Samsung DVD-V6800 Multi-System DVD Player/VCR Recorder Combo
1.7
based on 3 reviews
from
Ratings Distribution
5 star
0
4 star
0
3 star
1
2 star
0
1 star
2
Category Average
3.8
Pros
  • Durable (1)
  • Easy to use (1)
See less See more
Cons
  • Difficult to set up (1)
  • Difficult to use (1)
  • European connections (1)
  • Flimsy (1)
Best Uses
  • Home (1)
Provided by B&H Photo Video
Samsung DVD-V6800 Multi-System DVD Player/VCR Recorder Combo Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DVD-V6800 Multi-System DVD Player/VCR Recorder Combo
See all eBay results
  at eBay.com
Product Reviews
Last update: Nov 5, 2009
Samsung DVD-V6800 Multi-System DVD Player/VCR Recorder Combo Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 2 customers found this review helpful]
The price corresponds. But...
3.0
    Pros
  • Durable
  • Easy To Use
    Cons
  • Flimsy Construction
    Best Uses
  • Home
"Particularly my item.
The VCR makes IN a PAL or NTSC signal well but
when you try to play it using the multisystem TV the VCR
gives very bad signal. I put the tape on other multisystem VCR, it is
played well. In general the VCR badly plays any video signal- PAL /
NTSC. Sound is fine. I did not …"  Read Full Review »
Was this DVD Player & Recorder review on the Samsung DVD-V6800 Multi-System DVD Player/VCR Recorder Combo helpful to you?
 Report Abuse  (1)  (1)  0 comments
Apr 22 2009
Gena
Sacramento
I am:
  • Power User
Reviewed at:
It's a European machine
1.0
    Pros
  • None
    Cons
  • European Connections
    Best Uses
  • None
"I can't really tell if it's a good product or not. I wound up returning it because it's a European machine. It might be possible to use it in the states, but that would require buying different cords and fixtures, since all of the connections are in European format. I think it's also DVD region 2 …"  Read Full Review »
Sep 20 2009
JM
San Diego, CA
I am:
  • Casual User
Reviewed at:
Not for U.S.
1.0
    Pros
  • None
    Cons
  • Difficult To Set Up
  • Difficult To Use
    Best Uses
  • None
"The coaxial input and out put on this machine is not for standard coaxial cable. "
Nov 5 2009
video griffter
charlotte, NC
I am:
  • Power User
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
