Samsung HT-X810T 2.1-Channel Home Theater System
3.5
based on 19 reviews
Ratings Distribution
5 star
8
4 star
4
3 star
1
2 star
2
1 star
4
Category Average
4.1
Low Price:
$479.00 at Rainbow Appliance
 Trusted:
$499.98 at Vanns.com
Find it at Amazon
$479.00 - $499.98
from 2 stores
Pros
  • Easy setup (8)
  • Clear sound (7)
  • Interfaces well with tv (7)
  • Thundering bass (5)
  • Confusing / difficult controls (3)
  • Attractive design (1)
  • Great sound for movies (1)
  • Picture quality (1)
See less See more
Cons
  • No sound controls (1)
  • Overwhelming bass (1)
  • Poor interface (1)
Best Uses
  • Movies (6)
  • Living room (5)
  • Larger rooms (4)
  • Surround sound solution (4)
  • Television shows (2)
  • Smaller rooms (1)
Provided by OneCall
Beautiful New Design
This home theater system is wall-mountable with a sleek, modern design that compliments the rest of your living room. It`s the perfect match for your wall-mounted 40" HDTV. The wall mount is included.
USB Host Play
You don't need to burn CDs or DVDs to enjoy music, video clips or photos on your home theater system - just plug a portable digital device into the USB port for instant entertainment.
Bluetooth Capable
This home theater system connects to all of your Bluetooth-enabled devices. Let others in your household enjoy some peace and quiet while you watch and listen to your TV with a wireless Bluetooth headset.
Powerful Sound
Experience the ultimate in sound: 300 watts of RMS power, plus high fidelity audio. SAMSUNG`s Sound Bar home theater system is also enhanced with Dolby Digital(R), Dolby Pro Logic(R) and DTS system, so you hear every detail clearly.
Wireless Subwoofer
A 5.8 GHz subwoofer delivers powerful bass and since the subwoofer is wireless so you can place it anywhere and not have to deal with messy wires.
Specification Description
Model HT-X810, HT-X810T, HTX810, HTX810T
UPC 036725616820
Analog Audio Yes
Built-in DVD Player Yes
Command / Control Anynet +
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Compatible Formats DVD
Compatible Formats DVD Audio
Compatible Formats DVD+R
Compatible Formats DVD+RW
Compatible Formats DVD-R
Compatible Formats DVD-RW
Compatible Formats DiVX
Compatible Formats JPEG
Compatible Formats WMA
Compatible Formats WMV
Disc Player DVD Player - Single
HDMI Yes
Main Features DVD Player
MP3 or iPod Connectivity iPod Dock included
Optical Yes
Play Modes Stereo (2 Channels)
Radio Bands FM
Speakers 2 Satellites + Subwoofer
Surround Modes DTS
Surround Modes Dolby Digital
Tuner FM
Samsung HT-X810T 2.1-Channel Home Theater System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 8, 2009
Samsung HT-X810T 2.1-Channel Home Theater System Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[0 of 2 customers found this review helpful]
5.0
Great product!
"[...]Opened it up and had it all connected and working perfectly in 15 minutes to Samsung 46" LCD TV. Its as simple as plugging in wall, connecting HDMI cable & optical audio cable(neither is included)and included FM antenna. So easy a caveman could do it! I have HD cable box with HDMI connection so Optical cable is for sending TV broadcasts over theater system. Made NFL playoffs awesome. Wireless subwoofer ..." Read Full Review »
Jan 11, 2009 by Rick
See more positive Samsung HT-X810T 2.1-Channel Home Theater System reviews
3.0
Great if you don't care about Blu Ray, Cable audio
"First of all, this is a sleek looking surroundbar and has HDMI out, and Optical, as well as USB inputs. The problems are many though: 1. There is NO HDMI Input. I have PS3, which i mostly use it as a Blu Ray player. Since this unit did not provide an HDMI input, i left my PS3 connected to my LCD. I connected optical out from PS3 to optical in of Samsung Surroundbar. Problem was there there was no sound - either ..." Read Full Review »
Jul 18, 2008 by prsmd
See more negative Samsung HT-X810T 2.1-Channel Home Theater System reviews
Displaying 1 - 5 of 19 Reviews
Show
Sort by
Great product!
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
  • Thundering Bass
    Cons
  • None
    Best Uses
  • Larger Rooms
  • Movies
  • Surround Sound Solution
"[...]Opened it up and had it all connected and working perfectly in 15 minutes to Samsung 46" LCD TV. Its as simple as plugging in wall, connecting HDMI cable & optical audio cable(neither is included)and included FM antenna. So easy a caveman could do it! I have HD cable box with HDMI connection …"  Read Full Review »
Was this Home Theater review on the Samsung HT-X810T 2.1-Channel Home Theater System helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jan 11 2009
Rick
Orlando, FL
I am:
  • Tech Savvy
Reviewed at:
Great for movies, bad for music
4.0
    Pros
  • Attractive Design
  • Easy To Setup
  • Picture quality
    Cons
  • No sound controls
  • Overwhelming bass
  • Poor Interface
    Best Uses
  • Larger Rooms
  • Movies
"This unit has ridiculous amount of uncontrolled, boomy bass from wireless subwoofer. It is fine when watching movies but drastically degrades CD playback and radio experience. If you want to buy this unit as a versatile DVD & CD player, look elsewhere. "
Oct 9 2008
Magellan
Warsaw, Poland
I am:
  • Practical
  • Tech Savvy
Reviewed at:
3.0
1. There is NO HDMI Input. I have PS3, which i mostly use it as a Blu Ray player. Since this unit did not provide an HDMI input, i left my PS3 connected to my LCD. I …"  Read Full Review »
 Report Abuse  (0)  (2)  0 comments
Jul 18 2008
prsmd
Undisclosed
Reviewed at:
Great sound and features
5.0
"Bought this item after a trip to my neighborhood Sears store. The salesman recommended this model. We'd met with Tweeters and were about to go with a custom installation but were not going to be able to get the look we wanted due to the structure of our home. We decided to go with this model for a f …"  Read Full Review »
Jul 23 2008
eal1906
Richmond, Tx
Reviewed at:
Very satisfied with the HT-X810T
5.0
    Pros
  • Clear Sound
  • Easy To Setup
    Cons
  • None
    Best Uses
  • Larger Rooms
  • Living Room
  • Movies
"Products is extremely easy to set up and I was looking for something that didn't have wires all over the house and this product fit the bill. The base sounds great and the DVD quality is great. Highly recommend if your looking for something easy to use and set up. "
Mar 11 2009
chas
Denver area
I am:
  • Technically Challenged
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
