Samsung 61-inch LED 1080p DLP Rear Projection HDTV - HL-T6187S
5.0
based on 6 reviews
Ratings Distribution
5 star
6
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Attractive design (6)
  • Simple controls (5)
  • Fast setup (4)
  • Great picture quality (4)
  • Lightweight (1)
See less See more
Cons
  • No picture in picture (1)
Best Uses
  • Home (5)
  • Movies (4)
  • Blu ray dvd (1)
  • Professional (1)
  • Video (1)
Provided by Buzzillions.com
Enjoy more picture and less frame with Samsung's HL-T6187S DLP HDTV. The piano black bezel is just 0.6-inches wide; the set's slim depth lets it fit where others won't. The energy-efficient 61-inch screen features a powerful, long-lasting LED light engine that turns on almost instantly. Full HD 1080p resolution and Samsung Cinema Smooth(TM) technology deliver a wide range of brilliant colors, with bright images and crisp definition. The blackest blacks, brightest whites and nuanced tones are yours with a 10,000:1 dynamic contrast ratio. Hidden speakers deliver clear, robust SRS TruSurround XT(TM) sound.
Integrated HDTV Tuner with the addition of a suitable UHF/VHF antenna delivers the world of free off-air DTV and HDTV local broadcast channels. An additional QAM tuner decodes unscrambled digital cable signals.
Cinema Smooth(TM) Light Engine
Samsung is the worldwide leader in creating light engines that harness DLP HDTV technology from Texas Instruments. Samsung`s Cinema Smooth light engine brings together the right optics, electronic circuitry and replaceable light source to create a brilliant picture that`s more lifelike and much closer to film. Now in its sixth year of evolution, Samsung`s Cinema Smooth light engine delivers crisp, 1080p High Definition resolution with high contrast and brightness, defined edges and sharp detail.
LED (Light Emitting Diode) for modern color realization
LED replaces arc lamp & color wheel and realizes beautiful color
  • LED will last the life of the TV (No lamp to change)
  • Samsung LED DLP TVs eliminate the need to replace the consumable lamps every few years, and thus have less impact on the environment and on one`s wallet.
  • Ultra-Wide Color Gamut exceeds NTSC defined color space
  • More energy efficient than similar sized flat panel displays
  • Ultra quiet (no color wheel noise)
    Next Generation DLP Chips from Texas Instruments
    Samsung employs a Texas Instruments DLP chip that is comprised of millions of microscopic mirrors. The DLP chip is faster than any other HDTV technology, with the mirrors switching on & off 15,000 times a second to deliver a razor-sharp picture for fast moving images. When combined with Samsung`s new Cinema Smooth light engine, the result is a crisp, bright picture with deep, rich colors that`s closer to film.
    Samsung`s DNIe(TM) - Digital Natural Image Engine
    Samsung`s exclusive Digital Natural Image engine makes the sharpest and clearest images possible, regardless of the profile of input signals. Five image processors and a six-times density enhancer ensure the best picture from any source. Now in its sixth generation (since 2002), DNIe guarantees the truest colors and highest contrast, while virtually eliminating digital artifacts.
    My Color Control
    You can get the pink tones, the green of the grass and the blue of the sky just the way you like, without affecting the other colors on the screen. The three major colors can be adjusted to perfectly fit your taste. Self expression meets display perfection.
    Cinema Mode
    Samsung`s Cinema Mode lets you see colors the way the director intended, by matching them more closely to production standards. This creates more accurate colors and natural skin tones when viewing Hollywood movies on your TV—the perfect setting when enjoying movies with the lights off.
    Cinema Smooth(TM) Film Mode 3:2 Pull Down
    Powered by Samsung`s Cinema Smooth technology, 3:2 Pull Down corrects for the artificial frames created when films are converted to DVDs. The result is a clearer image without the subtle motion artifacts caused by 24-to-30 frames per second video conversion.
    Picture Format Size Adjustment
    Enjoy all your 4:3 aspect-ratio programming in smooth, wide-screen without black bars. Four pre-set aspect ratio modes—Normal, Wide, Zoom 1 and Zoom 2—stretch your image to fill the screen naturally.
    Energy Efficient
    Samsung DLP TVs are more energy efficient than many flat panel TVs, resulting in significant utility savings over the life of the TV.
    Color Temperature Adjustments
    Cool1, Cool2, Normal, Warm1, Warm2 selectable with on-screen display.
    3D Comb Filter dramatically reduces edge image artifacts while improving transition detail.
    Previous Channel returns to the previously viewed channel at the push of a button.
    Game Mode enhances dark areas, sharpens the picture, speeds up the image processing response and enhances the sounds of your games. Picture and sound quality optimized for the special needs of gaming systems at the touch of a button.
    Closed Caption displays dialog that can be read along with encoded broadcast TV programs and pre-recorded videos.
    Non Volatile Memory preserves audio, video and menu settings during power outages.
    Auto Volume Leveler keeps audio volume consistent during channel changing to minimize static sound bursts.
    Discrete IR Codes
    This set is equipped with discrete IR codes for use with an optional macro/programmable remote (see owners manual for details).
    Universal Remote Control permits control of the TV, DVD, VCR and a Tuner/Receiver.
    HDMI (High-Definition Multimedia Interface) addresses both pure digital audio and video performance and simplifies connections from the new generation set-top boxes, HD game consoles, HD Blu-ray(TM) and DVD players by reducing cable connections to one cable and plug.
    DTV and DVD Compatible Connect your DVD and DTV sources with two smart component video (Y/Pb/Pr) inputs that accept 480p/720p/1080i/1080p signals.
    PC
    A Samsung HDTV using DLP technology can also function as a high-quality XGA PC monitor with 1080p compatibility.
  • Specification Description
    Model HL-T6187S, HLT6187S, SAMHLT6187S
    UPC 036725261891
    Analog Audio Rear Input
    Analog Audio Rear Output
    Analog Audio / Video (2) Rear Input
    Aspect Ratio 16:9
    color null
    Compatible Furniture or Stand TR500X3B
    Component Video (2) Rear Input
    Contrast Ratio 10,000:1
    DB15 (PC Video) Rear Input
    Depth (Inches) 14.4
    HDMI (3) Rear Input
    HDTV HDTV Tuner Built In
    HDTV Native Resolution 1080p
    Height (Inches) 37.8
    Optical Rear Output
    Projection Type DLP Rear Projector
    Remote Control Included
    Resolution 1920 x 1080
    RF (2) Rear Input
    S-Video (2) Rear Input
    Screen Size 61" Diagonal
    Screen Size (inches) 61
    Select DLP Units
    size null
    sku 104004
    skuprice 2119.9900
    Speakers 10 Watts x 2
    Stand Optional
    style SAMHLT6187S
    Surround Modes SRS TruSurround XT
    taxable Y
    Tuner ATSC
    Tuner NTSC
    Tuner QAM
    USB Port USB 1.1
    Viewing Angle 140 degrees Horizontal
    Viewing Angle 60 degrees Vertical
    Weight (Pounds) 74.7
    Width (Inches) 54.8
    Samsung 61-inch LED 1080p DLP Rear Projection HDTV - HL-T6187S Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: 61-inch LED 1080p DLP Rear Projection HDTV - HL-T6187S
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Aug 29, 2008
    Samsung 61-inch LED 1080p DLP Rear Projection HDTV - HL-T6187S Reviews
    Displaying 1 - 5 of 6 Reviews
    Show
    Sort by
    EXCELENT TV I LOVE IT
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • No Picture in Picture
      Best Uses
    • BLU RAY DVD
    • Movies
    "[...] I think the 61" picture is much clearer than the 56". However there is no doubt that the 56" was much brighter. I do like the fact that this tv has utilizes LEDs as the light source because they last longer. I also have this tv in a very very bright room and unlike the 56" there is little …"  Read Full Review »
    Was this LCD TV review on the Samsung 61-inch LED 1080p DLP Rear Projection HDTV - HL-T6187S helpful to you?
    Dec 19 2007
    lovingit
    chicago,il
    I am:
    • Gearhead
    Reviewed at:
    Wow
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    "Make sure you get DishNetwork for your HD. I had comcast and their hd service is not good at all. So if want the best quality from this tv make sure get the Dishnetwork "
    Aug 29 2008
    Fermin
    Albuquerque, NM
    I am:
    • Tech Savvy
    Reviewed at:
    Excellent Buy!
    5.0
      Pros
    • Attractive Design
    • Lightweight
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    "I love the size of the screen. It allows for good viewing no matter where you are sitting in the room. The picture is not as sharp as it would be if I had a HD satellite receiver. "
    Feb 11 2008
    Size Matters
    Beltsville, MD
    I am:
    • Tech Savvy
    Reviewed at:
    Great value
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    "Excellent picture. [...]Great value. Highly reccommend. "
    Aug 29 2008
    JayZ
    Kerman, CA
    I am:
    • Tech Savvy
    Reviewed at:
    Like it a lot!!
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Professional
    • Video
    "Best big screen TV on the market! "
    Sep 5 2007
    JJ
    St. Louis, MO
    I am:
    • Tech Savvy
    Reviewed at:
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
