Samsung 52" 1080p LCD Flat Panel HDTV
4.5
based on 11 reviews
from
Ratings Distribution
5 star
7
4 star
3
3 star
0
2 star
1
1 star
0
Category Average
4.4
More Images
Pros
  • Attractive design (11)
  • High resolution (10)
  • Great picture quality (9)
  • Good connection options (8)
  • Fast setup (7)
  • Simple controls (4)
  • Wide viewing angle (3)
  • Nothing not to love about (1)
  • Spectacular tv (1)
See less See more
Cons
  • Difficult to set up (1)
  • Prone to reflections (1)
  • Sharp learning curve (1)
Best Uses
  • Home (10)
  • Movies (10)
  • Video (5)
  • Home theater (1)
  • Wall mounting (1)
Provided by Abt Electronics
Samsung 52" LCD Black Flat Panel HDTV - LNT5281F/ 1080p HD-Grade 1920 x 1080 Pixel Resolution/ 500000:1 Dynamic Contrast Ratio With Local Dimming Technology/ LED Backlight Technology/ 10 Bit Processing/ Integrated Built-In Digital Tuner (ATSC/Clear QAM)/ Auto Motion Plus/ Picture-In-Picture/ Game Mode/ USB 2.0/ SRS TruSurround XT/ Auto Volume Leveler/ Swivel Stand/ Black Finish
Specification Description
Model LN-T5281F
UPC 036725252813
Analog Audio / Video (1) Rear Input
Analog Audio / Video (1) Side Input
Aspect Ratio 16:9
Component Video (2) Rear Input
Contrast Ratio (Dynamic) 500,000:1
DB15 (PC Video) (1) Rear Input
Depth (Inches) 4.7
HDMI (1) Side Input
HDMI (2) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Headphone Jack (1) Side Output
Height (Inches) 30.7
Refresh Frequency 60 Hz
S-Video (1) Rear Input
S-Video (1) Side Input
Screen Size (inches) 52
Speakers 15 Watts x 2
Stand Pedestal
Viewing Angle 178 degrees Horizontal
Viewing Angle 178 degrees Vertical
Wall Mountable Yes
Weight (Pounds) 81.1
Width (Inches) 54
Samsung 52" 1080p LCD Flat Panel HDTV Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 52" 1080p LCD Flat Panel HDTV
See all eBay results
  at eBay.com
Product Reviews
Last update: Feb 3, 2009
Samsung 52" 1080p LCD Flat Panel HDTV Reviews
Most helpful positive review
Most helpful negative review
5.0
Best LCD HDTV I have seen
"When I was shopping around for my first HDTV (jan 09), I did a lot of research and found Plasmas to be king of HDTV image quality, due to the deep black range and resulting contrast ratio. While shopping in [...] I saw what I thought was a Plasma HDTV, and was shocked to find out it was a LCD model from Samsung. I was also surprised that the colors were accurate and the motion was smooth, and it appeared to ha..." Read Full Review »
Feb 03, 2009 by d2f
See more positive Samsung 52" 1080p LCD Flat Panel HDTV reviews
2.0
Samsung 5281F
"Its the new 81 series so they may be having problems. Screen went to a "pink screen" with no more picture after 1 day (possibly a bad board according to Samsung rep). [...] said I had to have an authorized tech look at it. The only problem is that there is only 1 Samsung authorized technician in this area and they are 3 weeks behind! So, can't watch the new Samsung for another week (maybe) and its been two weeks..." Read Full Review »
Oct 26, 2007 by Disappointed with Samsung
See more negative Samsung 52" 1080p LCD Flat Panel HDTV reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
    Best Uses
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"When I was shopping around for my first HDTV (jan 09), I did a lot of research and found Plasmas to be king of HDTV image quality, due to the deep black range and resulting contrast ratio. While shopping in [...] I saw what I thought was a Plasma HDTV, and was shocked to find out it was a LCD model …"  Read Full Review »
Was this LCD TV review on the Samsung 52" 1080p LCD Flat Panel HDTV helpful to you?
Feb 3 2009
los angeles, CA
I am:
  • Enthusiast
Beautiful out of the box
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
    Cons
    Best Uses
  • Movies
"There was no problems setting it up. I own 3 different sizes from the same manufacturer, so I am use to the menu. First time users may find it challenging. You have to cycle through different steps to get to where you want. But with practice, it gets to be second nature.
I watched the Incredib …"  Read Full Review »
Feb 26 2008
Pete
NYC, NY
I am:
  • Tech Savvy
Reviewed at:
Highly Recommended
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Resolution
  • Reduced Glare
    Cons
  • Difficult to Setup
    Best Uses
  • Home
  • Movies
  • Video
"This TV has an excellent picture, no mura/cloud problems that plague other manufacturers, and awesome blacks. However, there are way too many display settings, and I find myself constantly tweaking - trying to get the picture adjusted to my personal tastes. I dont think there is a "perfect" pictur …"  Read Full Review »
Sep 14 2007
OU812
Buffalo, New York
I am:
  • Practical
  • Tech Savvy
Reviewed at:
This Samsung LCD HDTV meets all quality
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"I have bought the Sony RHT S10 soundbar to supplement the TV speakers to enhance acoustic effects for special occasions. This soundbar does not give the sound-a-around effect, but it does allow you to add-on a powered subwoofer. "
Aug 30 2008
Rickie
San Jose, CA
I am:
  • Couch Potato
  • Practical
  • Professional
Samsung 5281F
2.0
    Pros
  • Attractive Design
    Cons
  • None
    Best Uses
  • Home
"Its the new 81 series so they may be having problems. Screen went to a "pink screen" with no more picture after 1 day (possibly a bad board according to Samsung rep). [...] said I had to have an authorized tech look at it. The only problem is that there is only 1 Samsung authorized technician in thi …"  Read Full Review »
Oct 26 2007
Tallahassee, FL
I am:
  • Tech Savvy
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
