Samsung 52" Flat Panel LCD 1080p HDTV In Black
4.0
based on 9 reviews
Ratings Distribution
5 star
4
4 star
2
3 star
2
2 star
1
1 star
0
Category Average
4.4
More Images
Pros
  • Attractive design (7)
  • Fast setup (7)
  • Great picture quality (7)
  • High resolution (7)
  • Simple controls (7)
  • Good connection options (5)
  • Wide viewing angle (4)
  • Deep colorwhite balance (1)
  • Hdmi 13 (1)
  • The black level (1)
See less See more
Cons
  • Difficult to use (2)
  • Bad interface (1)
  • Difficult to set up (1)
  • Low resolution (1)
  • Poor connection options (1)
  • Poor image quality (1)
  • Poor sound quality (1)
Best Uses
  • Home (8)
  • Movies (7)
  • Video (6)
  • Office (1)
Provided by OneCall
For those who are ready for the clearest, brightest LCD picture on the market today, Samsung presents the LN-T5265F. Full 1080p resolution is just the beginning: the color-saturated 52-inch picture boasts a 15000:1 dynamic contrast ratio, displaying rich blacks and capturing subtle nuances. A fast 8ms response time ensures smooth, lifelike motion. SRS TruSurround XT(TM) sound from hidden side speakers is enhanced by the premium audio sound of 2.2 channel dome speakers. Enjoy connectivity with all your other digital devices, with 3 HDMI ports and a full complement of inputs. And the handy HMDI-CEC feature lets you control all your CEC-enabled peripherals using just one remote.
HD-Grade 1920 (H) x 1080 (V) pixel resolution: High resolution pixel density with built-in image scaler to handle inputs from a variety of digital and analog audio/ video sources.
Wide Color Gamut CCFL (Cold Cathode Fluorescent Lamp): Provides colors in your picture that were not available before.
Wide Color Enhancer optimizes a color`s hue resulting in more natural colors.
178º (H) / 178º (V) viewing angle improves viewing angle, contrast, and brightness to provide an even better picture.
10 bit processor
15000:1 contrast ratio/550nit brightness: As two of the most important determining factors in overall picture quality, contrast and brightness levels achieve new heights in this latest generation LCD panel. Samsung`s new LCD TV`s give the most stunning realistic picture quality ever from a flat panel set.
Wide Viewing Angle Panel
Super clear panel
Built-in digital tuner: (ATSC/Clear QAM)
Picture-in-Picture (PIP) enables convenient simultaneous viewing of TV programs and video or PC sources.
Game Mode enhances dark areas, sharpens the picture, speeds up the image processing response and enhances the sounds of your games. Picture and sound quality optimized for the special needs of gaming systems at the touch of a button.
8ms Response time: Fast 8ms response time minimizes blurring of moving video.
SRS TruSurround XT(TM) TruSurround is a patented SRS technology that solves the problem of playing 5.1 multichannel content over two speakers. TruSurround delivers a compelling, virtual surround sound experience through any twospeaker playback system, including internal television speakers and headphones. It is fully compatible with all multichannel formats up to 5.1 channels.
Side A/V ports provides easy connections so you can connect a camcorder, digital camera, or any other digital device with no hassles.
Removable stand and VESA compatible hole mounts: If you want to install your TV on your wall, you can easily remove the stand and use a VESA compatible wall mount to safely and stylishly attach your TV to the wall.
Specification Description
Model LN-T5265F, LN-T5265FX, LNT5265F
UPC 036725252615
Analog Audio / Video (1) Rear Input
Analog Audio / Video (1) Side Input
Aspect Ratio 16:9
Component Video (2) Rear Input
Contrast Ratio 15,000:1 (dynamic)
DB15 (PC Video) (1) Rear Input
Depth (Inches) 4.4
HDMI (1) Side Input
HDMI (2) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Height (Inches) 31.0
Refresh Frequency 60 Hz
Remote Control Included
Resolution 1920 x 1080
RF (1) Rear Input
S-Video (1) Rear Input
S-Video (1) Side Input
Screen Size 50" to 60"
Screen Size (inches) 52
Select LCD Units
Speakers 10 Watts x 2
Stand Swivel
Surround Modes SRS TruSurround XT
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port USB 2.0 High Speed
Viewing Angle 178 degrees Horizontal
Viewing Angle 178 degrees Vertical
Wall Mountable VESA Compliant
Weight (Pounds) 63.1
Width (Inches) 52.2
Samsung 52" Flat Panel LCD 1080p HDTV In Black Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 52" Flat Panel LCD 1080p HDTV In Black
See all eBay results
  at eBay.com
Product Reviews
Last update: Nov 28, 2008
Samsung 52" Flat Panel LCD 1080p HDTV In Black Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
Great Picture, great features!
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Movies
"This is our all-around TV. The first HD we've purchased. We purchased a smaller model Samsung last year for my parents and were so impressed that we decided to get the larger model for ourselves. I'm a little jealous that the Samsung "red" hadn't come out yet, because I think that is very stylish …"  Read Full Review »
Was this LCD TV review on the Samsung 52" Flat Panel LCD 1080p HDTV In Black helpful to you?
Sep 2 2008
PhoenixKitten
Cincinnati, Ohio
I am:
  • Couch Potato
  • Practical
Reviewed at:
great picture....unreliable
2.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Resolution
  • Reduced Glare
  • Simple Controls
    Cons
  • Bad Interface
  • Difficult to Setup
  • Difficult to Use
    Best Uses
  • Home
  • Movies
  • Video
"As soon as we set this LCD up the Audio was a acting up on us, it was distorting at random. We made sure it wasn't just the audio feed from the cable by playing a DVD, and a PS2 game. Sure enough it was the internal speakers, and then to make matters worse, the unit started to randomly turn itself o …"  Read Full Review »
Jul 7 2008
Nick the editor
Denver CO
I am:
  • Practical
  • Professional
  • Tech Savvy
beautiful clear picture
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Office
  • Video
"We have two of these in a church. It has PC inputs so works great for Power Point (as long as you use a large font) also it produces outstanding DVD pictures. Everyone in church is delighted. "
Aug 30 2008
Pastor Paul
Santa Fe, NM
I am:
  • Tech Savvy
Reviewed at:
Little Boom for the Buck
3.0
    Pros
  • Fast Setup
  • Simple Controls
    Cons
  • Dull Image
  • Poor Resolution
  • Sound Quality is poor
    Best Uses
  • Home
  • Movies
  • Video
"For the price it was a disapointment The Sound quailty is poor and the picture is nothing more than average in my opion. I have purchased Sony the last three TV's I should have stayed with them "
Nov 28 2008
Barrelman
Buffalo NY.
I am:
  • Enthusiast
Reviewed at:
Why would you watch anything else?
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"Not only is this an awesome TV, it looks beautiful in my living room. The picture is the best I've ever seen and sounds great too. "
Jun 4 2008
KO
Detroit - GO WINGS
I am:
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
