Samsung 61-inch Slim 1080p DLP Rear Projection HDTV (HL-T6176S)
4.6
based on 17 reviews
Ratings Distribution
5 star
10
4 star
7
3 star
0
2 star
0
1 star
0
Category Average
4.5
More Images
Pros
  • Attractive design (15)
  • Fast setup (15)
  • Great picture quality (15)
  • Simple controls (14)
  • Awesome (1)
  • Easy to use (1)
  • Im glad i made this purc (1)
  • Lighter than my 32 inch (1)
See less See more
Cons
  • Big doglittle bark (1)
  • Muffled sound (1)
  • The sound need help (1)
  • Wimpy housing (1)
Best Uses
  • Home (15)
  • Movies (13)
  • Video (8)
  • Games (1)
  • Office (1)
  • Professional (1)
  • Video games (1)
  • Wii and xbox360 (1)
Provided by OneCall
Fill your room with the riveting 1080p Full HD resolution and brilliant sound of the Samsung HL-T6176S. Its 0.8-inch-thin piano-black bezel and hidden speaker system let you enjoy more screen and less frame; the slim depth lets the 61-inch DLP(R) HDTV fit where others won't(TM). Enjoy the crisp definition and bright imagery of Samsung's Cinema Smooth(TM) 1080p Light Engine; a phenomenal 10,000:1 dynamic contrast ratio delivers the full range of vivid colors, bright whites, deep blacks and nuanced tones. SRS TruSurround XT(TM) audio fills the room with clear, robust sound. Fast, 16 micro-second switching speed virtually eliminates motion blur; Game Mode optimizes performance so gamers will marvel at the lifelike action. Full digital connectivity with 3 HDMI ports allows digital connectivity to Cable/Satellite boxes Blu-ray players, AV receivers, and more.
Integrated HDTV Tuner with the addition of a suitable UHF/VHF antenna delivers the world of free off-air DTV and HDTV local broadcast channels. An additional QAM tuner decodes unscrambled digital cable signals.
Cinema Smooth(TM) Light Engine
Samsung is the worldwide leader in creating light engines that harness DLP HDTV technology from Texas Instruments. Samsung`s Cinema Smooth light engine brings together the right optics, electronic circuitry and replaceable light source to create a brilliant picture that`s more lifelike and much closer to film. Now in its sixth year of evolution, Samsung`s Cinema Smooth light engine delivers crisp, 1080p High Definition resolution with high contrast and brightness, defined edges and sharp detail.
Cinema Smooth 1080p Light Engine
Samsung`s Cinema Smooth 1080p light engine is the culmination of years of industry leading research and development. It releases the maximum power of the new generation of DMD microdisplays for the most film-like picture. It creates an image with no visible pixel structure and accurate shading and better low-light detail.
Next Generation DLP Chips from Texas Instruments
Samsung employs a Texas Instruments DLP chip that is comprised of millions of microscopic mirrors. The DLP chip is faster than any other HDTV technology, with the mirrors switching on & off 15,000 times a second to deliver a razor-sharp picture for fast moving images. When combined with Samsung`s new Cinema Smooth light engine, the result is a crisp, bright picture with deep, rich colors that`s closer to film.
Faster 5 Segment Color Wheel for High Contrast and Brightness
Samsung`s 2.2 color wheel spins at 14,400 rpm for smooth fast-motion video, and has five color segments for more accurate colors. Comprised of five colors, Red, Green, and Blue, plus Cyan and Yellow, it achieves film-like transitions and eliminates the pixel breakup found in slower color wheel designs and slower-switching LCD microdisplays. The Cinema Smooth(TM) light engine uses a whisper quiet air bearing design.
Samsung`s DNIe(TM) - Digital Natural Image Engine
Samsung`s exclusive Digital Natural Image engine makes the sharpest and clearest images possible, regardless of the profile of input signals. Five image processors and a six-times density enhancer ensure the best picture from any source. Now in its sixth generation (since 2002), DNIe guarantees the truest colors and highest contrast, while virtually eliminating digital artifacts.
My Color Control
You can get the pink tones, the green of the grass and the blue of the sky just the way you like, without affecting the other colors on the screen. The three major colors can be adjusted to perfectly fit your taste. Self expression meets display perfection.
Cinema Mode
Samsung`s Cinema Mode lets you see colors the way the director intended, by matching them more closely to production standards. This creates more accurate colors and natural skin tones when viewing Hollywood movies on your TV—the perfect setting when enjoying movies with the lights off.
Cinema Smooth(TM) Film Mode 3:2 Pull Down
Powered by Samsung`s Cinema Smooth technology, 3:2 Pull Down corrects for the artificial frames created when films are converted to DVDs. The result is a clearer image without the subtle motion artifacts caused by 24-to-30 frames per second video conversion.
Picture Format Size Adjustment
Enjoy all your 4:3 aspect-ratio programming in smooth, wide-screen without black bars. Four pre-set aspect ratio modes—Normal, Wide, Zoom 1 and Zoom 2—stretch your image to fill the screen naturally.
Energy Efficient
Samsung DLP TVs are more energy efficient than many flat panel TVs, resulting in significant utility savings over the life of the TV.
Color Temperature Adjustments
Cool1, Cool2, Normal, Warm1, Warm2 selectable with on-screen display.
3D Comb Filter dramatically reduces edge image artifacts while improving transition detail.
Previous Channel returns to the previously viewed channel at the push of a button.
Game Mode enhances dark areas, sharpens the picture, speeds up the image processing response and enhances the sounds of your games. Picture and sound quality optimized for the special needs of gaming systems at the touch of a button.
Closed Caption displays dialog that can be read along with encoded broadcast TV programs and pre-recorded videos.
Non Volatile Memory preserves audio, video and menu settings during power outages.
Auto Volume Leveler keeps audio volume consistent during channel changing to minimize static sound bursts.
Discrete IR Codes
This set is equipped with discrete IR codes for use with an optional macro/programmable remote (see owners manual for details).
Universal Remote Control permits control of the TV, DVD, VCR and a Tuner/Receiver.
HDMI (High-Definition Multimedia Interface) addresses both pure digital audio and video performance and simplifies connections from the new generation set-top boxes, HD game consoles, HD Blu-ray(TM) and DVD players by reducing cable connections to one cable and plug.
DTV and DVD Compatible Connect your DVD and DTV sources with two smart component video (Y/Pb/Pr) inputs that accept 480p/720p/1080i/1080p signals.
PC
A Samsung HDTV using DLP technology can also function as a high-quality XGA PC monitor with 1080p compatibility.
Specification Description
Model HL-T6176S, HLT6176S
UPC 036725261761
Analog Audio Rear Input
Analog Audio Rear Output
Analog Audio / Video (2) Rear Input
Aspect Ratio 16:9
Compatible Furniture or Stand TR500X3B
Component Video (2) Rear Input
Contrast Ratio 10,000:1
DB15 (PC Video) Rear Input
Depth (Inches) 11.5
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Height (Inches) 35.8
Optical Rear Output
Projection Type DLP Rear Projector
Remote Control Included
Resolution 1920 x 1080
RF (2) Rear Input
S-Video (2) Rear Input
Screen Size 61" Diagonal
Screen Size (inches) 61
Select DLP Units
Speakers 10 Watts x 2
Stand Optional
Surround Modes SRS TruSurround XT
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port USB 1.1
Viewing Angle 140 degrees Horizontal
Viewing Angle 60 degrees Vertical
Weight (Pounds) 74.1
Width (Inches) 55.1
Samsung 61-inch Slim 1080p DLP Rear Projection HDTV (HL-T6176S) Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 61-inch Slim 1080p DLP Rear Projection HDTV (HL-T6176S)
See all eBay results
  at eBay.com
Product Reviews
Last update: Nov 5, 2008
Samsung 61-inch Slim 1080p DLP Rear Projection HDTV (HL-T6176S) Reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
Spots spoil the good stuff!
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"Overall, the picture is very good...I read the reviews before purchasing this TV, but am disappointed in the permanent spots that appear on the screen, especially when there is a light background. My family has commented also, upon viewing this set.
Upon checking into the Samsung manual that came …"  Read Full Review »
Was this Rear Projection TV review on the Samsung 61-inch Slim 1080p DLP Rear Projection HDTV (HL-T6176S) helpful to you?
Aug 31 2008
Penny
Amawalk, NY
I am:
  • Practical
Reviewed at:
[1 of 1 customers found this review helpful]
Samsung DLP is out this world.
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • NONE OF THE ABOVE
    Best Uses
  • Home
  • Movies
  • Video
  • WII and XBOX360
"The ease of use and setup are incredible and the picture is comparible to anything out there. Using my XBOX360 or WII has taken on a whole new meaning. The picture is bright and clear. We use it to watch fight tapes since my spouse is a pro boxer and now we can't get the others to leave after watchi …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jun 9 2008
strait4prez
Chicagp
I am:
  • Tech Savvy
Reviewed at:
Everything's Great Except For!
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Movies
"This TV is everything I was hoping it would be, except, I was advised that DLP was exceptional for moving objects like in NASCAR, NFL, etc. I found out during the Olympics that the picture would become pixelated during the diving competitions but so far that was the only time. Maybe the dives are t …"  Read Full Review »
Aug 29 2008
Armrooster
Buffalo NY
I am:
  • Tech Savvy
Reviewed at:
Good Price,Good Product
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Im glad I made this purc
  • Simple Controls
    Cons
  • No Cons
    Best Uses
  • Home
  • Movies
  • Video
"I bought this product for personal use. I enjoy the big screen very much and it works perfectly. Although my wife thought the TV was too big for the room, we found that as time passes it seems to fit better each day. "
Aug 29 2008
Robin
Windham,NH
I am:
  • Practical
Reviewed at:
I love it! Its like my own movie theater
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"IM NOW USING THIS PRODUCT IN MY LIVING ROOM 2 ENTERTAIN MY GUEST WITH MOVIES OR VIDEO GAMES. ITS SO CLEAR IT CAN BE SEEN CLEARLY FROM ALL ANGLES OF THE ROOM. THERES NOT ONE THING BAD I CAN SAY ABOUT THIS PRODUCT HONESTLY. "
May 27 2008
JUNITO AKA PAPICHULO
QUEENS, NEW YORK
I am:
  • Practical
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
