Samsung LN-46A650 46-inch Touch of Color 1080p 120Hz LCD Flat Panel HDTV
#2
4.8
based on 362 reviews
Ratings Distribution
5 star
306
4 star
51
3 star
3
2 star
1
1 star
1
Category Average
4.4
Low Price:
$1,499.99 at Adorama
 Trusted:
$1,549.00 at Buydig.com
Find it at Amazon
$1,499.99 - $1,889.00
from 4 stores
More Images
Pros
  • High resolution (167)
  • Attractive design (163)
  • Bright image (163)
  • Fast setup (154)
  • Good connection options (150)
  • Simple controls (103)
  • Reduced glare (90)
  • Sharp image (7)
  • Vivid colors (6)
  • Easy setup (5)
See less See more
Cons
  • Poor sound quality (16)
  • Difficult to set up (3)
  • Remote control (2)
  • Bad interface (1)
  • Bass (1)
  • Blackexterior looks cheap (1)
  • Does not stop glare like (1)
  • I haven't found any yet (1)
  • Instruct manual not clear (1)
Best Uses
  • Home (143)
  • Movies (111)
  • Home theater (70)
  • Wall mounting (37)
  • Bedroom (15)
  • Video (13)
  • Family room (4)
  • Gaming (3)
  • Dorm room (2)
  • Kitchen (2)
Provided by OnSale
LN46A650 46" 1080p 120Hz LCD HDTV with RED Touch of Color 16:9 Aspect Ratio, 50000:1 Dynamic Contrast Ratio, 1920 x 1080 Pixel Resolution, 178/178 Degrees H/V Viewing Angle, (4) HDMI Inputs, (2) Component Inputs, (2) Composite Inputs, ATSC/Clear QAM Tuner 46" High-Definition LCD TVSamsung has reinvented our traditional LCD bezel and gave it a stylish, unique new look with our exclusive Touch of Color. This truly exceptional TV also includes the new InfoLink RSS feature which lets you enjoy instant access to news, weather, sports and stock information. And action scenes have never looked so real with Auto Motion Plus 120Hz and Ultra Clear Panel technology. With too many features to list, the Samsung LN46A650 takes your home entertainment to another level.Touch of ColorMake a statement with Samsung’s new Touch of Color design. It features a hint of amber color naturally blended into the traditional piano black frame. Transforming our already stylish TVs into a work of art, it truly is unlike anything you’ve ever seen.Auto Motion Plus 120HzYour action-packed sports and movies have never looked this real. Auto Motion Plus 120 Hz technology virtually eliminates any motion blur and creates smooth transitions between frames. What’s the secret? Auto Motion Plus calculates the image between frames and inserts it, creating a non-repetitive transition from one to the next. The result is a clearer picture you have to see to believe.4ms Response TimeAn important feature for an LCD panel is the pixel response time. Response time refers to the amount of time it takes a pixel to "refresh" itself-to go from being active to being inactive, (ready to be re-activated). The lower the milliseconds, the faster the response time. A very fast 4 ms response time virtually eliminates any blurring and gives you smooth-motion action scenes.Instant Access to News and MoreWith just a push of a button you can access news, weather, sports and stock information. The InfoLink RSS feature gathers up-to-the-minute content from USA Today and displays it on your screen. Now you can always stay connected while watching TV anywhere in your home.50,000:1 Contrast RatioContrast and brightness levels achieve new heights in this LCD TV. Watch movies and shows come to life with enhanced details in very dark or bright scenes. Enjoy a more realistic, sharper picture quality that’s sure to catch your eye.Ultra Clear PanelWith Samsung’s ultra clear panel colors are more vibrant than ever before. The brighter, clearer picture will definitely amaze you. Tired of annoying glare getting in the way of your movie-watching? Our ultra clear panel technology enhances contrast and rreduces reflection so you can enjoy an overall outstanding viewing experience.Energy Star compliantBy being Energy Star compliant you are assured that your Samsung model is helping the environment by using less energy while saving you money. Energy Star is a joint program of the U.S. Environmental Protection Agency and the U.S. Department of Energy promoting energy efficiency.
Specification Description
Model LN46A650
UPC 036725228214
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (2) Rear Input
Analog Audio / Video Side Input
Aspect Ratio 16:9
Coaxial Rear Input
Command / Control EX-LINK
Compatible Formats 1080p
Component Video (2) Rear Input
Contrast Ratio 50,000:1
Contrast Ratio 50000:1
DB15 (PC Video) Rear Input
Depth (Inches) 11.0
Dynamic Contrast Ratio 50000:1
HDMI (1) Side Input
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 1080p
Headphone Jack Side Output
Height (Inches) 30.5
Optical Rear Input
PC Audio Rear Input
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1080
RJ45 Ethernet Rear Input
S-Video Side Input
Screen Format 16:9 Widescreen TV Imaging
Screen Size 41" to 49"
Screen Size 45"
Screen Size (inches) 46
Screen Size (Inches/Diagonal) 46
Select LCD Units
Speakers 10 Watts x 2
Stand Swivel
Tuner ATSC
Tuner NTSC
Tuner QAM
Viewing Angle 178 degrees Horizontal
Viewing Angle 178 degrees Vertical
Wall Mountable Yes
Weight (Pounds) 58.6
Width (Inches) 44.5
Samsung LN-46A650 46-inch Touch of Color 1080p 120Hz LCD Flat Panel HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 17, 2009
Samsung LN-46A650 46-inch Touch of Color 1080p 120Hz LCD Flat Panel HDTV Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
5.0
This is the one you want!
"I use this TV as a HD monitor for my satellite receiver. I upgraded from a 34 inch CRT HD. The pictures on this Samsung are so sharp, they almost appear 3 dimentional! The screen glare I feared so much turned out to not exist. Movie fans should buy this TV. It has quite a few very nice TV features I don't use because, I connected it to my PC. I use it as a TV monitor as well as a way to display my digital p..." Read Full Review »
Mar 11, 2009 by Don
See more positive Samsung LN-46A650 46-inch Touch of Color 1080p 120Hz LCD Flat Panel HDTV reviews
1.0
Don't buy this LCD TV
"Everything was fine about this TV until I sat down to watch it and found that every light in my room, and every window, was reflected on the screen. LCD should not show reflected lights. I called Samsung and they said there was nothing they could do about it. The reflections make watching this set almost impossible. Of course, you could turn off all your lights and close all your curtains in the middle of the da..." Read Full Review »
Feb 22, 2009 by pbrugalett
See more negative Samsung LN-46A650 46-inch Touch of Color 1080p 120Hz LCD Flat Panel HDTV reviews
Displaying 1 - 5 of 362 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home Theater
  • Movies
It has quite a few very nice TV feat …"  Read Full Review »
Was this LCD TV review on the Samsung LN-46A650 46-inch Touch of Color 1080p 120Hz LCD Flat Panel HDTV helpful to you?
 Report Abuse  (3)  (0)  0 comments
Mar 11 2009
Don
Cleveland, Ohio
I am:
  • Power User
Reviewed at:
[4 of 4 customers found this review helpful]
Amazing television
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • Poor Sound
    Best Uses
  • Home
  • Home Theater
  • Movies
"This TV is my first foray into LCD TV and my first full 1080p set - I upgraded from a smaller 720p/1080i CRT, which I thought looked great when used with the PS3/blu-ray. Well... this TV really showed me a thing or two about HDTV! To really show off its capabilities you really need a blu-ray player …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Jan 17 2009
Trevor
Merced, CA
I am:
  • Enthusiast
Reviewed at:
[8 of 11 customers found this review helpful]
Fantastic TV and Great Price!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • Remote Control
  • Screen smudges
    Best Uses
  • Home
"[...] We haven't upgraded satellite to HD but the picture is still very good. If youre worried about buying online, don't be. This is so much easier than driving to a store, waiting for salespeople, paying a higher price and sales tax[...]and either hauling and carrying a huge heavy box yourself or …"  Read Full Review »
 Report Abuse  (8)  (3)  0 comments
Nov 19 2008
Annette
Ankeny IA
I am:
  • Casual User
Reviewed at:
Price: $1,499.99
Better than 1080p?
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Good Resolution
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home Theater
  • Movies
"What I really don't like about this tv is that it shows picture in 3572 by 2870. Ok, maybe I don't know the exact dimentions. But have you ever looked up people's noses? It is not a pretty site.Attach a flash drive and have some high megapixel pictures. Seriously this has such a good picture, I now …"  Read Full Review »
Jan 3 2009
Jack-- the Knave
Maryland
I am:
  • Enthusiast
Reviewed at:
Love it
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"I spent a lot of time researching/seeing which TV I wanted to purchase for my new condo. I LOVE the Samsung LN46A650. Once I realized that it had that "touch of red" thing you see in the new Scarlet commercials, I was sold. The clarity is AMAZING. (50,000:1 ratio is the highest, by far, of any TV …"  Read Full Review »
Jul 20 2008
Morenoski
San Antonio, TX
I am:
  • Practical
  • Technically Challenged
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
