Samsung 55" 1080p LED 120HZ LCD HDTV UN55B6000VFXZA
#11
4.7
based on 84 reviews
Ratings Distribution
5 star
63
4 star
17
3 star
3
2 star
0
1 star
0
Category Average
4.4
$2,114.61 - $2,799.00
from 16 stores
More Images
Pros
  • High resolution (54)
  • Attractive design (53)
  • Bright image (52)
  • Fast setup (48)
  • Good connection options (48)
  • Simple controls (32)
  • Reduced glare (29)
  • 3d depth (1)
  • Auto volume is "heaven" (1)
  • Beautiful colorful border (1)
See less See more
Cons
  • Poor sound quality (8)
  • Poor connection options (3)
  • Bad interface (1)
  • Best tv experience ever (1)
  • Cannot project pc monitor (1)
  • Color not as crisp as lcd (1)
  • Glare (1)
  • Jump from hdmi to local (1)
  • Jump from local to hdmi (1)
  • Lcd image is better (1)
Best Uses
  • Home theater (43)
  • Movies (40)
  • Home (36)
  • Wall mounting (36)
  • Bedroom (6)
  • Piece of art (1)
Provided by OneCall
Picture Perfect
For images that are stunningly true to life you need the 3 Cs: contrast, color and clarity. Ultra-brilliant Samsung LED TVs have them all. Mega Contrast provides an incredible range of brightness - from pure blacks to pristine whites. Advanced Color Processing enables a wider range of natural colors and provides greater depth for a vibrant, captivating picture - even with subtle colors. Plus our Auto Motion Plus 120 Hz technology eliminates virtually all motion blur, leaving your picture smooth and crisp - and your jaw dropped.
Depth without depth.
Thanks to our innovative, optional Wall Mount (WMN1000B), our astonishingly slim LED TVs can be hung just like a picture frame - less than two inches from the wall. Only this frame is made with a hint of amber. We call it a Touch of Color. One look at it and its soft, square corners is all it takes to see that this isn't just a TV you're hanging. But a work of art. Our most advanced HDTV technology contained in a razor-thin silhouette. Stunning at only 1.2" deep, Samsung LED TVs are our slimmest HDTVs yet. Supported by a unique stand with an elegant, crystal-clear neck, you'll have no trouble finding a place for one in any room.
Green works in any room.
Samsung LED TVs are easy on the planet as well as the eyes. They use 40% less power than conventional LCDs.ยน And they're free of lead, mercury and other VOCs. So you can put your feet up and relax knowing you're leaving a smaller carbon footprint.
The world wide web just got wider.
Can't decide if you'd rather watch TV, see your photos on Flickr or photos check your stocks on Yahoo? Do it all on Samsung Series 7 LED TVs. An easy to use widget lets you watch, add or delete content. View it all on the roomy sidebar or across the incredibly wide screen. With our Series 7 LED TVs, TV goes way beyond just TV.
Getting on TV made easy.
Samsung Series 7 LED TVs 7 take the struggle out of sharing your talent with the world, or at least with your family. Access your videos, music and photos from your PC or from your DLNA mobile device - wirelessly and effortlessly - and enjoy them on your TV. Our LED TVs can even connect with multiple PCs. Who said you need connections to get on TV?
Your audience awaits.
There's no excuse anymore for leaving all those great digital pictures and videos in your cameras or storage devices. Thanks to the USB 2.0 Movie: Multi-media Center feature on all Samsung LED TVs you can connect your digital camera, thumb drive - even your MP3 player - quickly and easily. The smart, user-friendly USB 2.0 interface allows you to access videos, playlists and pictures with your remote. Now anytime can be showtime.
Library hours extended.
Suppose you feel like playing a game of chess or cooking instead of watching TV. Samsung Series 7 LED TV's Content Library Flash feature lets you do just that Enjoy hours of built-in entertainment features, then personalize it by adding content that's available online. And downloading is easy. There's so much you can do with our Series 7 LED TVs.
Specification Description
Model UN55B6000, UN55B7000
UPC 036725229808
Analog Audio (1) Rear Output
Analog Audio (1) Side Output
Analog Audio (2) Rear Input
Analog Audio / Video (1) Rear Input
Aspect Ratio 16:9
Command / Control EX-LINK
Component Video (2) Rear Input
Component Video Rear Input
Contrast Ratio 3000000:1
DB15 (PC Video) Rear Input
Energy Star Compliant Yes
HDMI (4) Rear Input
HDMI (4) Side Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Optical Rear Output
Optical Side Output
PC Audio Rear Input
PC Audio Side Input
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1080
RJ45 Ethernet Rear Input
Screen Size 55"
Screen Size (inches) 55
Speakers Built-in
Stand Included
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port (2) Rear Input
USB Port (2) Side Input
Wall Mountable Yes
Samsung 55" 1080p LED 120HZ LCD HDTV UN55B6000VFXZA Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Samsung 55" 1080p LED 120HZ LCD HDTV UN55B6000VFXZA Reviews
Most helpful positive review
Most helpful negative review
5.0
Excellent HDTV; make neighbors gealous!
"The TV looks excellent hanging on top of the fireplace. With the ultra slim wallmount, it is < 2" from the wall. It is in a very bright living room with lots of natural light and glare is not a problem even though it has a glossy finish. The Blue-Rays and HD Satellite receiver makes the picture "jaw-dropping". It has very limited connectivity to non-HD devices, so use it only with HD components, if you can...." Read Full Review »
Sep 17, 2009 by Manu
See more positive Samsung 55" 1080p LED 120HZ LCD HDTV UN55B6000VFXZA reviews
3.0
It's an expensive TV
"[...]I use this TV as a monitor. It's great. It's bright. It's beautiful. All the internet connectivity stuff in it is rubbish -- a total waste of time. Honestly -- the TV isn't probably worth the money for the average Joe, but for those looking to show off, well, it's money well spent...." Read Full Review »
Oct 19, 2009 by Frank
See more negative Samsung 55" 1080p LED 120HZ LCD HDTV UN55B6000VFXZA reviews
Displaying 1 - 5 of 84 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Resolution
  • Reduced Glare
    Cons
  • Poor Connection Options
    Best Uses
  • Home
  • Home Theater
  • Wall Mounting
"The TV looks excellent hanging on top of the fireplace. With the ultra slim wallmount, it is < 2" from the wall. It is in a very bright living room with lots of natural light and glare is not a problem even though it has a glossy finish. The Blue-Rays and HD Satellite receiver makes the picture " …"  Read Full Review »
Was this LCD TV review on the Samsung 55" 1080p LED 120HZ LCD HDTV UN55B6000VFXZA helpful to you?
Sep 17 2009
Manu
San Jose, CA
I am:
  • Enthusiast
Reviewed at:
Price: $2,569.99
Best Picture
4.0
    Pros
  • Attractive Design
  • Auto Volume is "heaven"
  • Best HD Picture Available
  • Fast Setup
  • Good Connection Options
  • More »
    Cons
  • PIP Ackward to Use
  • Poor Sound
    Best Uses
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"Pros I have been shopping for this TV for over 2 years. I have had it for approximately 2 weeks. I was looking for quality, affordability and peace of mind that I was buying from reputable company. I wanted Plasma picture quality on an LCD since our family room has bright sunlight during the day. …"  Read Full Review »
Nov 16 2009
Dave
Cleveland, OH
I am:
  • Enthusiast
Reviewed at:
Price: $2,188.18
[3 of 3 customers found this review helpful]
Really, really great
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • Movies
"This is some really good stuff. I upgraded from a 50" Samsung 720p Plasma and am really in awe of the picture quality. Even standard SD TWC cable programming looks great. The TV enhances SD picture's sense of depth and motion is dead-smooth. If you like the warm, soft look of film, this might not be …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
May 18 2009
Ken Pen
Raleigh, NC
I am:
  • Enthusiast
Reviewed at:
Price: $2,367.00
[5 of 5 customers found this review helpful]
A thin TV that has amazing depth
5.0
    Pros
  • 3D depth
  • Attractive Design
  • Bright Image
  • Fast Setup
  • More »
    Cons
  • Glare
    Best Uses
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"Very thin TV that gives a sense of depth I have never seen before. This 3D aspect is best seen from the center. The angle view is very good but only has the sense of depth as a normal TV. The TV is so thin and can be mounted so close to the wall that you need to pre-install any cable you want to …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
May 25 2009
Jim in his Den
Rockport, Ma
I am:
  • Casual User
Reviewed at:
Price: $2,188.18
So Far So Good
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home Theater
  • Movies
  • Wall Mounting
"I haven't been able to play around with many settings but the TV was easy to hook up out of the box and everything looks perfect (no dead pixels or damage [...]) Abe's was hundreds of dollars cheaper than [...]. [...] I have been trying to stare at the edges to try and find the one flaw of edge-lit …"  Read Full Review »
Nov 17 2009
MA
I am:
  • Enthusiast
Reviewed at:
Price: $2,188.18
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
