs, I needed a smaller TV that was easily transportable. I demand a good picture and have always bought top of the line. My son, reported that Samsung was considered by many to be nearly the equal of..." Read Full Review »
Jul 22, 2008 by The professor
See more positive Samsung LN19A450 19-inch LCD Flat Panel Television reviews
3.0
Not a bad tv set for a bedroom
"It's a nice, lightweight tv for a bedroom. However, when I was working out on the floor and looked up at the tv, the colors were off. Otherwise, the colors and sound are just fine. Also, when I connected it to my dvd recorder / vcr, I thought that I did everything correctly, but I was not picking up all of my channels. I didn't have a problem with my other TV (different brand)in the living room when I connect..." Read Full Review »
Mar 09, 2009 by OrchidGirl70
See more negative Samsung LN19A450 19-inch LCD Flat Panel Television reviews
Displaying 1 - 5 of 85 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"I bought the TV to replace a 13" tube TV that will not be able to receive over the air signals next year when broadcasts go digital. Since I had used my discount coupons for the converter boxes for my two larger TVs, I needed a smaller TV that was easily transportable. I demand a good picture and …"  Read Full Review »
Was this LCD TV review on the Samsung LN19A450 19-inch LCD Flat Panel Television helpful to you?
 Report Abuse  (10)  (3)  0 comments
Jul 22 2008
The professor
Merion Station, PA
I am:
  • Tech Savvy
Reviewed at:
[5 of 5 customers found this review helpful]
Performance exceeds expectations
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
"I bought this TV to replace an old CRT-style analog TV (Sony Trinitron WEGA) that was experiencing interference from a neighbor's defective remote (old TV being powered off and on by said defective remote without any action on my part. Since old analog TV (had it not been subject to interference fr …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Jun 2 2008
Donna J
Chicago, IL
I am:
  • Practical
Reviewed at:
[4 of 4 customers found this review helpful]
Decent for bedroom
4.0
"The LN19A450 is a decent TV for the bedroom or other small area. Unlike the larger LN22A450, the screen can tilt up and slightly down with the supplied stand.
The tuner is quite fast compared to many other TV's (I was going for a Sharp until I saw how slow it was.) Changing channels takes about 1 s …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Sep 24 2008
Undisclosed
Reviewed at:
[1 of 1 customers found this review helpful]
Believe the posts about the sound!
4.0
    Pros
  • Attractive Design
  • Fast Setup
    Cons
  • Poor Sound
    Best Uses
  • Bedroom
  • Kitchen
"I bought this TV to replace a 13" CRT in my kitchen. Based on the reviews, it had a stronger digital tuner than most others, important to me because I currently use a rooftop antenna to receive my local broadcasts in HD. I also subscribe to DirecTV and combine the signals received with a signal comb …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 26 2009
shortcircuit
Boyertown, PA
I am:
  • Enthusiast
Reviewed at:
[2 of 2 customers found this review helpful]
Fantastic quality TV!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Resolution
    Cons
  • None
    Best Uses
  • Home
  • Kitchen
  • Office
"Needed a replacement TV for the kitchen. Found out that Samsung will auto-adjust based upon input signal from 4x3 to 16x9. I hate pushing buttons to avoid seeing "fat people" when the aspect ratio changes. Picture is nothing short of amazing for a small TV. Mine is hooked directly to the cabe, …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Dec 2 2008
BLD
New Hampshire
I am:
  • Casual User
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
