Samsung HL-T5087S 50-inch Slim LED Engine 1080p DLP Rear Projection HDTV
4.4
based on 5 reviews
from
Ratings Distribution
5 star
2
4 star
3
3 star
0
2 star
0
1 star
0
Category Average
4.5
More Images
Pros
  • Attractive design (5)
  • Fast setup (5)
  • Great picture quality (5)
  • Simple controls (4)
See less See more
Cons
  • Poor sound quality (2)
Best Uses
  • Home (5)
  • Movies (5)
  • Office (1)
  • Professional (1)
  • Video (1)
Provided by OneCall
Enjoy more picture and less frame with Samsung's HL-T5087S DLP HDTV. The piano black bezel is just 0.6-inches wide; the set's slim depth lets it fit where others won't. The energy-efficient 50-inch screen features a powerful, long-lasting LED light engine that turns on almost instantly. Full HD 1080p resolution and Samsung Cinema Smooth(TM) technology deliver a wide range of brilliant colors, with bright images and crisp definition. The blackest blacks, brightest whites and nuanced tones are yours with a 10,000:1 dynamic contrast ratio.
Integrated HDTV Tuner with the addition of a suitable UHF/VHF antenna delivers the world of free off-air DTV and HDTV local broadcast channels. An additional QAM tuner decodes unscrambled digital cable signals.
Cinema Smooth(TM) Light Engine
Samsung is the worldwide leader in creating light engines that harness DLP HDTV technology from Texas Instruments. Samsung`s Cinema Smooth light engine brings together the right optics, electronic circuitry and replaceable light source to create a brilliant picture that`s more lifelike and much closer to film. Now in its sixth year of evolution, Samsung`s Cinema Smooth light engine delivers crisp, 1080p High Definition resolution with high contrast and brightness, defined edges and sharp detail.
LED (Light Emitting Diode) for modern color realization
LED replaces arc lamp & color wheel and realizes beautiful color
  • LED will last the life of the TV (No lamp to change)
  • Samsung LED DLP TVs eliminate the need to replace the consumable lamps every few years, and thus have less impact on the environment and on one`s wallet.
  • Ultra-Wide Color Gamut exceeds NTSC defined color space
  • More energy efficient than similar sized flat panel displays
  • Ultra quiet (no color wheel noise)
    Next Generation DLP Chips from Texas Instruments
    Samsung employs a Texas Instruments DLP chip that is comprised of millions of microscopic mirrors. The DLP chip is faster than any other HDTV technology, with the mirrors switching on & off 15,000 times a second to deliver a razor-sharp picture for fast moving images. When combined with Samsung`s new Cinema Smooth light engine, the result is a crisp, bright picture with deep, rich colors that`s closer to film.
    Samsung`s DNIe(TM) - Digital Natural Image Engine
    Samsung`s exclusive Digital Natural Image engine makes the sharpest and clearest images possible, regardless of the profile of input signals. Five image processors and a six-times density enhancer ensure the best picture from any source. Now in its sixth generation (since 2002), DNIe guarantees the truest colors and highest contrast, while virtually eliminating digital artifacts.
    My Color Control
    You can get the pink tones, the green of the grass and the blue of the sky just the way you like, without affecting the other colors on the screen. The three major colors can be adjusted to perfectly fit your taste. Self expression meets display perfection.
    Cinema Mode
    Samsung`s Cinema Mode lets you see colors the way the director intended, by matching them more closely to production standards. This creates more accurate colors and natural skin tones when viewing Hollywood movies on your TV—the perfect setting when enjoying movies with the lights off.
    Cinema Smooth(TM) Film Mode 3:2 Pull Down
    Powered by Samsung`s Cinema Smooth technology, 3:2 Pull Down corrects for the artificial frames created when films are converted to DVDs. The result is a clearer image without the subtle motion artifacts caused by 24-to-30 frames per second video conversion.
    Picture Format Size Adjustment
    Enjoy all your 4:3 aspect-ratio programming in smooth, wide-screen without black bars. Four pre-set aspect ratio modes—Normal, Wide, Zoom 1 and Zoom 2—stretch your image to fill the screen naturally.
    Energy Efficient
    Samsung DLP TVs are more energy efficient than many flat panel TVs, resulting in significant utility savings over the life of the TV.
    Color Temperature Adjustments
    Cool1, Cool2, Normal, Warm1, Warm2 selectable with on-screen display.
    3D Comb Filter dramatically reduces edge image artifacts while improving transition detail.
    Previous Channel returns to the previously viewed channel at the push of a button.
    Game Mode enhances dark areas, sharpens the picture, speeds up the image processing response and enhances the sounds of your games. Picture and sound quality optimized for the special needs of gaming systems at the touch of a button.
    Closed Caption displays dialog that can be read along with encoded broadcast TV programs and pre-recorded videos.
    Non Volatile Memory preserves audio, video and menu settings during power outages.
    Auto Volume Leveler keeps audio volume consistent during channel changing to minimize static sound bursts.
    Discrete IR Codes
    This set is equipped with discrete IR codes for use with an optional macro/programmable remote (see owners manual for details).
    Universal Remote Control permits control of the TV, DVD, VCR and a Tuner/Receiver.
    HDMI (High-Definition Multimedia Interface) addresses both pure digital audio and video performance and simplifies connections from the new generation set-top boxes, HD game consoles, HD Blu-ray(TM) and DVD players by reducing cable connections to one cable and plug.
    DTV and DVD Compatible Connect your DVD and DTV sources with two smart component video (Y/Pb/Pr) inputs that accept 480p/720p/1080i/1080p signals.
    PC
    A Samsung HDTV using DLP technology can also function as a high-quality XGA PC monitor with 1080p compatibility.
  • Specification Description
    Model HL-T5087S, HL-T5087SAX, HLT5087S
    UPC 036725250895
    Analog Audio Rear Input
    Analog Audio Rear Output
    Analog Audio / Video (2) Rear Input
    Aspect Ratio 16:9
    Compatible Furniture or Stand TR500X3B
    Component Video (2) Rear Input
    Contrast Ratio 10,000:1
    DB15 (PC Video) Rear Input
    Depth (Inches) 13.4
    HDMI (3) Rear Input
    HDTV HDTV Tuner Built In
    HDTV Native Resolution 1080p
    Height (Inches) 31.8
    Optical Rear Output
    Projection Type DLP Rear Projector
    Remote Control Included
    Resolution 1920 x 1080
    RF (2) Rear Input
    S-Video (2) Rear Input
    Screen Size 50" Diagonal
    Screen Size (inches) 50
    Select DLP Units
    Speakers 10 Watts x 2
    Stand Optional
    Surround Modes SRS TruSurround XT
    Tuner ATSC
    Tuner NTSC
    Tuner QAM
    USB Port USB 1.1
    Viewing Angle 140 degrees Horizontal
    Viewing Angle 60 degrees Vertical
    Weight (Pounds) 61.3
    Width (Inches) 45.2
    Samsung HL-T5087S 50-inch Slim LED Engine 1080p DLP Rear Projection HDTV Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: HL-T5087S 50-inch Slim LED Engine 1080p DLP Rear Projection HDTV
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Sep 1, 2008
    Samsung HL-T5087S 50-inch Slim LED Engine 1080p DLP Rear Projection HDTV Reviews
    Displaying 1 - 5 of 5 Reviews
    Show
    Sort by
    VERY SURPRISED
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Video
    "Very happy with vivid crystal clear picture, The new L.E.D. light engine replaces the old bright, hot lamp, w/ noisy cooling fan and spinning color wheel. Picute provides deep darkest of dark blacks and vivid picture unlike most flat panel lcd and plasma tv's which can not generate deepblacks. If yo …"  Read Full Review »
    Was this Rear Projection TV review on the Samsung HL-T5087S 50-inch Slim LED Engine 1080p DLP Rear Projection HDTV helpful to you?
    May 11 2008
    David R.
    Bakersfield, CA
    I am:
    • Professional
    Reviewed at:
    Great TV, Great Price
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • Sound could be better
      Best Uses
    • Home
    • Movies
    "Great TV, great alternative to pure flat screens. LED light source is great. HD picture is equal to higher end flat screens. Only thing that could improve is the sound. Could definitely use an added sound system. "
    Aug 30 2008
    psustang
    Butler, PA
    I am:
    • Gearhead
    • Practical
    • Professional
    Reviewed at:
    Definitely worth the money.
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • Sound quality just ok
      Best Uses
    • Home
    • Movies
    "Great television for the price. Recommended it to family member who purchased next higher model # because this one was sold out. Sound quality is not great when watching movies - but easily rectified with an add-on system. Overall: great tv. "
    Sep 1 2008
    TV watcher
    Honeoye Falls, NY
    I am:
    • Tech Savvy
    Reviewed at:
    Everything was great
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    "Everything was great the product is the best. The [...] set up great. "
    Apr 18 2008
    Mobeta
    Bronx, New York
    I am:
    • Couch Potato
    • Practical
    Reviewed at:
    Loyal Samsung Owner
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Office
    • Professional
    "Outstanding picture quality "
    Aug 30 2008
    Jay Dilla
    Dallas, TX
    I am:
    • Tech Savvy
    Reviewed at:
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
