Samsung 72" Slim Depth 1080p DLP HDTV
4.6
based on 16 reviews
Ratings Distribution
5 star
11
4 star
4
3 star
1
2 star
0
1 star
0
Category Average
4.5
More Images
Pros
  • Attractive design (15)
  • Great picture quality (15)
  • Fast setup (14)
  • Simple controls (8)
  • Good value (1)
  • Nice value (1)
See less See more
Cons
  • Confusing / bad remote control (1)
  • Controls (1)
  • Flimsy (1)
  • Poor image quality (1)
  • Worked one day (1)
Best Uses
  • Home (13)
  • Movies (12)
  • Video (4)
  • Office (1)
  • Professional (1)
Provided by Abt Electronics
Samsung 72" Slim Depth DLP HDTV - HLT7288W/ Cinema Smooth 1080p Light Engine/ Full HD 1920 x 1080p/ 10000:1 Contrast Ratio/ Full Digital NTSC/ATSC Tuners WithClear QAM/ Picture In Picture/ Game Mode/ SRS TruSurround XT/ Black Finish
Specification Description
Model HL-T7288W, HLT7288W, TR72BX
UPC 036725272880
Aspect Ratio 16:9
Card Slot CableCARD
Command / Control G LINK
Compatible Furniture or Stand TR72B
Component Video (2) Rear Input
Composite Video (3) Rear Input
Composite Video Rear Output
Contrast Ratio 10,000:1
DB15 (PC Video) Rear Input
Depth (Inches) 20.4
DVI Rear Input
HDMI (2) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Height (Inches) 46.8
Optical Rear Output
PC Audio Rear Input
Projection Type DLP Rear Projector
Remote Control Yes
Resolution 1920 x 1080
RF (2) Rear Input
RS-232C Rear In/Out
S-Video (2) Rear Input
Screen Size (inches) 72
Speakers 10 Watts x 2
Stand Optional
Stereo Modes MTS Stereo
Tuner ATSC
Tuner CableCARD
Tuner NTSC
Tuner QAM
USB Port Rear Input
Weight (Pounds) 104.5
Weight (Pounds) 129.9
Width (Inches) 65.8
Samsung 72" Slim Depth 1080p DLP HDTV Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 72" Slim Depth 1080p DLP HDTV
See all eBay results
  at eBay.com
Product Reviews
Last update: Nov 12, 2008
Samsung 72" Slim Depth 1080p DLP HDTV Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Outstanding picture, great features!
"Except for the flimsy bezel possibly causing a little bowing of the image, the picture quality is amazing and the features are great. [...] a fantastic deal on this set and it's probably the best value on the market in the 70" and larger market for RPTV. A few small tweaks to the picture (turn off DNIe, movie mode, warm 2, lower brightness, contrast, and sharpness) and it was awesome. HD content off DirecTV l..." Read Full Review »
Jul 09, 2007 by Brian
See more positive Samsung 72" Slim Depth 1080p DLP HDTV reviews
3.0
A lesson in patience
"Great picture ... once we got it to work. Set was delivered looked great. About 4 hours after the installer left, it turned off and would not turn back on unless it was allowed to sit for a while. The service shop discussed the failure with Samsung service and then came back to our house to "fix" the TV. Unfortunately, since the failure was intermittent, it was going to be difficult to see if the fix really w..." Read Full Review »
Aug 30, 2008 by Coach potato
See more negative Samsung 72" Slim Depth 1080p DLP HDTV reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Great value
  • Simple Controls
    Cons
  • Flimsy bezel
    Best Uses
  • Home
  • Video
"Except for the flimsy bezel possibly causing a little bowing of the image, the picture quality is amazing and the features are great. [...] a fantastic deal on this set and it's probably the best value on the market in the 70" and larger market for RPTV. A few small tweaks to the picture (turn off …"  Read Full Review »
Was this Rear Projection TV review on the Samsung 72" Slim Depth 1080p DLP HDTV helpful to you?
 Report Abuse  (2)  (0)  0 comments
Jul 9 2007
Brian
Raleigh, NC
I am:
  • Gearhead
  • Practical
  • Tech Savvy
Reviewed at:
3.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
    Cons
  • Worked one day
    Best Uses
  • Home
  • Movies
"Great picture ... once we got it to work. Set was delivered looked great. About 4 hours after the installer left, it turned off and would not turn back on unless it was allowed to sit for a while. The service shop discussed the failure with Samsung service and then came back to our house to "fix" …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Aug 30 2008
Coach potato
Clifton Forge
I am:
  • Practical
Reviewed at:
Fantastic
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"I love this Television; when I am watching a sporting event it is like having little midgets running around my living room. Quality is exceptional on my HD channels. It is extremely lightweight so it is easily manueverable. I highly recommend it to anyone. Also One Call has been exceptional. Th …"  Read Full Review »
Sep 5 2008
Edge
Los Angeles, Ca.
I am:
  • Professional
  • Tech Savvy
Reviewed at:
I would purchase again
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
    Cons
  • None
    Best Uses
  • Movies
"Great size for my theater room. Easy setup. Great picture when I play movies on my BlueRay disc player. The picture is not as good when I watch HD over my Dishnetwork receiver. Some of the detail is a little hazy. Picture not as good as my smaller HD TV but the size and price make up the differ …"  Read Full Review »
Sep 2 2008
Tutman
Tuscaloosa, Alabama
I am:
  • Professional
Reviewed at:
It broke
4.0
    Pros
  • Attractive Design
  • Great Picture
    Cons
  • None
    Best Uses
  • Home
"One week after getting TV and setting it up it broke. Monster Cable surge protector. No apparent damage from shipping. Worked great and then it just died one week later. Samsung arranged for a technician and motherboard had to be replaced. It works now. Keeping my fingers crossed. "
Aug 29 2008
avejoe
california
I am:
  • Gearhead
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
