Samsung DVD-1080P7 DVD/VCR Combo
3.2
based on 6 reviews
from
Ratings Distribution
5 star
1
4 star
1
3 star
3
2 star
0
1 star
1
Category Average
3.6
More Images
Pros
  • Easy setup (5)
  • Great picture quality (4)
  • Easy to use (3)
  • Attractive design (1)
  • Consistent performance (1)
See less See more
Cons
  • Flimsy (3)
  • Inconsistent (2)
  • Lower quality than before (1)
  • Tray gets stuck (1)
  • Unattractive design (1)
Best Uses
  • Home (5)
  • Movies (1)
  • Tv (1)
Provided by B&H Photo Video
The Samsung DVD-1080P7 DVD Player brings your home theater experience to a whole new level with superb HD DVD imagery and exquisite digital audio sound. Your current DVD library will look and sound better than ever before, because the DVD-1080P7 is a progressive-scan DVD player, capable of upconverting your DVDs to a 720p/1080i and 1080p high-definition experience. With the DVD-1080P7, enjoy the awesome power of Dolby Digital and DTS digital audio for a wider, more enveloping surround-sound experience. In addition, the DVD-1080P7 presents superb functionality and high-end features that will be hard to match, such as Samsung's EVQ Processing, HDMI CEC, DivX Certified, component video output, optical/coaxial audio outputs, and 192KHz/24-Bit audio processing. With connectivity to multiple A/V components and multi-format playback capabilities, the Samsung DVD-1080P7 answers the call with versatility and reliability.
Specification Description
Model DVD-1080P7, DVD-HD1080P7/XAA
UPC 036725607743
Analog Audio (1) Rear Output
Coaxial (1) Rear Output
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Compatible Formats DVD
Compatible Formats DVD+R
Compatible Formats DVD+RW
Compatible Formats DVD-R
Compatible Formats DiVX
Compatible Formats JPEG
Compatible Formats MP3
Compatible Formats MPEG4
Compatible Formats WMA
Component Video (1) Rear Output
Composite Video (1) Rear Output
D/A Converter 14-bit/108MHz (Video)
D/A Converter 24-bit/192kHz (Audio)
Depth (Inches) 11.4
Disc Capacity 1
Disc compatibility (Play) CD - CDR/W - DVD - DVDR/W
DiVX Play Compatible Yes
DVD Disc Compatibility (Record) DVD Play Only - Does not record
DVD Dual Layer Play Compatible Not Applicable
DVD Dual Layer Record Compatible Does not Record
HDMI (1) Rear Output
Height (Inches) 5.2
Manufacturer’s Warranty 1 Year
Optical (1) Rear Output
Power Supply 110 Volts AC
Progressive Scan Yes
Remote Control Included
S-Video (1) Rear Output
Surround Modes Dolby Digital
TV Broadcast Compatibility NTSC
Type of DVD Unit Component DVD Player
Video Standard Up to 480p
Weight (Pounds) 7.1
Width (Inches) 20.4
Samsung DVD-1080P7 DVD/VCR Combo Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DVD-1080P7 DVD/VCR Combo
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 7, 2008
Samsung DVD-1080P7 DVD/VCR Combo Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
They were better before
3.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • High Quality Picture
    Cons
  • Flimsy Construction
  • Tray gets stuck
    Best Uses
  • Home
"I have had other Samsung DVD player's, in fact a previous version to this one. Even though performance and image quality is still very good, the construction is just not that good anymore, the plastics on the player seem and feel cheaper, and it is very noticeable in the remote. Also de dvd tray doo …"  Read Full Review »
Was this DVD Player review on the Samsung DVD-1080P7 DVD/VCR Combo helpful to you?
Dec 19 2007
I just want good quality...
Los Angeles, CA
I am:
  • Tech Savvy
Reviewed at:
Does The Job
4.0
    Pros
  • Consistent Performance
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
"I like everything about the Samsung DVD player except the little red light that won't turn off -- reminding me that manufacturers still haven't got the message that consumers want to conserve in small ways as well as the big ones. When Mr. Samsung sees the windmill going up in his backyard, he'll u …"  Read Full Review »
Jul 22 2008
easyed
Somers, NY
I am:
  • Couch Potato
  • Practical
  • Professional
  • Retired looking forward
I have never bought Samsung before
3.0
    Pros
  • Easy To Set Up
    Cons
  • Unattractive Design
    Best Uses
  • Home
"I guess I was expecting more. Picture isn't any better than the Harmon Kardon DVD carosel player that I had before.
It seems to be cheap construction, shinny reflecting plastic front that makes it almost
impossible to read what is behind it.
I have had to play with the DVD tray opening and clos …"  Read Full Review »
Oct 4 2007
Ben
San Quentin, CA
I am:
  • Practical
Reviewed at:
Ok Player, Does not do well with Netflix
3.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • Inconsistent
    Best Uses
  • Home
"This is an ok, very low cost HDMI player.
I'd give it higher points but it's error correction is not that great. So if you like to use Netflix be prepared to clean 75% of your DVD's before you even put them in the player. "
Aug 7 2008
Lucky Guy
Boston
I am:
  • Tech Savvy
Reviewed at:
Bad experience with Samsung HD1080P7
1.0
    Pros
  • None
    Cons
  • Inconsistent
    Best Uses
  • None
"This player felt flimsy to me out of the box. I was able to play ONE movie before it started "stalling" as the movie played. Next, the DVD display began showing erroneous characters. I am returning this player. I finally purchased Panasonic-S97S. This is a GREAT player; very well constructed and a g …"  Read Full Review »
Sep 10 2007
CB
Jackson, MS
I am:
  • Tech Savvy
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
